want to up grade from rev tec coil spacer kit
Discussion in 'Suspension' started by bigcuzauto, Jul 30, 2012.
  1. Jul 30, 2012 at 5:19 PM
    bigcuzauto
    bigcuzauto [OP] Active Member
    Louisiana
    2006 tacoma trd
    3 in coil spacer lift 285/75/16 buckshots dent in the rear
    2006 taco with 3 in coil spacer kit from rev tec running 285/75/16 maxxis mudders on stock wheels
    I am ready for a change want to go 6 inches no body lift any ideas? I have a set of 34.5 in swampers on 16 in wheels I would like to use but seems like most of the 6 in kits I look at require 17 in wheels or larger.
    Shoot me some ideas or tell me what you are running
  2. Jul 31, 2012 at 12:24 AM
    bigcuzauto
    Louisiana
    2006 tacoma trd
  3. Jul 31, 2012 at 6:02 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Pro Comp and Fabtech will get you 6" and RCD will be 4" but all drop bracket requires cutting the xmember if you is a 4wd.
