Wanted t56 swap kit
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Smittyxr1984, Apr 14, 2023.
  1. Apr 14, 2023 at 8:35 AM
    Smittyxr1984
    Smittyxr1984 [OP] Well-Known Member
    2007 XR
    Urd has been out of stock for monthes and desperate need the t56 swap stuff for my xrunner TURBO build. Built motor in process all turbo setup already done and running
    jjgandarillas likes this.
  2. May 12, 2023 at 8:15 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There is a thread on here with a guy selling his kit. Been a long time since I have seen that thread though.
  3. May 12, 2023 at 9:32 AM
    Smittyxr1984
    2007 XR
    I landed a new bellhousing and used apr crossmember from Gadget need to figure out what I need for the rest of it besides the speedo box. What clutch are my options? Want to do it once like a southbend twin disc or the like
  4. May 12, 2023 at 10:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    For the bell housing, I highly recommend installing heli-coil inserts into the bellhousing. On the side that mates to the transmission.
  5. May 12, 2023 at 10:56 AM
    Smittyxr1984
    2007 XR
    For what reason? It looks to be a well made piece from URD
  6. May 12, 2023 at 5:40 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The casting is porous. A few times of bolting and un-bolting, and the thread material will pull out. I recently did this to mine.
