Wants to run but can’t
Discussion in 'Technical Chat' started by Loudmouthsoup, Feb 18, 2018.
  1. Feb 18, 2018 at 2:56 AM
    Loudmouthsoup
    Loudmouthsoup [OP] New Member
    2001 Tacoma srs
    So I have a 2001 Tacoma with a 3.4 and I’m having this very odd problem that some of you are very aware and familiar with. All of the sudden one day last week I go to start the car and it runs for 1.2 seconds and then turns off. So I’m thinking to myself fuel pump and filter, well that was wrong. So now I’m going to change the Cranks sensor and pray a lot. I need to the feel pump and filter anyway but I’m chasing my tail looking for the real slim shady. I’ve had this truck for 18 years And drive it like a baby together we put 300,000 miles going back-and-forth from Canada to Mississippi, if any of y’all have some idea what my get me going again. Thanks much. Thank you guys very much. UPDATE. Some Tacoma’s with all the options made in 2000-2004 have a crazy ALARM system. If the lock actuators don’t fully go up and down it trips the system and thinks your pride and joy is being stolen. But since I had it part I replaced the Cam and crank sensors. She’s all good for another 300
  2. Feb 18, 2018 at 3:14 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Does it sound different as you crank it over? Might have broke the timing belt.
  3. Feb 18, 2018 at 6:35 AM
    BAMAFAN67
    BAMAFAN67 Well-Known Member
    The Free State of Jones
    19 TRD OD 4X4 DCSB
    My 97, 3.4L did something similar yesterday, the truck cranked and ran fine, made a trip to Walmart, come back out, cranks and runs fine leaving the parking lot and it just shuts off. It would try to crank but wouldn’t start, finally after a few minutes it’s starts, i move About 50 yards and it shuts off again. No stumbling or anything, it just dies. Had to pull it about 8 miles to the house, it will turn over but will not start. Kind of perplexed as where to start looking.
  4. Feb 18, 2018 at 6:42 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Broken timing belt or stripping teeth on timing belt
    wilcam47 and Loudmouthsoup[OP] like this.
  5. Sep 23, 2018 at 5:03 PM
    TeslasMuse
    TeslasMuse Member
    Having a similar issue with a 2001 2.7L prerunner 4-door, was the timing belt the issue?
  6. Sep 28, 2018 at 9:50 AM
    Taco-Man18
    Taco-Man18 Well-Known Member
    2018 MGM Tacoma V6 SR5
    Have you read for codes while the truck is on?
    It can be numerous things too. I'd say start with the MAF and sensor connection, breather hoses that could be loose or broken.
    Then maybe your fuel pump.
    I've even seen O2 sensors crap out and cause the motor to run rich and stall it out.
  7. Oct 5, 2018 at 3:35 PM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    My daughter's 02 behaves similarly - following... She's not getting any codes/lights, states it happens mostly when warm/hot outside. Or has set for a while. She might go 2-5 days between events...
  8. Oct 5, 2018 at 3:59 PM
    Clearwater Bill
    Billy
    Largo Florida
    He updated the original post where it says UPDATE.
    Looks like it was the OE alarm
