Wanting to Downgrade from Factory LEDs to Halogens
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mustainefan, Jun 16, 2022.
  1. Jun 16, 2022 at 9:47 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    If you're dead set on doing this and can figure out how to wire them to work I have my 2021 take off's with drl available that were removed with ~700 miles on the truck. One I tried opening to retrofit before I said fuck it and just sealed it up with silicone but there's no visible damage from outside the vehicle.
  2. Jun 16, 2022 at 9:48 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    With your conditions the dude is basically getting halogens for free, selling the LEDs for full price and the halogen guy is buying used LEDs for the price of new. Doesn't seem fair.
  3. Jun 16, 2022 at 9:49 AM
    Bowhuntercoop
    Bowhuntercoop Well-Known Member
    2025 gx550 overtrail. 2025 limited off-road tundra.
    Hahaha I have 50 percent windshield tint on my 18 pro with the stock 18 pro headlights. They have more output and brightness then I ever needed. I don’t understand the led obsession. How much light do people need?
    GSDLVR123 and mustainefan[OP] like this.
  4. Jun 16, 2022 at 9:50 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Where are you getting new leds for 1k?
    They were 1.1k when they were 25% off...
  5. Jun 16, 2022 at 9:51 AM
    BLtheP
    Plano, TX
    1K plus shipping plus giving up the halogens for a trade the OP initiated? You're up to around 1300 of value by that point and I can get brand new LEDs for $1340 shipped.
    At least if I buy new ones I can keep my old ones as spares in case I traded the truck and wanted to revert to stock or have spares.
  6. Jun 16, 2022 at 9:52 AM
    t2c
    t2c Well-Known Member
    The one I currently have now is a standard SR5 housing. Its neither a dedicated bulb (it works as blinker too) and it doesn't double up as a low or high beam.
  7. Jun 16, 2022 at 9:54 AM
    BLtheP
    Plano, TX
    Correct, I was not referring to SR5's. I was referring to the Pros you asked about, and relating them to other vehicles that have standard halogen DRLs that you showed interest in.
    I figured your amber turn signal DRL on the SR5 was not relevant.
  8. Jun 16, 2022 at 9:54 AM
    mustainefan
    mustainefan [OP] Well-Known Member
    Portland, OR
    2022 Tacoma TRD Off Road
    Icon Stage 2, 2015 TRD Pro Wheels, BFG KO2 285/75r16
    They whole MV argument is moot if the downgrade is not possible. I'm not going to go create custom harnesses myself.
  9. Jun 16, 2022 at 9:55 AM
    musicisevil
    Alaska
    2019 TRD Sport
    Okay... Where are you getting new leds for 1.34 shipped then?
    That’s what I’d list them at and I’m confident they’d be gone in a week
  10. Jun 16, 2022 at 9:57 AM
    t2c
    What I'm looking for is the standard SR5 housings because I like the amber DRLs in them. But I wish they had one that has a black housing. I don't want any LED strip things. I want my SR5 housing but in black and not chrome. I swear I've seen them somewhere but I'm unsure if the LED "L" was just turned off or if it didn't actually have it.
  11. Jun 16, 2022 at 9:57 AM
    BLtheP
    Plano, TX
    As the OP said this is a moot discussion however Sparks Parts....nobody is buying used ones for the price of new with a factory warranty.
    Paying a grand plus footing the shipping plus giving up the factory housings all as part of the deal puts you close to the value of what you could have just paid for a brand new set with a warranty. It doesn't make sense. Anyways, sounds like none of it matters.
  12. Jun 16, 2022 at 9:59 AM
    t2c
    And the reason I mentioned them as PROs was because I thought pre 2020 pros had the blacked out halogen lights but it seems those are mandatory with the led "L" strip?
  13. Jun 16, 2022 at 9:59 AM
    BLtheP
    Plano, TX
    Could you not just buy the TRD Pro housings and leave the DRL portion unplugged? I'm not sure the L's would be that visible if off. From the factory they only made the black housing in the TRD Pro format with the L. So I'm guessing you saw something aftermarket or they had the DRL unplugged. The TRD pro uses the L as a parking lamp at reduced brightness at night time so from the factory they would not have done what you are wanting, but I'm pretty sure you could simply install the housings and leave the L disconnected, especially since your truck will not have the connector for the L DRL anyways.
    t2c[QUOTED] likes this.
  14. Jun 16, 2022 at 10:00 AM
    BLtheP
    Plano, TX
    They did, and they are. find pics of a TRD pro not running and you'd get an idea if the unplugged LED strip is a manageable look for you or not.
  15. Jun 16, 2022 at 10:02 AM
    #35
    t2c
    Ahh I see man, thank you for your help and the info! Really appreciate it!
    BLtheP[QUOTED] likes this.
  16. Jun 16, 2022 at 10:05 AM
    #36
    slowpoke16taco
    slowpoke16taco Well-Known Member
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    Stock, but not stock (but stock)
    Ha! I saw your username and post...reminded me:
  17. Jun 16, 2022 at 10:07 AM
    #37
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Junkyard OEM halogen connector cutoffs (5 each side) and an MX-150 male pigtail and some butt connectors would get it done. It would be an ugly duck but that is within your powers.
    I am advising you in the strongest terms possible to just ignore the aesthetics. Honestly, they looked cheezeball to me at first too but it's grown on me.
    Being able to see at night is very useful for safety reasons. More seeing is better than less seeing. At least I don't know anyone who willingly prefers partial blindness to 20/20 vision.
    Also, I'm no halogen hater, of my 4 vehicles, 3 run halogen bulbs. And for 9011 HIR the halogen bulbs can be awesome. The Tacoma projectors, simply stated, suck.
  18. Jun 16, 2022 at 10:12 AM
    #38
    mustainefan
    Portland, OR
    And just to confirm, there is no way you could be enticed to hook a brother up?
  19. Jun 16, 2022 at 10:14 AM
    #39
    daveeasa
    David
    PNW
    No, I draw the same line with helping people with Alpharex, airbag cutoff switches, etc.
    I do not wish to aid anyone else's bad decisions, I make enough of those on my own and carry that guilt, don't need any extra :)
  20. Jun 16, 2022 at 10:20 AM
    #40
    mustainefan
    Portland, OR
    I can understand basic safety provisions like the airbag, but if Toyota is making a model with Halogen headlights its already been deemed to be perfectly safe and acceptable. I really don't understand the position that this is some sort of drastic move. Sure, maybe it would be like someone wanting to go from 4WD to 2WD, but there's no safety issues whatsoever. Additionally, it can be undone at any point if its a simple wiring harness. I respect your opinion, but I fail to see the logical connections.
    GSDLVR123, zacinnc78 and BLtheP like this.
