Warm a/c when sitting still
Discussion in '2nd Gen. Tacomas (2005-2015)' started by byronshawlsu, May 17, 2009.
  1. May 17, 2009 at 7:30 PM
    byronshawlsu
    byronshawlsu [OP] New Member
    Fairfiel, CA
    06 SR5 4wd
    17" aftermarket wheels and Bridgestone A/T Revo's, K&N Cold Air Intake
    Hello everyone, I'm new to the Tacoma forums so bear with me. I have an 06 Access Cab 4wd and bought in during the late winter and didn't turn on the a/c. It blows nice and cold as long as I'm moving but when I stop.......well, it gets warm.......ok, hot. Right now I try not to go through town where I'll be in stop and go when it's a hot day. Suggestions please. Thanks for what ever information you can provide.
  2. May 17, 2009 at 7:32 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Well it should not get "hot" but it will be alot colder once your moving.
  3. May 17, 2009 at 7:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    may need to get your r134a checked. its gonna get colder while you are moving cause of air hitting the condenser...............should stay cold when you are sitting too.
  4. May 17, 2009 at 7:41 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I'm re-reading your post, is the truck getting hot or is the air not blowing cold?
    Truck running hot. I'm going to guess the thermostat, if it's not the thermostat there is a chance your radiator needs to be cleaned out. I would drain the coolant and put in a new thermostat, if that does not take care of it you may have to pull the radiator and take it to a radiator shop. Wait for a second opinion from the forum.
    Air blowing hot. I would add a pound of R134.
  5. May 17, 2009 at 11:03 PM
    byronshawlsu
    Fairfiel, CA
    06 SR5 4wd
    The truck is not hot. Just the a/c air. Maybe it's time for a recharge.
  6. Oct 18, 2010 at 2:44 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    heater core, water pump?
  7. Oct 18, 2010 at 3:07 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    I would wash the condenser and radiator first, then recharge. the condenser coil is not able to evacuate heat from the inside of your truck while sitting still, then it's probably caked with garbage. You may not need any refrigerant.
  8. Oct 18, 2010 at 3:58 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    +1 on cleaning the condenser. Having the ac system leak checked would be a good idea too. There is no fan constantly pulling air through the radiator and condenser so, when you stop, it will not be as cold. Getting hot means the outside air is really hot, or you have issues.
  9. Oct 18, 2010 at 1:59 PM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    your probably low on refrigerant. we have a ford escape that done the same thing. they charged the system and now we freeze.
