Want to run 33x12.5x17-Lift suggestions
Discussion in 'Suspension' started by 08RedYota, Mar 15, 2011.
  1. Mar 15, 2011 at 6:59 PM
    08RedYota
    08RedYota [OP] Member
    Pennsylvania
    08 Tacoma TRD Sport
    Hey guys, Been wanting to put a lift on my 08 dbl cab, wanna run a 2.5-3" lift. I do some offroading nothing extreme though, want to keep a smoother ride, and a buddy just gave me some new mickey thompson's 33x12.5x17, can I run these with a 2.5-3" lift, and what is everyones suggestion on the lift for what I need? Thanks I'm a Noob lol
  2. Mar 15, 2011 at 7:13 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    how much are you willing to spend?
  3. Mar 15, 2011 at 9:26 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    That's a true 33" tire. You will need 3" or more to not rub to seriously. You will also need wheels with the correct backspacing or wheel spacers with factory wheels. Maybe look into a spindle lift if you are a 4x2.
  4. Mar 15, 2011 at 9:59 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You'll need to trim a lot of fender well plastic and chop your cab mount, but several members on here have fit that size on a 3" lift.
  5. Mar 15, 2011 at 11:46 PM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    Get the basic PRocomp or Fabtech 6" lift kits. They will keep your stock ride.
    Anything else will make your truck ride stiffer.
    Also for those size tires unless you want to trim most of your fenders and cut your cab mounts? A 3" lift won't work.
  6. Mar 16, 2011 at 12:26 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    RCD 4.5" and not worry about it
  7. Mar 16, 2011 at 4:48 AM
    08RedYota
    Pennsylvania
    08 Tacoma TRD Sport
    Willing to spend somewhere between 500-800, don't want to do any major cutting, solus what is the RCD lift is that what you are running? Do you run 33's? Toku is the procomp basic adjustible? I do not want 6", want to stay arnd 3-4" lift, what if I ran 33x12.5x16's, 3" work?
  8. Mar 16, 2011 at 5:03 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    a 33x12.5 is the same whether on 16 or 17" rim. only difference is the hole the rim goes into.
    3" lift w/ flare trimming, body mount chop, and 4.5" BS wheels or spacers, like the others said.
    the RCD 4.5" lift is a drop bracket lift like the 6", just smaller.
  9. Mar 16, 2011 at 5:24 AM
    08RedYota
    Pennsylvania
    08 Tacoma TRD Sport
    Yea realized what I said afterwards lol, pretty much not gonna be able to run these unless I get a 6" lift and drop it down?
  10. Mar 16, 2011 at 5:28 AM
    jhodge83
    SC
    the pro comp/fabtech basics are not adjustable. I'm running a 35x12.5 on a 3" lift, you just have to man up and do some cutting. if you have a 2WD, you can get a 4" spindle lift. that would be the way to go if you can.
  11. Mar 16, 2011 at 5:31 AM
    08RedYota
    Pennsylvania
    08 Tacoma TRD Sport
    If I put a 6" lift on what other issues am I gonna run into, am I gonna run into, such as drive shaft etc?
  12. Mar 16, 2011 at 6:11 AM
    08RedYota
    Pennsylvania
    08 Tacoma TRD Sport
    I have a 6 speed, 5ft bed, 4x4 so spindle lifts out
  13. Mar 16, 2011 at 8:37 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    6" lifts are gonna break your 500-800 dollar budget. Think more like 2k
  14. Mar 16, 2011 at 8:40 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    OME + cutting and trimming.
  15. Mar 16, 2011 at 9:23 AM
    lembowski
    Rolando, CA
    Jeeper Creeper
    Best bet is to just sell those tires and get some 285's.
  16. Mar 16, 2011 at 9:26 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    If you got a PreRunner, you could get lift spindles. If you got a 4x4, x2 on Solus694 suggestion on going with the RCD 4.5
  17. Mar 16, 2011 at 9:32 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Come on just a little trimming to fit those tires I have 33x12.5's on my 1st Gen and I just had to trim a little. and if you think trimming for the 3" is to much try cutting off the cross member for the 6" or 4.5" lift. With miner modifications those tires will fit on a 3" no problem.
  18. Mar 16, 2011 at 9:34 AM
    malander
    max
    01 limited trd 4x4
    A little off topic but what backspacing here your wheels? I know the offset was ridiculous but I've been thinking of getting some 15s in the fall
  19. Mar 16, 2011 at 9:35 AM
    JLee
    Jerry
    Bay Area NorCal
    15x10" 3.76" BS and a -44mm Off Set if they made 9" rims in these that's what I would of got.
