Want to try new setup on my tacoma
Discussion in 'New Members' started by marco1028, May 23, 2020.
will the tire fit without doing anything?
  1. Yes
    100.0%
  2. No, needs spacers
    0 vote(s)
    0.0%
  1. May 23, 2020 at 6:54 AM
    marco1028
    marco1028 [OP] New Member
    Marco
    2006 pre-runner Tacoma 2 inch body lift
    at the moment I have 285/75/16 tires on my truck and I want to put 285/60/20 tires with rims at -25 offset. But I'm already about an inch away from the control arm do y'all think I'll need spacers or not?
    det107 and buckhuntin-tacoma like this.
  2. May 23, 2020 at 7:00 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
  3. May 23, 2020 at 7:00 AM
    FishnTx
    South East Texas
    ‘17 OR
  4. May 23, 2020 at 7:02 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Welcome!
    det107, Black DOG Lila and Biscuits like this.
  5. May 23, 2020 at 7:55 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
    det107 likes this.
  6. May 23, 2020 at 8:06 AM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    That and a CMC and pinch weld mod and wheel well trimming and some fender trimming IF you haven't already. What's the back spacing on those 20's?
    det107 likes this.
  7. May 23, 2020 at 8:18 AM
    det107
    det107 Well-Known Member
    Welcome to TW!!
    Slick Taco has the right answer!
  8. May 23, 2020 at 8:28 AM
    marco1028
    Marco
    Right now I have a higher backspace and a positive offset,but my plan is to lessen the backspace and get a negative offset to allow the tir to fit.
  9. May 23, 2020 at 8:52 AM
    Slick Taco
    Either way you're probably going to have some serious rubbing with a -25 offset. Sure you may clear the UCA but you're most likely going to have contact with the wheel well and cab mount when you turn your wheels past a certain degree. An let's not forget to factor in necessary clearance for up travel.
    Maybe your local tire shop can set you up with a couple to throw on while you're there and check fitment. Also keep in mind up travel clearance while your wheels are turned.
    I'd skip the spacers...you're already going to be pushed out far enough with a -25 offset. Adding spacers will also mean more chopping. But hey..to each their own I guess. Chop away my friend
  10. May 23, 2020 at 2:55 PM
    marco1028
    Marco
    Alright thanks for the info
  11. May 24, 2020 at 1:40 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  12. May 27, 2020 at 2:13 PM
    12020rixtactoy
    12020rixtactoy Member
    Rick
    South Eastern VA
    20 Tacoma TRD OR
    2 bullet holes (reckless shooters on wma)
    Welcome from SE VA! good luck w/ the 20s and -25 offset...curious, what type of suspension set up are you running.....please post up some pics when you get it put together. Enjoy!
    you can go here to enter your current set up and compare to your planned set up
