wanting to lift truck more
Discussion in 'Suspension' started by nightrider09, Nov 15, 2012.
  1. Nov 15, 2012 at 8:23 AM
    nightrider09
    nightrider09 [OP] Member
    Silsbee, Tx
    009 Trd off road
    Billet grill, 6in pro comp stage 2 performance lift,weather tech mats, rhino step bars, fosgate p3 subs and component speakers, k&n cold air intake, hood shocks, pioneer head unit, flowmaster and turndown,moto metal wheels, 33in nittos
    I currently have a 3 in pro comp lift with diff drop spindles and struts/springs in front block n add a leaf in rear, i know what to do to acheive more lift in the back but not positive on tje front as to if id have to do away with whats there or what add ons can i do. Also tje truck only has 35,000 miles on it and thefront diff bearings n seals are already going out with little trail riding. Any ideas on why they wore so fast?
  2. Nov 15, 2012 at 8:28 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    If you want to lift the rear more, get a replacement leaf pack and lose the blocks. All Pro makes a couple good replacement leaf packs, there's the OME Dakar pack and Wheelers sells a couple options as well depending on how much lift you want.
    For the front, when you lift the truck, you put the front shafts at a more extreme angle which wears out parts quicker. Could just be bad luck, who knows why they wore out so quickly.
  3. Nov 15, 2012 at 9:23 AM
    dlooney
    dlooney Well-Known Member
    Dennis
    Wilmington NC
    07 TRD Sport PreRunner
    Satoshi w/ hella 500s mounted behind, 20% tint, 6K HID retro headlights, 4300k HID fog lights, DTRLs, plastidipped front valence, cb mount
    How do you like the pro comp 3 inch? And is it the suspension lift with coils or just spacers?
  4. Nov 15, 2012 at 9:48 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Are you 4x ?
  5. Nov 15, 2012 at 9:51 AM
    nightrider09
    Silsbee, Tx
    009 Trd off road
    Appreciate the info on the rear ive been around 4 wd's my whole life but I dont have to much experience with the new model stuff or Toyotas in general, But i do know several people with ifs and lifts and alot more lift than 3inches that do alot of mudding and no probs that fast. But like you said it could all jist be bad luck.Do they offer those packages to go with a vehicle thats already lifted? Bit yea it shocked me that the frsont diff seals and bearings on the axles are already goin out so soon i bought the truck used wit 24k on it had it for aboit a year and only has 34ish on it now. Tue lift was already on it and the giy i bought the truck had already done every thing that done to it. dlooney its alright ive read a lil bit about other peoples builds and have 3 inch lifts w/o a diff drop and have more ground clearance than i have. All im able to clear is a set of 33s but for some reason the sway bar rubs on the right side, ive priced this kit on pro comps website and it runs like 3grand from what i remember for the money i dont exactly think it was worth bit idk much about em and theres so many ways to lift these ifs that its crazy to me. The original owner built it for looks it was a mall crawler but for the money i paid for the truck id like to get use out of it besides jist looking good. The front is a lil stiff for my likings tho.
  6. Nov 15, 2012 at 9:52 AM
    Pugga
    Massachusetts
    F-150 Mod
    Tough to tell, isn't it? I'm guessing the spindle drop was actually a diff drop and I'm hoping he was correct about the diff bearings and seals which means he has to be 4wd. I could be way off though...
  7. Nov 15, 2012 at 9:55 AM
    Pugga
    Massachusetts
    F-150 Mod
    ProComp uses 700# coils I believe which is why it rides rough. Other popular lift coils are between 580 - 620 #/in for the Tacoma. Usually the 700# springs are for people who have plate bumpers and/or winches hanging off the front.
    With the Toyota IFS setup, you can't go over 3" of lift without a drop bracket lift (well, you can but you'll just tear up your CV's).
  8. Nov 15, 2012 at 9:56 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Ok assuming your 4x
    You need to level out the CV angles possibly
    & with IFS you'll probably have to get a drop bracket to get over 3"
    its alot of work to lift IFS as opposed to solid axle
  9. Nov 15, 2012 at 10:01 AM
    Gregero
    Gregero TRD: Trail Ready Development
    Greg
    El Cajon, CA
    Blue '06 Prerunner TRD Sport
    LED Spyder Tail Lights, Debadged Tailgate, TOYOTA logo on Tailgate, Uniden Radio w/ 4' Ant., Removed Sway-Bar, Rear 5125s, 8" King Offroad Shocks, Debadged Doors, 1.25" Rear AllPro Wheel Spacers, 33x12.50R17 Mickey Thompson Baja MTZs, AllPro Skid Plate, New Car Smell Air Freshener, OMD Ford&Chevy Leaf Pack, Glassworks Front Fenders, Engage LT UCAs and LCAs, Engage HD Tie Rod Ends, Kar-Tek Limit Straps, Camber Eliminator Kit, Removed Rear Flares, Blue LED Dome and Map lights, LED License plate lights, Black TRD Sport Rims, MBRP Catback Exhaust, 20W PA Speaker, 2 Meter Radio, AFE Stage2 CAI, Demello-like Bed Bar, Harbor Freight Dust Lights, Blacked-out Hood Scoop, Custom Pre-Runner Bumper
    Shackles flip kit? Some get an inch to 1&1/2" that way depending on the shackles used.
  10. Nov 15, 2012 at 10:32 AM
    nightrider09
    Silsbee, Tx
    009 Trd off road
    Yea its 4wd, its got aftermarket spindles, diff drop and procomp coil overs and springs in the front. The right side rubs on the sway bar linkage linkage when you turn to the left but what im wondering is how can i go about lifting the front with the existing parts i have or if i can even keep em to lift about 3 more inches and didnt understand why tje diff bearings n seals r already goin out.
  11. Nov 15, 2012 at 10:34 AM
    nightrider09
    Silsbee, Tx
    009 Trd off road
    I already have a 3 in pro comp kit on it just wanting to go bigger and unsure about how i can go about it with what i already have.
  12. Nov 15, 2012 at 10:37 AM
    nightrider09
    Silsbee, Tx
    009 Trd off road
    The front is what i have questions about, the rear is simple in my opinion.
  13. Nov 15, 2012 at 1:21 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yeah I got ya, & if you're already 3" in front, your maxed as far as what you're running now, like i said earlier , drop bracket will get you to 4", anything over that you'll be looking at (God forbid) body lift...
  14. Nov 15, 2012 at 2:12 PM
    nightrider09
    Silsbee, Tx
    009 Trd off road
    Ya i jus didnt know if i could go with control arms or spacers on the strut or anything like that on top of what i already and i had wrecked it bout 6 months ago n busted the blocks in the rear and they measured at 2.5 inches in the center of block and it has a aal also n local offroad shop told me that would mean its a 3 inch kit so idk since it was on the truck when i bought it. And ya i def dont really care for a body lift myself, but def gettin some new leaf springs hit 30k n started getting a hard 1st to 2nd and from what ive read is that thhe factory leaf pack gets weak and ccauses axle wrap which causes it to shift like that
  15. Nov 15, 2012 at 2:15 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    3" front lift won't cause damage that fast at all. Just say'n.
  16. Nov 15, 2012 at 2:16 PM
    Blacktacoma23
    Blacktacoma23 CO
    Denver
    2011 TACO
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, Nitto Mud Grapplers, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5%/30% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    Any pics?
  17. Nov 15, 2012 at 2:17 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    to go more than 3" on a 4x4 you will have to start over and get either a procomp or fabtech 6" drop bracket kit.
    EDIT: also can you show us pics of your front suspension so we can possibly help you better?
  18. Nov 15, 2012 at 2:25 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    The spindles you are talking about concern me, there aren't many cases of people using an aftermarket spindle on a 3 inch lifted 4x4, this may be the source or your premature wear. If you want to avoid a drop bracket lift, you could get like a 1 inch body lift and stick some 35's under there, you will need to cycle the suspension and get proper clearance but that combination will get you higher up, if you have stock tires now this will net you 3 more inches of lift.
  19. Nov 15, 2012 at 2:47 PM
    nightrider09
    Silsbee, Tx
    009 Trd off road
    Ya i know 3 inches shouldnt cause it to wear that fast jus wasnt sire if anyone else has had that prob out of there taco, Ill have to take some pics for you guus, yalls help is greatly appreciated. Didnt know if there was a diff in the 3 inch and 6 diff drops. I myself thoight it was kinda weird to have spindles diff drop with as 3 inch lift. It may already be a 6 inch lift, just going by what local shop tolold ke when i had to buy new lift blocks.
  20. Nov 15, 2012 at 2:52 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    Super Bro lift!
    Judging from the 2 pics you uploaded, you may have a 6" DB lift......hard to tell, the 2nd pic is too fuzzy.
