Wanting 33” Tire - TRD Pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MBCardsfan1982, Jul 24, 2025.
  1. Aug 10, 2025 at 7:32 PM
    #41
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Kind off curious. Compare 2 different size shows 10 % gain on the width, the rest is practically the same. Can 10% make a difference?
  2. Aug 10, 2025 at 8:17 PM
    #42
    Letstacobit
    Letstacobit Well-Known Member
    Orange County, CA
    2022 Off-Road
    Love my skinny (255/85r16, and I've run 285's on my gen 2 taco)...they work. Steering feels great, throttle response is barely affected, less stress on the spindles/tie rods etc.
    Been adding supporting mods, and my next set will be skinny 35's (35x10.5r17). These trucks lack torque/HP in the power band most drive in/wheeling(tuning helps a lot if you have 4.10's to start with). However, adding unnecessary rotational weight only compounds the problem.
    Especially for K03's....there are so many tire brands/options out there that have left these in the dust....I've run lots of tires and it'll be a cold day before I run those again (worst wet traction/sand/rock tire I've ever run).
  3. Aug 10, 2025 at 8:22 PM
    #43
    Vlady
    Issy, WA
    Thats is exactly my Russian roors told me.. not worth it for me
    265 even closer to 285's
  4. Aug 10, 2025 at 8:24 PM
    #44
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Agreed - E will be a harsh ride. C is mucho better. But good luck finding a C in that height. Maybe Nitto?
  5. Aug 10, 2025 at 8:44 PM
    #45
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    I don't know that's why I would like to run the experiment to find out how they truly run side by side. Same model tire and run it for a year after being on a 285/295 for the past 3 years. I'm just relaying the feedback I have gotten from the only local guy I know that has tried them.
  6. Aug 10, 2025 at 8:54 PM
    #46
    Vlady
    Issy, WA
    I see...
    I went from 245 to 265(about the same as go from 255 to 285) and I dont see any "improvements" . I delayed that the expirement by 3 years. I did gain 20 mm in width and some sidewall, but I lost tons in the performance...
    I've ran tune tunes for 7 years. I do see how the we miniscule width gain can improve the the performance
  7. Aug 10, 2025 at 9:02 PM
    #47
    Veet-88
    I changed from 265/70r17 to 285/70r17 and on road there are 100% cons but off road i have seen nothing but gains in performance. But how much of that was in the width or height or a combination of the height and width. Would the 255 offer the same feeling of confidence and have the same traction increase i won't know or have a real opinion until it's tried.
    Also I upped tire size with the same model so it was a great side by side comparison.
  8. Aug 10, 2025 at 9:08 PM
    #48
    Vlady
    Issy, WA
    Dude, look the stat. I dont see how you can "gain" if the stas show no improvements. I'll be a stallion i the bedroom .....with those stats.
    Typical lab experiment errors are 5+ %
  9. Aug 10, 2025 at 9:15 PM
    #49
    Veet-88
    Don't know what to tell ya but that is the perception hence why I want to try the other one to see. I have ran the same trails with a 265 and a 285 and there was a notable difference. That's why I'm saying all of these "stats" only go so far.
  10. Aug 10, 2025 at 9:20 PM
    #50
    Vlady
    Issy, WA
    That is the issue with TW. Bunch of bs for nothing. He said.. she said
    majpooper likes this.
  11. Aug 10, 2025 at 9:33 PM
    #51
    Vlady
    Issy, WA
    We are driving the same truck. You have a better stereo though. Are you in BC? I drove BC on 245 and 265. Paid the difference at the gas pumps for the same road...
  12. Aug 10, 2025 at 9:47 PM
    #52
    Veet-88
    AB, like I said there are 100% on road cons with the increased rolling resistance and weight.
  13. Aug 10, 2025 at 9:57 PM
    #53
    Vlady
    Issy, WA
    I've been to Banff and around. Your misconception about US based folks is the speed limit the mountains. This where you feel the burden of heavy tires
  14. Aug 10, 2025 at 10:06 PM
    #54
    Veet-88
    I'm not sure what point your trying to make here iv already stated you feel the effects and cons of the larger tires on road. It doesn't matter where you are geographically a heavy high rolling resistance tire will never do you any favour's on road.
  15. Aug 10, 2025 at 10:13 PM
    #55
    Vlady
    Issy, WA
    The point I'm making it that 10% increase in the tire width is laughable
  16. Aug 10, 2025 at 10:33 PM
    #56
    Veet-88
    But you just stated that you paid the price at the pump for the exact same increase ratio? Would that not mean that a 10% increase is not laughable as it had a direct effect on what you experienced. Be it your decreased fuel economy be it an increase in trail performance in mine aswell as a loss in fuel economy.
    10% is 10% just like change is change. Bolt of a 5lb heavier tire and tell me you don't feel it this is why the only opinions of anyone on here that are worth a half a damn are those that have actually run both sizes and all I am saying here is I would like to actually run it myself and feel for a difference.
  17. Aug 10, 2025 at 10:54 PM
    #57
    Vlady
    Issy, WA
    Yeah. I've mentioned on numerous threads going with a bigger and slightly heavier tire on daily driver.
    I just do see how you can increase trail performance by less than 1 inch. ...like your friend
  18. Aug 11, 2025 at 2:31 AM
    #58
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Nitto and Toyo would be a great tire in SL ratings. I run the Toyo 285s in SL. No issues. no power loss and I'm tuned, and speedometer is calibrated.
    Brex69[QUOTED] likes this.
  19. Aug 11, 2025 at 10:22 AM
    #59
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Yep - TW = "what I did to my truck is best"
    The truth is it's personal preference and how you use your truck and what you are trying to accomplish with your build. How the OP uses his truck and how I use mine are completely different. I try to go off road as much as I can - a few times a month - and I do things off road that push my limits which means sometimes traversing sharp rocks and I definitely do not want to limit travel so I would never not run anything but E rated tires and I removed the sway bar up front (check out Tinker's Adventure on that one) but the OP would not be wise to do that with his use case. The purpose of my truck is to have fun off road - period. The purpose of the OP's truck is much different.
    https://www.youtube.com/watch?v=gcgKbUTQJy8
    Veet-88 likes this.
  20. Aug 11, 2025 at 11:47 AM
    #60
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    This thread was started (and mostly discussed) about 16" wheels 285/75/16.. which are practically all e-rated. You're talking about 17" wheels at 285/70.... totally apples to oranges when it comes to a performance hit on the Tacoma. 17" tires have more options with lower weights than a true 33" on 16" wheels.
