wanting to paint stock trd wheels.
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaitus, Jun 13, 2013.
  1. Jun 13, 2013 at 5:48 PM
    tacomaitus
    tacomaitus [OP] Member
    Nick
    Louisiana
    02 4x4 black tacoma trd
    OK... so I just got a Tacoma, and am wanting to paint the stock wheels black. I've heard of just painting them black and painting them with spray on bed liner the only problem is that they are pretty beat up. Can I maybe sand them down and then paint them or are they past repair? Any suggestions will help thanks:)
  2. Jun 13, 2013 at 5:53 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    You could have them bead blasted and powder coated. Just depends what you are going to do with the truck and what you want it to look like.
  3. Jun 13, 2013 at 6:05 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    The "time & effort" YOU put into these will determine HOW they look...;)
    My son did this as a "Gift" and the "prep" was good BUT he rushed the painting process and ended up doing it twice :rolleyes:...thumb prints show up real well in shiny black paint..:p..
    Those "painted" wheels are now 2nd's for a Vermont Taco....
    If you take your time and are patient the results might just surprise you...:cool:
  4. Jun 13, 2013 at 6:06 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You could use paint stripper sold in auto parts stores and after fill in any deep scrapes with some permatex wheel repair. Sand smooth and paint.
  5. Jun 13, 2013 at 6:08 PM
    tacomaitus
    Nick
    Louisiana
    Thanks for tip and the truck will probably see 30% of the rest of his life off road. All I am wanting is a good looking truck that will be aggressive off road when I need it to be.
  6. Jun 14, 2013 at 12:53 AM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    My wheels look the same, maybe even worse. I want to paint them matte black but I'm afraid of the prep lol. If you put the time in you could make it work very well, but I just don't have the time to do it as I don't have another set of tires or a vehicle to use while I'm painting.
  7. Jun 14, 2013 at 1:26 AM
    stinkyspice
    stinkyspice Well-Known Member
    I sanded and painted my wheels look at my build thread I used rustoleum paint came out real nice! If I were u I would go get them sandblasted and then paint em right after! That would be the way to go!!
  8. Jun 14, 2013 at 6:44 AM
    Madjik_Man
    Colorado Front Range
    In your build thread you have the original 6 spoke wheels, not the one shown in the OP of this thread.
  9. Jun 14, 2013 at 8:14 AM
    tacomaitus
    Nick
    Louisiana
    So what exactly is sandblasting, does it work kinda like a pressure washer? Where can I do this and how much does it cost? And can I do it myself.:confused:
  10. Jun 14, 2013 at 8:35 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    It's pretty expensive to get the gear to do it, you need a big air compressor and a blast cabinet and blast media and such.. It should be $50 a wheel to get blasted. If you painted them right after it should turn out nice! Corrosion on Toyota alloys is a really common thing hah.
  11. Jun 14, 2013 at 8:54 AM
    tacomaitus
    Nick
    Louisiana
    Wow...they probs aren't even worth that much each:eek:
  12. Jun 14, 2013 at 10:37 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    I just finished repainting my alloys because I didn't do it right the first time. you don't need to sand blast. you can use heavy duty or metal sandpaper.
    then use metal primer after that your choice in paint. I used rustoleum semi gloss black. but you can go today or high gloss
  13. Jun 14, 2013 at 10:38 AM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    oh and to strip them of everything use Aircraft Paint Remover. And yes it's acid in a can so be careful
  14. Jun 14, 2013 at 11:06 AM
    tacomaitus
    Nick
    Louisiana
    Thanks a lot Mr. Biscuits that is what I will do, when I can get around to it. A wise man once said 99% of painting something is the prep. And the other 1% is to not screw it up:D
  15. Jun 14, 2013 at 1:03 PM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    very true.
    get metal sandpaper or "heavy duty" by 3M. it's black/dark grey. not that tan shit, it can't take the abuse of sanding metal
  16. Jun 14, 2013 at 6:20 PM
    mcallahan 98 taco
    mcallahan 98 taco Member
    mike
    selah wa
    98 tacoma & 2012 tacoma TRD
    3in toy tec lift rear aal, k&n cold air, 32 11.5 pro comp mt, LCE header, relentless fab diy front bumper
    if you want them to last i would go with sandblast and powder coat, it may cost a little more but will last much longer than paint. i have lots of experience with this as i work in an fab shop and we also powder coat and sandblast.
  17. Jun 14, 2013 at 6:26 PM
    TejasYOTA
    TejasYOTA Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
    I cleaned, sanblasted, primer and painted, all done by me.
    Check my link for pics.
  18. Jun 14, 2013 at 6:42 PM
    tacomaitus
    Nick
    Louisiana
    I know it is a little rednecked, but I was thinking of spaying them with truck bed liner. Yes? No? It would fill in the little imperfections of the wheel, and it should be rather tough. right?
  19. Jun 14, 2013 at 7:21 PM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    I agree, the only thing is you have to remove the tire. not an option for po' folk :eek:
  20. Jun 14, 2013 at 7:41 PM
    tacomaitus
    Nick
    Louisiana
    True DAT
