Warm gear shift???
Discussion in '1st Gen. Tacomas (1995-2004)' started by roddyrod72, Apr 16, 2010.
  1. Apr 16, 2010 at 8:16 PM
    roddyrod72
    roddyrod72 [OP] Well-Known Member
    Greenville, KY
    '10 SR5 Regular Cab 4x4 5 sp manual
    DRL OEM Mod, OEM Cruise Mod, 3" Lift, painted OEM grill
    So i took my 97 V6 5 speed (262,000 miles) on about a 2 hour trip on the interstate this week and noticed after driving for a while, the metal on the gear shifter was actually warm to the touch. Has anyone else noticed such a thing? I guess that means my tranny was actually running hot enough to radiate heat all the way up to the top of the gear shifter. No problems or anything...just a general question. Thanks.
  2. Apr 16, 2010 at 8:23 PM
    HomerTaco
    HomerTaco All up in your GRILL Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    that happened on my 99 taco a few times - never was an issue though..:notsure:
  3. Apr 16, 2010 at 8:42 PM
    da0023
    da0023 The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    mine does it as well. and I also use to have a 92 toyota that did the same thing. i believe you can feel the heat because of the combo of the shifter being on the floor directly above the tranny and the lack of a decent heat shield/barrier. I wouldn't worry about it.
  4. Apr 16, 2010 at 8:49 PM
    roddyrod72
    Greenville, KY
    Thanks guys, I appreciate it. Glad to know that I'm not the only one. :)
  5. Apr 16, 2010 at 8:51 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    My '91 does the same thing
