Warm start issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pol500, Nov 5, 2011.
  1. Nov 5, 2011 at 9:58 AM
    Pol500
    Pol500 [OP] Well-Known Member
    Duluth, MN
    03 TRD DC 4x4
    Deck plate, grey-wire, blue plug, alarm mod, clear corners, moved/painted badges, color matched grill, topper, 5100s, wheelers 5 leaf + 1.5 aal , OME coils, All-Pro rear bumper, Methods w/ 32's, converted HID Hellas, supercharger
    Truck starts fine when its cold but if the engines warm it will turn over fine but when it fires it sputters for a second and then runs good. It runs perfect any other time, full throttle, idle etc. No codes either. Anyone have any ideas?
  2. Nov 5, 2011 at 10:03 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    How many miles are on it? How long ago did this start? Have you replaced anything on it recently?
    Fink
  3. Nov 5, 2011 at 10:34 AM
    Pol500
    Duluth, MN
    03 TRD DC 4x4
    I've had the truck for six months and its done it the whole time I've had it. Truck has 173,000 mi. New plugs and wires, cleaned throttle body, seafoam through intake and gas tank, and cleaned any easily accessible sensor.
    I've had an injector go on another car and it's similar to that, kinda like its getting to much gas on warm start up and flooding itself, but unlike my other car my mpgs are about were they should be.
    Are there any sensors that are prone to failure on these trucks?
  4. Nov 5, 2011 at 10:37 AM
    96Taco
    96Taco Well-Known Member
    Alberta
    '04 V8 4Runner
    ..stay tuned
    Check , clean maf sensor
  5. Nov 5, 2011 at 11:20 AM
    Fink
    Orlando, FL
    Would a gummed up MAF cause warm-start issues though? I was going to suggest that but I wasn't sure if it would play a role or not.
    Either way, cleaning the MAF is not a bad idea.
    Fink
  6. Nov 5, 2011 at 11:21 AM
    Pol500
    Duluth, MN
    03 TRD DC 4x4
    Yep cleaned that too, actually had some MAF cleaner.
  7. Nov 5, 2011 at 11:28 AM
    Fink
    Orlando, FL
    Fuel filter ever been done? I have no idea if that would cause this, but it'd be a good idea to change it anyway.
    Fink
  8. Nov 5, 2011 at 11:34 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    wonder if u have a leaky injector -worse when warm
  9. Nov 5, 2011 at 5:18 PM
    Pol500
    Duluth, MN
    03 TRD DC 4x4
    Sorry forgot to add that, that was changed also.
    Like I said I had one go on my car and it acted the same way but on my car I was getting worse mileage and I'm getting about 17-18 around town and 18-20 on the highway with the tacoma so not sure if it would be that or not. On my car (Intrepid 3.2 v6) you had access to all of them and if you listened with a stethoscope you could actually here the bad injector sounded different then the others with the engine running. But on the truck it looks like you could only get two of them and they look like a pain to change so I really hope it's not that. Has anyone ever had an injector go on these trucks?
  10. Nov 5, 2011 at 7:28 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    im thinking you have a v-6? if you do its below.
    injectors on the v-6 (5vz-fe) are not that bad to change. Take the throttle body off. Take the intake off both upper and lower ( it comes in halfs) There are alot of bolts maybe 14 to get the intake off. both bolts to watch out for one is behind the intake and one beside where the support is at on the drivers side engine. If my memory is correct its a 12 mm bolts and 10 mm bolts. some where a 14mm bolts also. ( brain fart tonight) .
    When you get the injectors back on and this will save you some time. Bypass the fuel pump relay and let the fuel pump run 30 seconds is fine. That way you can check for leaks before you put the intake back on. I had a cracked injector once only way i found it was by doing it this way.
    I used this guy here for all my replacement on injectors they all have been great with no problems. http://www.fiveomotorsport.com/import-high-performance-fuel-injectors/toyota.
