Wanted 6 inch lift kit-2008 taco
Discussion in 'Buy / Sell / Trade' started by toyotadude5, Nov 7, 2009.
  1. Nov 7, 2009 at 1:37 AM
    toyotadude5
    toyotadude5 [OP] Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    im looking for some parts or full kit for 1 2008 taco 4x4 v6.
    im looking to lift it 6 inches but dont have the funds for a brand new setup.
    thanks, chris:)
  2. Nov 7, 2009 at 1:16 PM
    toyotadude5
    chris
    Flagstaff, az
    bumpbump
  3. Nov 7, 2009 at 1:22 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Probably not going to happen by pieces/parts bro....The parts that come with a 6 inch lift pretty much all get used for the install.
    It'll suck- but start saving and wait for the right time...Get new, matching parts and get it installed the right way the first time. Best of luck!!
  4. Nov 7, 2009 at 2:04 PM
    toyotadude5
    chris
    Flagstaff, az
    haha ya figured that. figured worth a shot. If anyone has a full kit ready to sell ill take it haha
  5. Nov 7, 2009 at 2:42 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    That usually doesn't happen. You can find used coilover shocks, or spindles (if 2wd) but a full fagtech 6" or Prolame 6" usually comes all together from the manufacturer new
  6. Nov 7, 2009 at 4:09 PM
    toyotadude5
    chris
    Flagstaff, az
    well since u obviously dont like fabtech or procomp, what other suggestion to get full 6 inch lift?
  7. Nov 7, 2009 at 6:19 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    Good question. My suggestion to you my friend if you want to lift your truck would be Camburg or total chaos uniball upper control arms (600-700 dollars) and a nice coilover set (sway a way, Icon, king, about 900-1200) that provides 3" lift. You get what you pay for when lifting the truck. C/O's make a massive difference in performance when on and off road.
    Another option is Toytec. They offer a 3" lift. Bilstein 5100 shocks w/ eibach springs. add a leaf for the rear plus bilstein 5100 rear shocks.
    If you were to go with a drop bracket kit I suggest the RCD 4" lift. Only good thing about drop bracket kit is it reduces the stress on the CV joints on a 4x4. RCD makes a better quality kit than fabtech and pro comp.
    If you go with a 6" lift you'll end up most likely running 35" tires which put a ton of strain on the brakes, steering, throws alignment off easily and suck's your gas and power like a mother. 3-4" lift makes the most sense with 33's... and the best performance off road and on.
    My 2 cents.
  8. Nov 7, 2009 at 6:28 PM
    toyotadude5
    chris
    Flagstaff, az
    no if i do go with the 6 inch i will only be going 33 inch tires. but i may look into the 4 inch. Thanks for the info
