Wanting 3" lift only have 3000$ what do i do?
Discussion in 'Suspension' started by j cody, Jul 22, 2011.
  1. Jul 22, 2011 at 9:07 PM
    j cody
    j cody [OP] Member
    Cody
    Tennessee
    2011 Tacoma TRD 4x4
    Yakima LoadWarrior (with extension) basket rack
    I have around 3000$ to 3500$ for a 3" lift and 33" AT tires. This truck is my daily driver so i do not want to kill the ride. What do i do?
  2. Jul 22, 2011 at 9:10 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    only $3000?...
    What are you looking for in a lift?
    Do you offroad a lot? What kind of offroad?
  3. Jul 22, 2011 at 9:12 PM
    DOT
    DOT Well-Known Member
    Jobin
    Littleton CO
    2007 FJ
    3'' toytec lift
    also are you installing the lift ?
  4. Jul 22, 2011 at 9:32 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    you can pick up the ultimate lift, ome dakar leafs, and some decent wheel/tire package and have some cash left over............was able to to do that in alaska and everything is inflated up here. and much cheaper with 5100's and AAL......................lots of info if you search. vendors on here should get you alittle discount also....
    BTW welcome to TW
  5. Jul 22, 2011 at 9:41 PM
    Treedawg37
    Treedawg37 Well-Known Member
    Barry
    Central, Alabama
    '11 Tacoma DC 4X4 SR5 SB,
    BHLM, tinted tails, weathertech mats & visors, sportsman"s camo seat covers, diff breather mod.
    you can go OME 3" with a dakar leaf pack for around $1200 and a good set of AT's round $1000 depending on weather or not you getting new wheels or using ones you have. you can get a good set up for what budget you have. and if you doing own install you shoul have enuff change to to UCA's also. jmo
  6. Jul 22, 2011 at 9:45 PM
    Conviction11
    Conviction11 Busting Asphalt
    J
    South Carolina
    I've got the 3" pro comp lift and it's perfect for me. A little stiff but it's not as bad as everyone makes it sound. I got it and had it professionally installed for around 700.00... that would leave you plenty of cash for tires and rims. I would recommend it.
  7. Jul 22, 2011 at 9:48 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Full OME lift with the Dakars , LR UCA's and your wheel / tire combo
    Done
  8. Jul 22, 2011 at 11:01 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    ^ what this guy said...
  9. Jul 22, 2011 at 11:23 PM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    $3500 will be enough to acheive what you need. U should look around the site at member rides to see what you like first, though.
  10. Jul 22, 2011 at 11:26 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver/Phoenix
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Toyo R/Ts, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    I have this lift and no complaints, but for your budget I would get something better.
  11. Jul 23, 2011 at 6:36 AM
    j cody
    j cody [OP] Member
    Cody
    Tennessee
    2011 Tacoma TRD 4x4
    im thinking OME with Dakars and UCAs. Thanks for the opinions. I would use the lift probably 85% on road and the rest off road on some easy trails we have in Tennessee. The installation i would do myself, i am great friends with the guys at the toyota dealership here so i can get it aligned and put together for fairly cheap.
