Wanted To Buy 2002-2004 Tacoma VF1A Transfer Case
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by owl0990, Sep 9, 2025 at 7:45 PM.
  1. Sep 9, 2025 at 7:45 PM
    owl0990
    owl0990 [OP] Well-Known Member
    Looking to buy a 2002-2004 Tacoma transfer case to go behind a R150F 5-speed manual transmission with the 3.4L V6. Long input shaft. No neutral sensor. Shift lever. No electronic actuator. No ABS and No Diff Lock (so no 4 Lo sensor). Supports A.D.D (4wd sensor on t-case).
  2. Sep 9, 2025 at 8:51 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    If you want a J shift VF1A you need it from a 98-99 4runner and that's it.
    Good luck hunting.
  3. Sep 9, 2025 at 8:58 PM
    owl0990
    ok what was the chain drive case behind the 2000-2004 5 speed R150F transmission
    Long input shaft. No neutral sensor. J shift lever. No electronic actuator. No ABS and No Diff Lock (so no 4 Lo sensor). Supports A.D.D (4wd sensor on t-case).
  4. Sep 9, 2025 at 9:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah apologies, I was thinking of the VF3AM that you were looking for.
    Shouldn't be too hard to find your VF1A.
  5. Sep 9, 2025 at 9:15 PM
    owl0990
    So what is the Tacoma transfer case am I looking for
  6. Sep 9, 2025 at 9:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    A VF1A, but you want a Jshift rear shift case. Should be easy to source as same case was used in 4runners and even some tundras. Even if it comes with the sensors you don't want it's fine. Doesn't chance how it works just don't hook them up.
  7. Sep 10, 2025 at 12:13 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Just to note, you can run a “short shaft” case from behind an auto with the r150. The input shaft is about 5/8” shorter, but it works fine. Not many autos with a j-shift though, so may not matter.
    Regarding the sensors, all cases are set up for them and they can be added or deleted easily. So no need to find a case with every option you’ve listed.
  8. Sep 12, 2025 at 12:53 AM
    02hilux
    Planet: EARTH
    BTW, if all options are exhausted at sourcing the specific tcase, you can find yourself a j-pattern case from a 4cyl and swap the input from your defective case to the replacement. You don’t have to wait for a 23s case if you need one bad.
