Want to repaint my side mirrors
Discussion in 'Detailing' started by 07TacoRidah, Nov 29, 2010.
  1. Nov 29, 2010 at 1:16 PM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    Want to repaint my side mirrors since they are fading some, I am going to paint them flat black but not sure what to use to keep the paint from chipping off (read somewhere you can use paint sealant but not sure what kind exactly, searched Google and found one that was better than car wax).
  2. Nov 29, 2010 at 2:46 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Do you plan on painting them yourself? If so, you can buy just a flat-black rattle-can and it'll do the trick. It won't provide the best protection from stone chips, etc... But the stuff is cheap, and re-paints won't break the bank.
    If you want better protection, you can have a shop paint them flat-black, and apply a matte clear. Matte clear will provide the protection of conventional clear, but with a matte finish. This route will, of course cost more $$$ than the rattle-can method! :)
  3. Nov 29, 2010 at 3:07 PM
    07TacoRidah
    I wanted to do them myself, I noticed a lot of my outside flat black is starting to fade nasty. is there a matte clear for a diy person like in a can? I have seen someone do the flat look but with a blue and then he said he put on some sealant, problem is he didn't list what he used. :(
  4. Nov 29, 2010 at 3:08 PM
    07TacoRidah
  5. Nov 30, 2010 at 1:47 PM
    Dadic 78
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    NP. Good luck with it. FYI, you might want to try your local autobody supply store, you never know, they may have another option for you if you're looking for matte-clear in a rattle-can.
  6. Nov 30, 2010 at 2:09 PM
    07TacoRidah
    if only I knew where one of those were here. :( it's more mainstream where I am at, hell people are barely hearing about OReily's. I think it's Craigen here, but still. :mad::( good lookin out though man :tup:
  7. Nov 30, 2010 at 2:27 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    You should use Diplicolor trim paint. It comes in a green can. It can be purchased at most auto parts stores.
  8. Nov 30, 2010 at 2:50 PM
    pinktaco808
    pinktaco808 Hot Steppa
    use a turbo torch on the part over and over and not hold in one place for a long time
  9. Nov 30, 2010 at 3:33 PM
    07TacoRidah
    is this one better than the one in the link I posted? Never tried either so I'm just going but company names.
    plz explain the process. also will this do a number on the paint overall (when done, AND IF done right)?
  10. Nov 30, 2010 at 7:24 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If they are not painted, just the plastic black, use 303 aerospace. It always brings my trim and mirrors back to black.
    Or spray on plastidip.
  11. Nov 30, 2010 at 9:35 PM
    pinktaco808
  12. Dec 5, 2010 at 10:35 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
  13. Dec 8, 2010 at 8:48 PM
    teamplayer
    teamplayer Active Member
    mario
    florida
    tacoma trd sport
    rims,painted parts,train horn for all those pleople texting with their phones,hid,painted engine cover,k&n air filter,leds floor lights.
    :)make sure you use some plastic promoter before spraying the flat black or the trim paint will work better for the mirror it will help a lot for chips dude, and make sure you wash and remove all the dirt and grease before you start spraying , so you don't get fish eye on your paint surface, good luck buddy. and make sure you tape up your truck good because spray paint can get very nasty over spray when is windy .
