want to replace diff fill/drain plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by BlackSportD, May 19, 2014.
  1. May 19, 2014 at 1:23 PM
    BlackSportD
    BlackSportD [OP] Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Got a question, are the front, rear and transfer case fill/drain plugs all the same thread and pitch? Figure if they are, I'd get three new magnetic plugs, non-mags for the fill, as my OEs are done.
    There are some aftermarket ones of various sizes, but found a youtube vid where the OEM Toyota low profile is used (so rocks cannot be the cause of torquing one loose)- I believe our transfer case already uses this one. It works on trucks up to 94, hoping its the same for mine (2001).
    Low Profile Magnetic drain plug: 90341-18021
    Steel Differential Gasket for Axle housings: 12157-10010
    Transfer case gasket (aluminum washer): 90430-18008
  2. May 20, 2014 at 9:59 AM
    1stevertaco
    1stevertaco Well-Known Member
    atlanta
    2000 taco 4x4
    sway bar end links
    Yes I believe they are all the same. The YouTube video, also hints at the fact that other Toyota cars trannies use the same full/drain plugs.
    Good to see a part number for the drain plug gasket.
    Anyone know the size of the gasket? I'm always at the local parts store looking for the copper gasket, the guy behind the counter can never help.
