Warm up or not?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by newtaco2008, Oct 16, 2010.
  1. Oct 19, 2010 at 7:32 AM
    #161
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Of the 169 posts so far this is the most insightful. Thanks for your time, expertise and effort. Curious George
  2. Oct 20, 2010 at 6:14 AM
    #162
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Actually u agreed with me :). Like i said, a film. Also wasnt saying 5 qts floats and doesnt drain to the pan , of course it does. Compared to older oil standards in the 70/80s modern oils leave the coating/ film / layer that helps minimize friction on startup , synthetics are reported to be especially good at this.
  3. Oct 20, 2010 at 6:36 AM
    #163
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    I think the fact that so many people are so split on this, with both sides having stories of success (mine - '95 Avalon with 250k+ that I never had any problem with, no idle at start) speaks volumes to the fact that letting a modern, fuel injected engine idle when starting up really doesn't get you any extra benefit. But if it makes you feel better, go for it.
    I do let my Mustang or other carbureted (or otherwise low-tech) engine warm up for a few seconds, but not for any extended period.
  4. Oct 20, 2010 at 6:52 AM
    #164
    Glamis
    Glamis date joined 03-18-2009 this is my new ID
    Anaheim & Glamis, CA
    08 PreRunner DC/LB Sport-2 Debadged
    Debadged, TRD exhaust, Devil Horns, Pop n lock, Stock wheels chromed, K&N, DRL's on/off switch, bed mat, lock & unlock beeper, Disable Seatbelt Warning Chime, 12v Cigarette lighter plug always on, 2009 LED Brake lights, TSP springs, Fire Stone Ride Air springs.
    I'm old school I let my truck get to the cold line or just past it. Just not in the morning any time my truck has Cold off completely. I give the Rings, pistons, and block, time to expand. I know new cars run just fine cold and new oils never completely run out the top of the motor. I feel it is Cheap insurance.
    I have done this with all my car and trucks.
  5. Oct 23, 2010 at 7:34 PM
    #165
    Sapper26
    Sapper26 Well-Known Member
    Will
    Columbus, GA
    99 Xtra Cab 4x4
    No real reason to in Hawaii.
