Wanted Blower Fan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 02809bristol, Mar 17, 2015.
  1. Mar 17, 2015 at 5:01 PM
    02809bristol
    02809bristol [OP] Member
    Hello looking for fan blade only for my blower fan.
    The other day dash had a strong vibration ! I removed blower fan and found fan blade is cracked causing vibration
    Really don't want to spend $$$$ on entire unit.dealer won't cover , out of warranty
    2012 double cab
  2. Mar 17, 2015 at 5:19 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    I have an entire unit you can have.
    It's from an 09 that squeaked and I replaced.
  3. Mar 17, 2015 at 9:06 PM
    02809bristol
    Just need white fan itself , where are you located?
  4. Mar 18, 2015 at 4:58 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    If you're replacing the fan, that would be a good time to clean the motor as well and lube it up as they tend to make a lot of noise. There is a good post somewhere up here with a good write up on how to do it.
