Wanting lift opinions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by InfernoTaco19, Jan 2, 2021.
  1. Jan 2, 2021 at 12:03 PM
    InfernoTaco19
    InfernoTaco19 [OP] Member
    2017 Inferno Tacoma 4x4 TRD Off Road
    Hey y’all, used to be on the site a while ago with my old 2nd gen, and now that I’ve got my 3rd I’m ready to be back. I’ve got a 2017 4x4 Inferno trd off road, had it since 0 miles. It’s now got 62k and I’m actually using the off road for my deer lease. At the moment, I’m looking to do the bilstein 6112 set up in the front with the 5160 in the rear, Deaver add a leaf, KYB top hats, camburg UCAs, and that’s about as far as I’ve gotten. My question is, with TRD pro wheels and an upgrade to 285/75-16 tires, think I’ll have any rubbing? Or is that set up enough to clear everything. Thanks in advance for any input, and I hope to be on here a lot more in the future.
  2. Jan 2, 2021 at 12:12 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Welcome. You will rub. Be prepared to cut/trim and possibly a cab mount chop. Remember your lift does not help when your suspension compresses during normal operation.
    Or, you could be like some other dweebs and not care that you rub at full lock.
    Chew, 71tattooguy and jeremy5000 like this.
  3. Jan 2, 2021 at 12:13 PM
    InfernoTaco19
    So, In your opinion, if I did that setup, is there anything you can do to prevent rub without doing the chop?
  4. Jan 2, 2021 at 12:22 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    See, it might not rub but probably it will. What people don't realize is these trucks are a tiny bit different because of normal stack up tolerances during assembly and caster settings being different.
    So, you can do two things... get the right backspace that will put the tire as far under the fender as possible... or adjust caster forward.
    You will probably still cut.
