Want to make STICKY DIY Valve Cover Gasket
Discussion in '4 Cylinder' started by TurboBoss, Oct 26, 2014.
  1. Oct 26, 2014 at 8:57 AM
    TurboBoss
    TurboBoss [OP] Active Member
    Panama Rep. of Panama - Central America
    Hey guys,
    I am going to replace my 2TR-FE Valve Cover gasket since is leaking and want to take the oportunity to take as much pics to make a STICKY
    Please help me with the following:
    1) Whats is the torque for the valve cover screws?
    2) Any advise on what to focus when talking pics and what to pay attention during changing the gaskets)
    THX,
    Isaac
    pinktaco808 and BassAckwards like this.
  2. Nov 1, 2014 at 6:56 AM
    TurboBoss
    So, nobody knows the torque for the valve cover screws?
    Come on guys, help me with this info.
    THX,
    Isaac
  3. Nov 1, 2014 at 10:05 AM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    From the Torque spec guide under 2nd gen, 80 in-lbs.
    pinktaco808 likes this.
  4. Nov 3, 2014 at 5:00 AM
    TurboBoss
    Hey Nickonfire700,
    Thx for your reply. Were can I get the torque spec guide? I want to have it for future reference.
    THX,
    Isaac
  5. Nov 3, 2014 at 6:36 AM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
  6. Jan 9, 2015 at 5:15 AM
    ojose
    ojose Active Member
    Jose
    San Juan, PR
    08 5-lug 4 cyl Base Access Cab
    TurboBoss... Did you made the sticky yet? I will be changing the head valve gasket for mine this month and wanted to be sure what i'm supposed to be doing
  7. Jan 10, 2015 at 11:21 AM
    TurboBoss
    Hey Guys,
    I have not doit this yet. I have a pinch nerve in my back that is killing me and if my wife see me working on my car, she will scream! :annoyed:
    But you can download this Word document and you will find the Torque and sequence for the valve cover
    https://www.dropbox.com/s/vjc0p0e43ce6r86/2TR FE Valve Cover Gasket.doc?dl=0
    Good luck
    Isaac
  8. Mar 25, 2015 at 7:40 AM
    reloader403
    reloader403 Well-Known Member
    Acworth, GA
    2003 RC 2wd 2.4 auto
    Just replaced mine this last weekend, used the Haynes manual....and what do you know? it didn't say anything about using form in place gasket for the two spots like the drop box attachment turboboss posted. Looks like I'll be redoing it and adding some sealant.
  9. Mar 29, 2015 at 5:44 PM
    Indy
    Indy Master of all I survey.
    Remove air tube, remove plug wires, remove cover bolts, replace gasket, replace bolts, replace wires, replace airtube. 30 minute job.
  10. Feb 8, 2018 at 9:28 PM
    81shark
    81shark Well-Known Member
    guess it's my turn. maybe i'll do it live on youtube.
  11. Feb 11, 2018 at 6:23 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    It wasn't a 30 minute job for me, the wiring harness coming around the front of the valve cover was a PITA to work around because it's so taut. Plus the gasket was brittle, stuck to every surface, and had to be removed in chunks. Probably took me about two to three hours being very careful not to drop dirt and gasket pieces onto the valve train. Still not a bad job. Replaced PCV valve while the cover was off too.
    stnenginnerjr likes this.
  12. Feb 15, 2018 at 7:10 PM
    81shark
    i'd love to see somebody do it in 30 minutes.. my ass
    pinktaco808 and ecoterragaia like this.
  13. Feb 15, 2018 at 7:11 PM
    81shark
    all cleaned up now and ready to be put back together. this is post cover removal, pre cleaning
    pinktaco808, MY50cal and Jeffch like this.
  14. Feb 15, 2018 at 7:16 PM
    81shark
    so tips so far...
    everything is 10MM except the bolt that holds the pcv pipe on the back of the block. it's 12mm you will want a wrench if you do this. i pulled it as i needed more wiggle back there.
    disconnected a ton of the wiring harness.. to the injectors, cam position sensor and couple of others to give the wiring harness a little more play
    also pulled the wire harness clips off the valve cover. flip the cover over and squeeze them with needle nose pliers and they will pop out, giving you a little more space around the wires.
    and those stupid studs suck. i don't have the right socket to pull them, but if i did, i would relocate them to the front of the block. the two nuts will thread onto the other bolts for safe keeping.
    o'reilly has the wrong part # for the PCV. forgot to order one when i ordered the gaskets from camel toyota
    not having a drive able truck sucks. even after it gets back together, it says wait 24 hours for the rtv to fully cure before returning to service
    the inner gasket was baked hard... the outer was still very pliable but obviously worn. this worries me about any o ring or seal.
    i also put some paper towels in the throttle body to make sure nothing falls in.
    that is all for now.
    MY50cal, ecoterragaia and Pervy like this.
  15. Feb 15, 2018 at 7:21 PM
    Pervy
    Pervy Well-Known Member
    East Texas
    2.4 Tacoma, 3.4 4Runners
    Keep up the good work, haha may be doing the same down the road and will definitely be a asset having your hard work on display.
  16. Feb 16, 2018 at 7:10 AM
    81shark
    Cover is back on and hand tightned. In an hour it will be torque time
    Jckdnls and Pervy like this.
  17. Feb 16, 2018 at 7:38 AM
    81shark
    i may or may not have showered the cover. i may have missed a spot around a couple of the bolt holes.
    the gaskets sit in the valve cover gasket chanels nicely. was worried they would fall out of the gasket channel, but no worries.
    i put the cover on before adding the sealant at the front. with all the wires disconnected and the loom holders off of the cover, there is enough space to lift the front of the cover up a couple of inches for sealant application. i thought it would be better than putting sealant on and trying to get everything in place.
    80in pounds is for the torque of all the valve cover bolts.
    all buttoned up.. now we wait until tomorrow to test it. hopefully i didn't fuck up too bad.
    if you have to do it, it's not a bad job. it took me two hours to strip and clean and maybe another two hours to put it all back together, although an hour of that was waiting on the sealant to set up before torquing
    the pcv valve should be fun to change with the cover back on. defiantly make sure you get the correct one before you start.
  18. Feb 17, 2018 at 3:40 PM
    81shark
    Happy to report after a couole of shake down runs she is leak free. Not a bad job if you need one and want to save a few bucks. I should call the dealer for a quote to make myself feel richer.
    Picked up some 1/4 in tools in the process. Always fun to add tools to the tool box.
    Markcal and Pervy like this.
  19. Feb 17, 2018 at 4:44 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    It's a triple threat - feeling of accomplishment - save $$ - buy tools. Hard 2 beat that.
    BassAckwards, Markcal and 81shark like this.
  20. Feb 26, 2018 at 5:55 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Just did my Pcv hoping it’s my leak but pretty doubtful. Have the gasket just waiting on time and temps. Pcv took 30 mins 1/8 turn at a time fine threads and plastic, new one went on quick at least. What mileage you at. Valve train looks pretty free of build up. What are you running for oil?
    Hope mine is that clean when I open mine up.
