Wanting to buy my first AR15
Discussion in 'Guns & Hunting' started by CNEDEER, Jun 30, 2012.
  1. Jul 1, 2012 at 8:13 PM
    CNEDEER
    CNEDEER [OP] If ya ain't first, your last!
    2015 DC TRD OR 4x4
    I've been doing some searching on the Spikes Tactical website and they have an enormous amount of options. I was looking at uppers and they ranged from 7.5" to 16" . I take it that is the length of the barrel? This is going to be a long learning experience
  2. Jul 1, 2012 at 8:17 PM
    762NateOh
    762NateOh Well-Known Member
    Nate
    Tucson, AZ
    04 Prerunner SR5
    I'd look at spikes - I believe someone else mentioned them too.
    A good mix of quality, without getting over the top price wise.
    http://www.spikestactical.com/new/z/st15-16-midlength-le-carbine-p-443.html
    That would be a great starter rifle (or...a great leave it alone and shoot it rifle too).
    Truthfully, the AR15 platform isn't rocket surgery. There are very few 'bad' rifles out there among the dozens of manufacturers.
  3. Jul 1, 2012 at 8:19 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Not saying I spent 3 grand on everything.... But I spent 3 grand lol.... Just stocked up on ammo yesterday :) 600 more rounds :)
  4. Jul 1, 2012 at 8:20 PM
    CNEDEER
    2015 DC TRD OR 4x4
    Oh lord. Maybe I should get out while I still can! :eek:
  5. Jul 1, 2012 at 8:22 PM
    meeestirg
    meeestirg Well-Known Member
    Vance County, NC
    those numbers are barrel length. they go out past 16" too. you can get 18" 20" etc... it all depends what you want to do with it. since this is your first rifle and you are going to use it to learn, i still just suggest the S&W M&P15 Sport
  6. Jul 1, 2012 at 8:24 PM
    CNEDEER
    2015 DC TRD OR 4x4
    Gotcha. Advantages of a larger barrel? I would imagine it to be more accurate at longer ranges the longer it is?
  7. Jul 1, 2012 at 8:25 PM
    meeestirg
    Vance County, NC
    if you want to see if you can afford ammo in the future you are going to spend $0.30 - $0.35 a round for factory plinking ammo, less if you learn to reload or buy reloads. stay away from steel cased ammo.
  8. Jul 1, 2012 at 8:27 PM
    double dee
    double dee Well-Known Member
    Arizona
    I just started building my AR15. After countless hours of research I decided on Bravo Company. They had everything I was told to look for plus they stand by their product with a lifetime warranty. I originally bought just my upper receiver from them but I have decided I am going to buy my lower from them as well.
    This is what my build concist of...
    BCM upper receiver 14.5 Carbine
    BCM Lower
    Daniel Defense Omega FF rail
    Magpul CTR stock
    Eotech XPS2-0
    Troy folding back up rear sight
    I will post a picture of the finished product once everything comes in:D
    The complete rife itself is right around $1,0000. The eotech and daniel defense omega rail is what puts it above the $1,000 range but there are less expensive options for both of those.
    http://www.bravocompanyusa.com/
  9. Jul 1, 2012 at 8:28 PM
    Stubbs95tacoma
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    I have 2 long and short... :rolleyes: they can be changed out :rolleyes:
  10. Jul 1, 2012 at 8:28 PM
    meeestirg
    Vance County, NC
    yes and also the twist rate of the barrel and the weight of the bullet.
  11. Jul 1, 2012 at 8:31 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    Alot of people say longer barrels aren't anymore accurate than shorter ones but I dont believe them. Get a 16 for all around and 20 for hunting/longer ranges.
    Oh and welcome to the black gun disease:D
  12. Jul 1, 2012 at 8:39 PM
    CNEDEER
    2015 DC TRD OR 4x4
    As if TW didn't deplete my funds as it is, this will make me go broke lol.
    Also, a lot of the searching I have been doing thus far, a lot of times the word carbine will be thrown in the mix. Is carbine consistent with a shorter barrel? or???
  13. Jul 1, 2012 at 8:48 PM
    MontanaTaco
    Colter
    14 DCLB Sport
    OME lift
    Carbine is the distance the gas port is away from the chamber. It is used on 16 inch barrels and the longer the barrel the longer the gas port is away from the chamber. A rifle length is the smoothest shooting. There is also mid and intermediate lengths. 18 inch barrels can use either mid or rifle lengths.
    I'm sure someone can explain how each performs compared to the others. I've only shot rifle and carbine.
  14. Jul 1, 2012 at 8:49 PM
    meeestirg
    Vance County, NC
    this is pretty true i was hitting a 10" steel target every time at 600 yards with my AR. 16" barrel 1:7" twist rate. 55gn bullets.
  15. Jul 1, 2012 at 8:51 PM
    #35
    MontanaTaco
    Colter
    14 DCLB Sport
    OME lift
    Nice! What scope do you have?
  16. Jul 1, 2012 at 9:03 PM
    #36
    meeestirg
    Vance County, NC
    surprisingly i was using a primary arms red dot and their x3 magnifier.
  17. Jul 1, 2012 at 9:43 PM
    #37
    troy28
    troy28 Well-Known Member
    Capitol of Salty Roads
    Need help
    With out getting to complicated a 16in barrel length is the shortest legal length you can put on your rifle with out getting a Class 3 Stamp and registering the lower as a Short Barrel Rifle or permanently welding flash hiders on to reach 16in.
    Yes you can order a 7in upper off the internet tonight and slap it on your lower tomorrow. The upper is not illegal until it is attached to an unregistered lower. Even honestly misunderstanding this law will not save you on a Federal Level if you get caught.
    With in reason, a longer barrel does add to accuracy. But not enough to make a difference in what you will be doing. If you want real accuracy you would also need to hand load match ammo with a recipe specific to that rifle and then create a shooting log of temperatures, wind speeds......... After all that is done people then need to learn how to correctly shoot the rifle.
    16in will be lighter than an 18in+ barrel especially with run and gun. Learn proper shooting techniques and you will still be able to shoot quarters and center of mass at a couple hundred yards.
    As for the ammo. If you are willing to clean your gun after shooting, do not need to shoot a single ragged hole at 100+ yards, and enjoy saving money shoot steel case ammo. You can not reload steel and you can increase the potential to wear your gun out sooner. By sooner I mean your children may have to purchase a new barrel and ejector before they hand it down to their children. I would not trust my life to steel case but an afternoon at the range I will shoot it all day.
  18. Jul 1, 2012 at 9:49 PM
    #38
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    a longer barrel might not be more accurate, but generally, the longer the barrel the higher the muzzle velocity... some of the varmint and high power guys will use long "bull" barrels which have a large wall thickness to reduce harmonic vibrations that occur when firing...
  19. Jul 2, 2012 at 5:38 PM
    #39
    StZu
    StZu Where the White Women At?
    Richard
    Dallas Texas
    18 Super White TRD Offroad
    Level 8 Wheels, Bilstien/Eibach lift, 2" aal, blacked out rear bumper, AC drain hose relocation, sound deadening 4 doors and back wall, amp/speaker upgrade, 10" daytona sub, LED interior lights.
    Why stay away from steel case ammo? I would shoot steel before reloads, if I didn't load it myself.
  20. Jul 2, 2012 at 6:32 PM
    #40
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    For $1000 you can get a Colt 6920 - essentially their "Law Enforcement" edition. Similar to what the Military M4 runs. Usually around $950 online, $1050 in shops. Some Walmarts are also reportedly carrying them.
    Good brands?
    Colt, Novoske, BCM, LMT.
    Middle road brands? (probably still good enough)
    Rock River Arms, Stag, Smith & Wesson, PSA (only b/c they're new)
    Not so well thought of brands?
    DPMS, some of the Bushmaster models (some are OK).
    You might be able to go cheap by buying a used upper (the part that goes bang) and a cheap lower, or building one yourself (that's the part w/ the trigger and buttstock).
    Go to Ar15.com and m4carbine.net and do some reading. Make sure you read the stickies in the sections you're interested in. Then set aside at least $400 for a case of ammo and 5 mags.
