Wanting to re-gear. Suggestions?
Discussion in '1st Gen. Tacomas (1995-2004)' started by LSC15, Apr 15, 2013.
  1. Apr 15, 2013 at 8:13 PM
    LSC15
    LSC15 [OP] Well-Known Member
    Logan
    New Bern, NC / Lenoir, NC
    2001 TRD D-Cab
    - Billies all the way around - Eibach Coils w/ aal - Kenwood Double Din - Ultragauge
    Hey guy. I've got a 95 2.7L tacoma. I have went up to 32x11.50s and can tell a difference in the gas and power. Im not to worried about the gas but i would like to get the power back. My door code is B03A, which means i have 4.10 gears if i'm not mistaking. So with the 4cyl and 32s, what gear ratio should i go to if I decide to re-gear and about how much would it cost? Thanks
  2. Apr 15, 2013 at 8:40 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    I'm running the same size tire but my truck came with 4.56 gears. I think 32's and 4.56 are a good match. On the highway at 65 I'm running about 2350 rpm. Also gas mileage wise my last tank of almost all city driving was 18.3 mpg.
  3. Apr 15, 2013 at 8:43 PM
    LSC15
    Logan
    2001 TRD D-Cab
    Yea my gas isn't too bad in city, 17-18 mpg. I can tell the power I have lost from when i bought the truck with 235s then went to 31s and now on 32s. You still have a lot of power? Not having to push the gas too hard?
  4. Apr 15, 2013 at 9:06 PM
    TherealScuba
    TherealScuba Well-Known Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Auto? 4.56's.
    5 Speed? 4.30's.
    Only problem is finding a factory set of 4.30's will be like finding 9mm ammo these days. ;)
  5. Apr 15, 2013 at 9:09 PM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    i have an '04 automatic v6 with 285s (~33") tires and regeared to 4.88s. love it. i think 4.56s would be fine for 32s unless you plan on running 33s in the future...
  6. Apr 15, 2013 at 9:23 PM
    valon5150
    valon5150 Well-Known Member
    Steven
    redding
    01 taco turd
    all pro lift, 33s, home made sliders, bumpers, skids
    if you plan on going to 33's in the future just get 4.88s. 4.56's would probably be ideal right now. i wouldnt wast time on 4.30's unless you found some dirt cheap it's just not big enough of a difference even to waste time pulling your diffs out. if you get 4.56s and then go to 33's someday the 4.56s would treat you decent still.
  7. Apr 15, 2013 at 9:40 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    This.
    Autos came wi 4.56 cause they are power hogs and have different gearing.
    Your a manual. So 4.30s would be best.
  8. Apr 15, 2013 at 9:54 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor 15x8 D Window Steelies 33" BFG KM2s Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Gear sets (ring and pinion) will run you about 200$ each. Master install kits (bearings and such) are another 200-220$ each. So parts will be ~850$. If you are in the diff, it may be smart to install a locker while doing this. Prices vary with type, from 250-1000$
    Labor costs to install will vary depending on who does it. Most places get 750-1000$ for complete installation, front and rear + parts.
  9. Apr 16, 2013 at 6:25 AM
    LSC15
    Logan
    2001 TRD D-Cab
    Ok thanks guys. My truck is an automatic too
  10. Apr 16, 2013 at 6:57 AM
    LSC15
    Logan
    2001 TRD D-Cab
    Do I need to find a truck with 4.56s to re gear or what?
  11. Apr 16, 2013 at 7:04 AM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    See Digiratus' post from above:
    You're on the east coast, so I'd definitely give ECGS a call. they can set ya straight!
  12. Apr 16, 2013 at 7:08 AM
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    I went with 4:56 nitro gears and i'm running 305/70/16. Love the gears
  13. Apr 16, 2013 at 7:14 AM
    LSC15
    Logan
    2001 TRD D-Cab
    Ok thanks guys
