Warm up or not?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by newtaco2008, Oct 16, 2010.
  1. Oct 17, 2010 at 10:26 AM
    #61
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    I usually get in, release e-brake, as I am already rolling down the hill bump the starter and floor it!
  2. Oct 17, 2010 at 10:52 AM
    #62
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    If I have the time I let the RPM go down. If my kids are
    Creating a fuss I wait up 5 unless.'if my wife is dealing with the meltdown I shut down.'if
    I run into the grocery store or other and i don't want to got through the ordeal of dealing with a 3yo and 2yo and it's too hot or cold I'll leave it running for as long as it takes.
    I use synthetic and drop the oil every 5k. That is where synthetic oil does it's job.
    Anyway the oil cooler especially with a tow package plus the radiator will deal with the heat. Off roading creats more heat so those who claim it's bad for the engine to idle are drowning themselves I a glass of water
  3. Oct 17, 2010 at 10:54 AM
    #63
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    First, with engine oil the way it is now a days, especially with Synthetics your oil isn't like molasses at all. That's why you purchase 5w30. Or if you're in Canada, Toyota recommends 0w30 if you can find it.
    Second if you're in cold weather there is this brand new device out called a block heater. You plug your vehicle in for the night and this little element keeps your engine block toasty warm till you go to start it.
    Read and learn knave.
    And the worst thing you can probably do to an engine is poop in the cylinders, light the engine on fire with thermite and for the coup de gras, drop this on it.
    Jesus, the lack of mechanical understanding here is dumbfounding. Now I see how elected officials actually make it into political office.
  4. Oct 17, 2010 at 11:18 AM
    #64
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    WHO ARE YOU!? What have you done with Krazie!!!!
  5. Oct 17, 2010 at 11:25 AM
    #65
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    hahahaha.....
  6. Oct 17, 2010 at 11:33 AM
    #66
    jandrews
    '09 FourDubDee TRD OR
    Next thing you know, we'll have people pouring tranny fluid into their coolant reservoir...
  7. Oct 17, 2010 at 11:35 AM
    #67
    cummins6speed
    But I was told it helps to warm up your engine faster:rolleyes:
  8. Oct 17, 2010 at 12:28 PM
    #68
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    What's the procedure for escaping from vampires? They scare me more than the zombies.
  9. Oct 17, 2010 at 12:30 PM
    #69
    WABOOM
    WABOOM Well-Known Member
    Minnesota yeah sure ya betcha
    2013 F-150 XLT Supercrew 4x4
    debadged
    Krazie , that piece was written by the smelly hippies. I don't believe the Enviro Extremists :)
  10. Oct 17, 2010 at 12:58 PM
    #70
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Spring, Summer and Fall I wait till the RPM's drop as a minimum but usually longer while I'm putting stuff in the truck. Winter below 30F I use a oil pan heater and run it til it is warm enough to sit in. Don't know if this is correct or good or bad but that is what I do.
  11. Oct 17, 2010 at 1:12 PM
    #71
    cobrakenny
    cobrakenny Well-Known Member
    Ken
    Raleigh, NC
    09 TRD Crew Cab 4x4 LB
    Now that beats even my neighbors start procedure! :laughing:
    Seriously though I was always taught that it's really more the internal parts like valves, rings, bearings and all that fancy stuff that should be coming up to temp for proper tolerances before putting a heavy load on a cold engine. I don't think oil is what we should be disscussing if we are all using the proper weight for a particular climate. But please educate me guys...
  12. Oct 17, 2010 at 1:14 PM
    #72
    jandrews
    Nah, you're right on. But the point is, idling is slower way to get up to temp, and has other undesirable results as well (less complete combustion, which means more byproduct buildup and oil contamination).
    You SHOULD wait until operating temp to put HEAVY load on an engine. However, LIGHT load, i.e. gentle acceleration in normal driving, is the best way to bring your engine up to operating temperature with the least delay.
  13. Oct 17, 2010 at 1:17 PM
    #73
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Those parts DO need to get up to temp. The more quickly, the better.
    Valves: The only tension they are under, is whats generated by their springs. Heat has no affect
    Bearings: The bearings are suspended from other metal parts from a thin film of oil. If you have metal on metal contact at start up, you'll know it. If you have propper oil pressure (either via a gauge, or dummy light), then your good to go.
    Piston rings: Combustion pressures mostly keep them pressed against the cylinder walls. Heat DOES have an affect on them, and to avoid the most possible blow by, you need to get them to operating temp quickly.
  14. Oct 17, 2010 at 1:26 PM
    #74
    cobrakenny
    Ken
    Raleigh, NC
    I figure that being I tow a trailer with about 2200 lbs GVW almost every day, I give her just a couple minutes extra to warm up before I go. I guess that would be considered a load right? Without the trailer I just drive a little easy until the temp comes up to normal or might let her run just a few to defrost the windsheild before I go, but that's just so I can see!
  15. Oct 17, 2010 at 1:36 PM
    #75
    cobrakenny
    Ken
    Raleigh, NC
    jandrews and chris 4x4
    Great info, thanks Guys!
  16. Oct 17, 2010 at 4:40 PM
    #76
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Even though it was, and I knew someone was going to harp on that, the science is still sound regardless.
    But what the fuck do I know? I've only run vehicles in temperatures of -50ºC for years on end, diesel and gas engines.
    Just like I'm the only one on my ambulance service that lets the rigs run for a while after using them to let the intercooler draw the heat away from the engine block so it doesn't roast the internals due to the heat from the turbo.
    Thanks ya bugger.
  17. Oct 17, 2010 at 4:53 PM
    #77
    AKTACO420
    AKTACO420 Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    By saying the oil is like molasses when its cold was just a figure of speech. I have enough mechanical knowledge to know how to build a truck from the ground up. I have a block heater installed but I let It warm up about 3 mins. This thread wasn't started to find out the fastest way to warm up your truck it was started to see who was doing it and why.
  18. Oct 17, 2010 at 5:13 PM
    #78
    BarefootBandit
    BarefootBandit Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    I let it warm up until the needle crosses the bottom line with the "C"
  19. Oct 17, 2010 at 5:58 PM
    #79
    rme
    rme Well-Known Member
    Savannah
    Green TACOMA
    XM, Panasonic Stereo, Headlights,Electric Ant,Toyota Deluxe Wheels, Rhino Lining, Cargo Rails
    Hey your low on gas if you didn't notice....:p
  20. Oct 17, 2010 at 7:29 PM
    #80
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    And a piss poor one at that. A figure of speech is something like "That's the way the cookie crumbles."
    There is no reason to let your truck sit and idle.
    At all. If the truck isn't moving, it's getting an awesome 0mpg.
    And even if...lets just say for shits and giggles that the oil like molasses was true. You'd still want to not let your truck warm up, cause a thicker viscosity would mean more stress on the engine, which means higher revs which means more gas burnt which means faster warm up time on the engine. Not to mention a higher viscosity means increased friction.
    Guess what that causes...heat.
    Either way advocates for letting the vehicle warm up are incorrect via logic or flawed logic.
