Wanting to Downgrade from Factory LEDs to Halogens
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mustainefan, Jun 16, 2022.
  1. Jan 11, 2023 at 9:24 AM
    #101
    islesrule123
    islesrule123 Well-Known Member
    New York
    2016 inferno Tacoma TRD off road
    Trd pro suspension trd pro grill
    thank you @daveeasa and I work nights living in the suburbs then driving into the city I use them often at the beginning of the trip. I also believe they could use some fine adjustment for the alignment
  2. Jan 11, 2023 at 10:08 AM
    #102
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    See post #5987 as an example for removing the green center plastic in the OEM harness to make H9s plug and play.
    RE Odyssey vs T4R, Post #5247 for Odyssey high beam vs T4R in post #5048 (Toshiba HIRs vs stock) and post #5241 (Toshiba vs Sylvania HIRs) The T4R puts down higher output 17%+ higher output intensity in the high beam over the Odyssey using the same high performing 9011 HIRs. Need to look at the posts to compare patterns.
    Note that you don't adjust the high beam independently. The high beam is tied to the low beam and adjusted by adjusted the low beam. If your low beam is adjusted correctly, then your high beam is properly aimed.
    eurowner and daveeasa like this.
  3. Jan 11, 2023 at 10:27 AM
    #103
    islesrule123
    New York
    I think the low beam is a little low ill have to check
    crashnburn80[QUOTED] likes this.
  4. Jan 13, 2023 at 2:33 AM
    #104
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    Curious about LED headlamps -- whether Toyota's latest OEM projectors, or retrofit H4 bulbs in old reflector housings -- how do these deal with serious cold weather & snow?
    Do they get hot enough on their own to keep the headlight lenses free of snow? Or does Toyota build auxiliary heating circuits into the newer OEM LED projector assemblies to prevent the headlights from getting dangerously caked up & dim due to snow accumulation?
  5. Jan 13, 2023 at 4:52 AM
    #105
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    I have upgraded from Halogen to OEM LED on my 2017, and they have been great for the last 3 years. I personally like the look of them, but a BLHM Halogen gives me that cool RC Toy Truck vibe.
    The one issue I have with the LEDs is the less than ideal performance in rainy weather on old roads. I do think it is because of the color temp, the cooler white is just not as visible in bad weather compared to warmer whites.
    I used to run 5500k HIDs and those penetrated through rain like nothing.
  6. Jan 13, 2023 at 5:17 AM
    #106
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Toyota’s LEDs are reflector, not projector. That said, no they do not melt snow. No aux heating circuit. I don’t know of any OEM that gives you aux heaters. Some aftermarket options for Jeeps and trucks do but that’s all. Some OEMs have a sprayer that hits the headlights.
  7. Jan 13, 2023 at 5:54 AM
    #107
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    I wish the manufacturers would cut the LED kelvin to way lower like 4000k range as the high kelvin light seems to wash out color contrast to me
  8. Jan 13, 2023 at 6:48 AM
    #108
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    I think the headlights on my 2019 are amazing but then, I was driving vehicles before halogens came on the scene, what a difference they made from the incandescence bulbs...
    blu92in99 and fathomblue like this.
  9. Jan 13, 2023 at 7:11 AM
    #109
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    I feel the same way. I just installed the factory leds on my SR5 and like them, but anyone who says the halogens are terrible has never driven on a freshly paved asphalt road at night, in the rain, with nothing but a pair of incandescent sealed beams lighting the way.
    Vmax540[QUOTED] and eurowner like this.
