Wanted: OEM Seal for Wheel Flare
Discussion in '1st Gen. Tacomas (1995-2004)' started by thombiz, Nov 21, 2010.
  1. Nov 21, 2010 at 8:11 AM
    thombiz
    thombiz [OP] Active Member
    Corpus Christi
    01 Prerunner & '02 Tundra
    I purchased an '01 Doublecab recently and it is missing the vinyl seal which goes between the right front fender and the wheel well flare. I'm a bit concerned that the flare could rub against and thru the paint. Anyone have a seal from a take-off or a damaged flare they'd like to sell?
  2. Nov 21, 2010 at 10:15 PM
    JDBECK23
    JDBECK23 Well-Known Member
    Jesse
    King George, Va
    '01 Tacoma Reg Cab 4 cyl 4x4
    You can buy one from toyotapartszone for 11 bucks... but the shipping will be expensive..
    I would suggest checking the dealer price as well. The 01 I recently bought had 2 out of 4 falling off, so I just replaced them all after hitting the fender flares with some paint.
    Here's a link.
    http://www.toyotapartszone.com/Page_Product/PartDetail.aspx?model=TACOMA&year=2001&catalogCode=674460&VAID=2514,2515,2516&selectConditions=(1=3RZFE;5=MTM;8=RCB)&subModel=NAP-4%20WHEEL%20DRIVE&originCountry=(12=USA)&sectionID=3&componentsID=75-52&componentsIndex=41&isBigPicture=False&pictureName=750809
    It's the top part listed, 53851G the front two are the same, the rears are different part numbers. They come with adhesive from the factory.
  3. Nov 22, 2010 at 6:34 AM
    thombiz
    Corpus Christi
    Thanks for the link. I don't mind paying for them and tried several "Toyota Parts websites" on the internet, coming up empty. I'm just glad to be able to find them. I really appreciate the help. Bob T.
    Edit: I just placed the order for the seal. Thank you again!
  4. Nov 22, 2010 at 8:42 AM
    JDBECK23
    Jesse
    King George, Va
    No problem. After replacing all 4 of mine, I noticed that there were two kinds of adhesives that the factory put on them. If the one you get has a yellowish color protective strip, you should be fine. One of mine had a red protective strip over the adhesive and that one didnt stay on for 5 seconds! I had to use 3m Weatherstrip adhesive to get it to stick... and now that sucker is ON THERE!
    Glad I could help!
  5. Nov 23, 2010 at 3:33 PM
    SixtyDashOne
    SixtyDashOne Well-Known Member
    Collegeville, PA
    2021 ArmyGreen TRD Sport, 2007 Regular Cab 4x4
    nice, i needed these as well!
