Want to lift my 2x4
Discussion in 'Suspension' started by doodle_cakes, Nov 17, 2009.
  1. Nov 17, 2009 at 6:20 PM
    doodle_cakes
    doodle_cakes [OP] Well-Known Member
    Canada
    08 Taco SR5 5lugger
    I have an '08 2x4 access cab taco.
    I want to lift it about 3inches and then put slighly larger rims and tires on it for a bit more height and added hyper masculinity :)(riding on BF ATs / stock wheels right now).
    I have been reading all the threads and stickies I can find but I am still a bit lost of the best way to go for what I want.
    99% of my driving is just around town / highways. When I do take her into the bush it's nothing too punishing at all. So I want something that will be very smooth for around town but doesn't have to be able to take the abuse a 4x4 would see.
    I am willing to shell out a good amount of cash for a sexy setup, but I don't want to go overboard and get a setup that I wouldn't fully utilize based on where I will be driving. I basically just want to be able to order everything I need online (not sure exactly all the parts I need), take her to a shop and have her good to go.
    5100's seem pretty popular, but again because I'm just in a 2x4 for around town I don't know if these would be practical.
  2. Nov 17, 2009 at 6:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Are you a Prerunner or a "5 Lugger" (number of lug nuts on wheel)
  3. Nov 17, 2009 at 6:47 PM
    doodle_cakes
    Canada
    08 Taco SR5 5lugger
  4. Nov 17, 2009 at 7:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think there are a couple of spacer kits on the market that give a 2" lift or so, and allow the use of a 31" tire. Otherwise, Total Chaos (and maybe a couple of others) makes a Long Travel kit for your truck.
  5. Nov 18, 2009 at 7:35 PM
    doodle_cakes
    Canada
    08 Taco SR5 5lugger
    Thanks. I am still pretty confused on the best way to go about this since I have never lifted a vehicle before.
    The total chaos one looks very nice http://www.chaosfab.com/88500.html
    but they only ship to authorized dealers and don't have any prices listed. There are 2 dealers in Canada, both of which I will be near within the next month or 2.
    Do you think this is pretty pricey and I would be better off just going with something more simple like this: http://www.readylift.com/c-104-tacoma-prerunner-sst-lift-kit-2005-2009-2wd-4wd-275-30f10r.aspx
  6. Nov 18, 2009 at 7:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That kit wont fit your truck. Its for the 4x4/Prerunner trucks.
  7. Nov 18, 2009 at 7:46 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Sorry, but this is a :threadjacked: because your description applies perfectly to me, but I'm a 6 lug prerunner, so if anyone want to suggest a lift to match that descirpion for my truck I am all ears.
  8. Nov 18, 2009 at 7:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Bilstien 5100's for you ;)
  9. Nov 18, 2009 at 8:31 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    TY Chris, I've read enough posts to know you know everything and to never doubt your opinion ;). With any luck they will release a rear spring TSB for 2010 tacomas and I can get some 5100's set at 1.75.
  10. Nov 19, 2009 at 6:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I surley dont know everything. :eek:, but that would be a good set up on your truck :)
  11. Nov 25, 2009 at 6:07 PM
    doodle_cakes
    Canada
    08 Taco SR5 5lugger
    oops didn't see that it said 6lug in small print.
    Right now I'm looking at this one:
    http://www.readylift.com/c-107-tacoma-5-lug-sst-lift-kit-2005-2009-2wd-275f175r.aspx
    If I install this, is there anything else I can add later to give her another inch or 2? Or would I have to go with a different kit completely? I guess when I put larger rims and tires that will add a couple more inches of clearance too though.
  12. Nov 25, 2009 at 6:19 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    OK, so if you have a 2wd Taco I am assuming you want a lift for looks primarily, correct? Probably want to throw on some larger tires and have that 4x4 look?
    OK, so if that is the case you might consider a body lift, or a spindle lift. Cheap and give good results, except they'll change your ride characteristics and vehicle stability.
    Here is a link to a TacomaWorld thread from a few days ago about exactly what you are asking, I think?
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/61918-help-lift-2wd.html
  13. Nov 25, 2009 at 6:24 PM
    mountainwolfpup
    Vancouver, WA
    Hmmm. Not sure you can do the spindle lift if it's not a Prerunner? Not sure. Chris4x4 would know...
    From my naive understanding it should be possible. If so, you could get 4" lift pretty easily.
    Just throw on add-a leaf in the rear and some blocks and new shocks. And then the spindle kit in the front.
  14. Nov 25, 2009 at 6:30 PM
    doodle_cakes
    Canada
    08 Taco SR5 5lugger
    yea I don't want something that will mess around with my factory ride feel too much, which from what I've read, this Ready lift kit doesn't.
    I do want it largely for looks, but even though it's a 2wd I still spend a lot of time in the mountains and wouldn't mind have a bit more clearance on my diff which is why I need this so I can put larger tires on her.
    I want to change the shocks up too. From what I've found pro comp 324515 are a good match with this lift. anyone know otherwise?
