Want to lift my truck 6inchs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jwoo, Aug 27, 2023.
  1. Aug 27, 2023 at 5:44 PM
    Jwoo
    Jwoo [OP] Member
    Have a 2015 Tacoma v6 it sits the lowest out of all the models. Looking to do a 6 in full suspension rough country lift. Any one and any suggestions?
  2. Aug 27, 2023 at 5:53 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    If you just want approximately 6" of total lift, you could do a 3" lift and then move from the factory tires to 32s or 33s. A 6" lift + tires to make it look proportional (usually 35s) is going to give you like 9-10 inches over factory. 6" will also usually require a drop bracket, so there's no turning back, unless you're 2wd and then you can do a 4" spindle lift + coilovers.
    LeakyAC likes this.
  3. Aug 27, 2023 at 6:01 PM
    Jwoo
    Jwoo [OP] Member
    Bottom of door sits at 19 inches now add 6 to that. 6 inch isn’t true 6
  4. Aug 27, 2023 at 6:07 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    That's typically the case with any lift. Depends on your cab model, weight in/on your truck, etc.
  5. Aug 27, 2023 at 6:11 PM
    Jwoo
    Jwoo [OP] Member
    I was thinking 4 then talked my self into a 6… no pictures really of access cabs
  6. Aug 27, 2023 at 6:13 PM
    Jwoo
    Jwoo [OP] Member
    6 inches 20 inch wheels 33-35 most likely 35s not gonna be wheeled
  7. Aug 27, 2023 at 6:18 PM
    Clearwater Bill
    Billy
    Largo Florida
    Don't.
    IMHO it's not worth cutting a hunk out of your frame for a looker lift.
    When time to sell your market will be quite limited.
    LeakyAC and Superdave1.0 like this.
  8. Aug 27, 2023 at 6:57 PM
    Jwoo
    Jwoo [OP] Member
    One thing is I am not cutting the truck up I inherited this truck and it’s not going anywhere the rough country 6 inch suspension lift says nothing about cutting the frame.
  9. Aug 27, 2023 at 6:59 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Send the link to the kit here. I bet you it does. I'd do some solid research on this before ordering that kit.
    LeakyAC likes this.
  10. Aug 27, 2023 at 7:01 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Are you 2wd or 4wd? If 4wd you will absolutely be cutting the front crossmember
    LeakyAC and EDDO like this.
  11. Aug 27, 2023 at 7:05 PM
    Clearwater Bill
    Billy
    Largo Florida
    Whatcha willing to lose.... Uh, I mean bet?
    gsubioguy and LeakyAC like this.
  12. Aug 27, 2023 at 7:06 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    I would advise against going past 3in of lift. IF you do not do hard core off-roading.
    If you are going past 3in you will be spending a lot on cutting and parts out of the wazoo on your truck.
  13. Aug 27, 2023 at 7:07 PM
    Jwoo
    Jwoo [OP] Member
    Welll you guys are rite that kit involves cutting
  14. Aug 27, 2023 at 7:43 PM
    Jwoo
    Jwoo [OP] Member
    Truck only have 42000 on it. Is it worth cutting if I m keeping
  15. Aug 27, 2023 at 7:48 PM
    Bishop84
    Bishop84 Well-Known Member
    2WD? or 4WD?
  16. Aug 27, 2023 at 8:00 PM
    Williston
    Williston Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Don't do it.
    Not sure of the finer specific details of your particular truck, (4x4, TRD, etc) but I have a 2014 4x4 double cab (stock) and it definitely doesn't "sit the lowest of all the models". Not even close. Maybe something else is going on with your truck: overloaded at some point? Towing a huge trailer? someone already modified it?.... (i.e.: lowered it)
    LeakyAC likes this.
  17. Aug 27, 2023 at 8:12 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Please don't ruin your truck.
  18. Aug 27, 2023 at 8:30 PM
    BluberryBCtaco
    BC Canada
    Let’s ask the all important question.
    • What is your budget?
    • What do you plan on doing with your truck?
    • Do you plan on going off-road every weekend?
    • Do you plan on going once a month?
    • Do you plan on going rock crawling / dune bashing?
    • Do you plan on going heavy / hard core off-roading?
    • Is the truck going to be a pavement princess?
    • Is the truck a daily driver?
    • Is the truck a commercial/ work truck?
    Your post #6 said “it’s not going to get wheeled”. Aka going not off-roading truck.
    and on post #8 you have no desire to cut the truck / do heavy modifications
    So let’s keep it inside those parameters in mind.
    Keep it 3in lift and under, and you will meet Post#8 requirements.
    You can go Bilstine 5100, new coils, and leaf pack, or similar product that can give you a fair lift, and it can get you on some easy/ moderate trails.
    You can do spacer blocks up to 3in with Rough country shocks and springs, if budget is the Main limiting factor, and it keeps with post #6 since you do not plan to go off-road with it.
    The key thing is:
    What is your requirements, and use case?
  19. Aug 27, 2023 at 8:40 PM
    Jwoo
    Jwoo [OP] Member
    The bottom of the door sits at 19 inches now my dad bough it brand new only owner now it’s on to me. He always wanted it lifted but could never do it because he would be able to get into it. If I lift it 3 inches could I get 33S under its
  20. Aug 27, 2023 at 8:57 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    To each there own, nothing wrong with drop bracket lifts. They catch a lot of heat on the forums because he said she said. My only advice is if your gonna go 6"......do it right. Do your research. Look into different brands. Cheaper isn't always better. You get what you pay for.
    Jwoo[OP] likes this.
