Want to upgrade to fox 2.5 remote resi's
Discussion in 'Suspension' started by tony92629, Jul 1, 2011.
  1. Jul 1, 2011 at 12:15 AM
    tony92629
    tony92629 [OP] Well-Known Member
    Tony
    Dana Point
    2010 White Tacoma Prerunner
    5100's all the way around. Front set at .85. Camburg Spindles. Camburg Uniball 1.25 UCA's. Total Chaos LCA skid plates. Custom Deaver 10 pack rear leaf spring. BFG AT KO's 285/70/17, Weathertech floor liners, Wet Okoles. Midland CB/PA, Firestick.
    I have been looking to upgrade my front coil overs. Right now I am currently running 5100's set at .85 with Camburg 1.25 Uniball Upper Control Arms with Camburg 4" spindles...with stock Lower Control Arms. Also, someone mentioned there is a difference in length in the shock. I am looking to keep mt stock fenders. (All advice and suggestions welcome).
    Running 5100's in the rear with a 3" Deaver 10 pack leaf spring.
    I am looking to purchase a set of Fox 2.5 coil overs with remote reservoirs. I live in orange county, Ca. Does anyone know where I can get a set of these in OC and how much they go for? (installed).
    Thanks.
  2. Jul 1, 2011 at 8:15 AM
    Pakow
    Pakow Well-Known Member
    Bay Area, CA
    Tacoma TRD Sport 4x4
    I just picked up a set from downsouth motorsports with UCAs and rear 2.0s for a great price. They are custom valving them for my setup too.
    Give them a call.
  3. Jul 1, 2011 at 9:25 AM
    tony92629
    Tony
    Dana Point
    They quoted $1260.00 for a set and they have them in stock. That sounds like a great price.
  4. Jul 7, 2011 at 9:25 AM
    PineappleGrenade
    PineappleGrenade Well-Known Member
    Zach
    Ohio
    '13 Honda Accord Sport
    Any complants with the 5100's in the front? I plan to either get the 5100 or keep my stock shocks when I get my Camburg Spindles. Also what made you go with the upper control arms with the spindles?....I heard it was okay to use the OEM ones????????
  5. Jul 7, 2011 at 9:26 AM
    PineappleGrenade
    Zach
    Ohio
    Also, what tire size are you using in the photo above?
  6. Jul 7, 2011 at 10:57 PM
    tony92629
    Tony
    Dana Point
    No complaints at all with the 5100's - the only thing is that you have to take the shock off and compress it in order to change the settings. Sorta of a hassle if you dont have the tools, time and know how..or $240.00 for someone else to do it. Its just not that easy..IMO. I want to be able to change the settings and looking for a little upgrade with the Fox 2.5 coilovers with remote reservoirs.
    My front 5100's are set at .85. With the spindles and Camburg UCA. I actually have pretty good travel with the 5100's and the stock coils - The coils have actually worked in very nicely and the ride is super smooth.
    Yes, you can use the stock UCA with the spindles. If you go with a 2.5 coil over, you will have to go with a different UCA - TC or Camburg or something of the sort.
    Just need extended break lines and will have to remove the dust cover off the rotors.breaks...no biggy.
  7. Jul 7, 2011 at 10:58 PM
    tony92629
    Tony
    Dana Point
    285/70/17 BFG AT KO's
  8. Jul 8, 2011 at 7:51 AM
    PineappleGrenade
    Zach
    Ohio
    any rubbing issues?
  9. Jul 8, 2011 at 8:43 AM
    tony92629
    Tony
    Dana Point
    Zero.
  10. Nov 17, 2011 at 8:37 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Extend the brake lines up front? I didn't have to. :confused:
    I have Fox 2.5 resi - I bought them from a very well know company here but I wouldn't do that again, I would go to Down South Motor Sports. That way you can have them valved and sprung specifically for your application and not the company's FJ!!!
    I bought mine from a different company but Sonny tweaked the valving to my specific needs and I swear, compared to what I got from that other company to what I have now I feel like I have triple bypasses! :)
  11. Nov 17, 2011 at 5:38 PM
    Large
    Large Red
    Are you running wheel spacers?
