Wanted COA tophats etc
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by AlanLoshbaugh, Apr 16, 2013.
  1. Apr 16, 2013 at 6:20 AM
    AlanLoshbaugh
    AlanLoshbaugh [OP] Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
    I have a liftkit to install on my 2005 4x4.
    I'd like to build the new COA's on the bench to expedite the process.
    I need an extra set of top hats and hardware;
    if anyone has this stuff, please let me know?
    thx;
    alanloshbaugh@gmail.com
  2. Apr 16, 2013 at 12:06 PM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    Bilstein 5100's with OME 885 X,top plate spacers,taco lean spacer,All Pro Expo's in the rear,installed fog lights,installed intermitent wipers,IPF off road lights,ARE topper with 5 ft. Hi-Lift Jack,first aid kit, fire extinguisher installed inside,Sway a Way front sway bar,Westin Brush Guard,air box mod,Mag Lite Mod,Relentless CB ant. Mount, DX 959 Galaxy CB,Go Rhino nerf bars,Duratrac 235-85-16's on TRD OR wheels,
    http://www.ebay.com/itm/MONROE-9079...Parts_Accessories&hash=item5aec3e0cbb&vxp=mtr
    I tried to find a set for a while, and ended up buying these. This is the correct Monroe part number, and by searching I found them as low as 16.00 each shipped, but now can't remember where. I believe it was Amazon.com They are a good quality. If you are going to use extended studs for any type of spacer plate with these, the studs I purchased from Wheelers did not fit correctly. They are for stock top plates, and it wasn't a big deal to tack weld the studs in place to hold them secure. I also used the Wheelers coil spring isolator,and it fit these perfect and was a nice quality product. Just a heads up if you can't find a stock used set,at least you have a back up plan.
  3. Apr 16, 2013 at 12:09 PM
    AlanLoshbaugh
    Alan
    Columbia, MO
    OME sell a kit. It's $165 or so.
    This seems better; thanks!
  4. Apr 16, 2013 at 12:19 PM
    eAreEyeSee
    eAreEyeSee Well-Known Member
    Eric
    Aurora CO
    2010 DCSB TRD Off-Road
    Blah Blah Blah. Like your FF team, nobody cares!
  5. Apr 16, 2013 at 12:21 PM
    Brunes
    Brunes abides.
    Rotorhead
    Rock Auto has them too-Little more than parts geek.
  6. Apr 16, 2013 at 12:24 PM
    AlanLoshbaugh
    Alan
    Columbia, MO
    thanks for the links!
    I'm a Land Cruiser guy, and used to leaf springs.
    I think the Monroe bits listed are short a bushing (or two?) and the shock damper rod hardware...yes?
  7. Apr 16, 2013 at 1:27 PM
    Brunes
    Brunes abides.
    Rotorhead
    I ordered a kit form Rock auto-Think it was about 30 bucks total maybe and had the isolators and everything.
  8. Apr 16, 2013 at 2:09 PM
    AlanLoshbaugh
    Alan
    Columbia, MO
    rock auto shows the same monroe kit; isolators and damping rod stuff not pictured, but maybe included....
  9. Apr 16, 2013 at 5:44 PM
    Skunkman
    Syracuse - Tug Hill
  10. Apr 16, 2013 at 7:11 PM
    Brunes
    Brunes abides.
    Rotorhead
    Rockauto photos do leave something to be desired but here is what I got:
    ImageUploadedByTapatalk1366164525.251692.jpg top hat w/ studs and coil isolator, top and bottom washers, top shock isolator and the bottom shock isolator is part of the top hat.
    There is a 5% rockauto code in the deals and coupons section that is good for a few more days I think...
