Wanting To Re-Gear
Discussion in '1st Gen. Tacomas (1995-2004)' started by bellassaiw10, Jun 14, 2011.
  1. Jun 14, 2011 at 7:43 PM
    bellassaiw10
    bellassaiw10 [OP] Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Been wanting to re-gear for quite some time now finally got some $$$ saved up, whats the best gear ration for 35s on a 00 Prerunner id say moderate highway use maybe, 4.88's ?? Thanks.
  2. Jun 14, 2011 at 7:44 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    what engine do you have?
    reason I ask is because some 1st 4 cylinders come with 4.56 on the stock tires so if yours is similar maybe even the 5.19's
  3. Jun 14, 2011 at 7:48 PM
    bellassaiw10
    Currituck NC
    3.4 sorry about that
  4. Jun 14, 2011 at 7:49 PM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
  5. Jun 14, 2011 at 7:50 PM
    08pretaco
    Oliver
    az
    4.88 sounds pretty good to me with the 35's and the V6. If you wheel a lot and the highway drivings low id go 5.19 but if your doing not so much off-road and more city/freeway 4.88
  6. Jun 14, 2011 at 7:50 PM
    08pretaco
    Oliver
    az
    Hey Matt, my buddy at discount was working when you came in today
  7. Jun 14, 2011 at 7:53 PM
    rcfreak201
    rcfreak201 Well-Known Member
    i have a 4.0 v6 with 33s and 4.88s it revs a bit but my buddy has the same with 35s and its perfect, ill also be getting 35s soon so i just decided to gear a bit higher keeping that in mind
  8. Jun 14, 2011 at 7:54 PM
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    Yep, he mentioned you. Aired down yesterday so I had to pop in for a fill up.
  9. Jun 14, 2011 at 7:55 PM
    bellassaiw10
    Currituck NC
    I did work just wanted a few confirmations on the 4.88
    Thanks pretaco
  10. Jun 14, 2011 at 7:56 PM
    08pretaco
    Oliver
    az
    NP man, regearing is a wonderful thing to do that people almost always look past as far as performance both power and MPG wise!
  11. Jun 14, 2011 at 7:57 PM
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    ;) gotchya. I'm getting rid of my 4.88's on Thursday. It's torture on the freeway. Back to sluggish 4.10's.
  12. Jun 14, 2011 at 7:59 PM
    rcfreak201
    why man? why not go with some 4.56s then? or just get bigger tires:D
  13. Jun 14, 2011 at 7:59 PM
    bellassaiw10
    Currituck NC
    I actually know how to use the invisible "Search Button" haha what size tires are you running ?
    Whats everyones views yukon gears ? ya or na
  14. Jun 14, 2011 at 8:00 PM
    Quast
    Quast Well-Known Member
    Dustin
    Mission, BC
    03 toyota tacoma 3.4L
    3'' OME lift, Deck plate mod, spidertrax wheel spacers, 12'' alpine type S sub.
    how would one go about doing this is it easy to do on your own or is it something that you should just bite the bullet and pay to get done? what kind of price range for the gears and wheres the best to buy. been thinking of doing this for a bit now just not sure though thanks!
  15. Jun 14, 2011 at 8:02 PM
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    Dude I commute from Ft. Irwin, CA to Gilbert, AZ (7 hour drive). Don't want to do the bigger tire things just yet. I can still get busy in the desert with 4.10's.
  16. Jun 14, 2011 at 8:05 PM
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    I bit the bullet and had someone else do it. It's not THAT hard, just more a test of patients. Glad now I bit the bullet cause the place put the wrong gears in, and I'm not getting charged to have anything swapped back to normal, and I can spend time doing other things with my free time.
  17. Jun 17, 2011 at 6:35 PM
    bellassaiw10
    Currituck NC
    Whats the best kind of gears to order ??
  18. Jun 18, 2011 at 6:10 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    I got nitro gears in mine. 4.88 as well. I ordered a built diff from eastcoastgearsupply and did the swap my self, it came with a 5 year warranty. Good guys to deal with. Chase knows his gears.
