warming up in winter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tig1, Feb 6, 2010.
  1. Feb 6, 2010 at 8:35 AM
    tig1
    tig1 [OP] Well-Known Member
    Paul
    Saint John,New Brunswick,Canada
    2009 tacoma
    n fabs,window visor tonneau ,bilstein 5100's all round.245/75R16Toyo A/T II
    ok question- how long do you let your tacoma and it doesn't matter what kind, warm up in the winter.mine is a 2009 access cab 4cyl.and I let it go for about 2-4 minutes before I get going.that's with -18/-20 with a wind chill( I know wind chill has no effect on trucks).too long too short let's here you.
  2. Feb 6, 2010 at 8:39 AM
    Tadcaster
    Tadcaster Dogs n Trucks
    Pete
    Vermont
    09 Access Cab TRD Off Road
    I do about the same with my 09 TRD OR. With weather like ours I need some heat coming out of the defroster before setting out.
  3. Feb 6, 2010 at 8:39 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    I think the actual time is hard to judge, but I usually wait until the idle slows down, and the belts have had time to flex a little. This is when I'm in northern Vermont or Maine (family there)....not in CT where it is not a big concern.
  4. Feb 6, 2010 at 8:47 AM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    It depends, but in the a.m. my scangauge on zero-ish days show the water temp @ startup in the teens. It takes about 2-3 driving minutes to get it up to 125 degrees which just gets the temp needle moving.
    At full warm up it registers between 181-185 degrees operating temp. That is the halfway mark. These numbers are pretty consistent over the last 2 winters in Northern VT. My driving time to work is not that far, 3 miles tops & so on really cold days I let it warm up longer or take it for a longer drive.
    Usually after work, I get it in and drive away without a warm up just to get out of there but take it easy on the throttle. It warms up pretty fast. My 2 cents.
  5. Feb 6, 2010 at 8:54 AM
    gfiber
    gfiber Well-Known Member
    Gary
    Seattle, WA
    2017 Black TRD Sport Access Cab
    TRD sport pkg, Towing Pkg, Ham radio installation, bed lights, front 32 inch LED Bar behind the grill.
    Used to be it was better to start driving as soon as you could. The engine warms faster under load than idle. I generally only wait until the windows are clear then go.
    Sitting there idleing was more harmful as so much fuel is not burned with the old carburators anyway. Probably a lot different since Throttle Body Injection has coame about.
  6. Feb 6, 2010 at 9:03 AM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    2-4 minutes is good when it's really cold out. On an average day, like -10c thirty seconds to a minute is good. The faster the engine warms up the better, and it will warm up faster if you drive it. Just go easy on the gas while it's warming up. Long idle times put wear on the engine and wastes gas.
  7. Feb 6, 2010 at 9:14 AM
    NMG
    NMG Well-Known Member
    Ottawa
    09 Double Cab TRD Sport
    My normal routine is to unlock the doors, throw my lunch in the truck, scrape all of the windows, get in, start it, adjust the climate controls, buckle up, start playing some music and go. I figure at most, it's like 30 seconds.
    If it's really cold (say -30C or colder), I might let it run a little longer, but honestly, I don't think it makes a difference. The truck warms up MUCH quicker by just driving it so I normally just get in and go. In very cold temps, however, I do go really easy on everything. Easy on the brakes, easy on the gas, no really quick manoeuvres, etc. It does take time for stuff to loosen up but I don't think that sitting away idling for minutes really does all that much. I'd actually prefer to have everything "break in" at the same pace, as opposed to having a completely warm engine and a frozen solid tranny, suspension, etc. I figure taking it easy on everything is a good way to go when the temps are like that.
  8. Feb 6, 2010 at 9:16 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I usually let it warm up between 5-10 minutes. I try to avoid scrapping as much as possible. I notice the glass really gets scratched easily.
  9. Feb 6, 2010 at 9:23 AM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    crank mine and go,hardly ever gets to freezing here.
  10. Feb 6, 2010 at 9:25 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Whether or not you have a child would play into this.
  11. Feb 6, 2010 at 9:30 AM
    Canadian Max
    Canadian Max Yamaha
    In the Garage
    2010 TRD 4X4
    2010 TRD Sport 4 door Speedway Blue 4" Nerf Bars Vent visors Weathertechs Mats Hella 500 HID Mod Bull Bar Devil Horns Eclipse AVN 726E Energy Speakers
    5-10 min if it's really cold.. God I hate winter:eek:
  12. Feb 6, 2010 at 11:19 AM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    5 mins is usually my time, just enough to drop rpm and get a little heat going.
  13. Feb 6, 2010 at 11:23 AM
    mattcombs
    mattcombs Well-Known Member
    matt
    hazard kentucky
    SR5 tacoma 4wd
    3in revtec lisf westin step bars and westin bull bar and some other odds and ends
    10 usually
  14. Feb 6, 2010 at 11:38 AM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road SR5 Impulse Red
    5100's @ 1.25", Scangaugae II, deck plate mod w/AFE Pro Dry S filter, grey wire mod, alarm mod, defrost w/o compressor mod, de-badged, 17" sport wheels powder coated black, 1" B.O.R.A. wheel spacers, 265/70/17 Cooper Zeon LTZ's, sockmonkey beside decals.
    i only let it idle for about 30 seconds then just drive it easy until its gets warm.
  15. Feb 6, 2010 at 12:39 PM
    JKD
    JKD Well-Known Member
    Usually 30 seconds, sometimes a couple of minutes if I'm brushing snow or scraping ice.
  16. Feb 6, 2010 at 12:47 PM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    till the tach reads under 1000 rpm, in neutral so the tranny warms up at the same time.
    then take it easy for the first couple minutes once i get going to let the drive train and other moving parts warm up too.
  17. Feb 6, 2010 at 12:50 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    A couple minutes roughly only if its really cold. then i just take it easy on her until she gets warmed up.
  18. Feb 6, 2010 at 12:56 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    if it's really cold, I let it warm up for a few minutes atleast, and usually give it some time the first time I drive it for the day.
  19. Feb 6, 2010 at 12:57 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    Just wanted to clear something up because i hear a lot of people around here talking about how it warms up faster if you just start driving it?!?!? That jsut doesnt even make any sense, of course it is going to warm up. but your components will be under stress when they are cold and more easily broken.
    warming it up by driving it is not the goal people who like to "warm up" their engine should be trying to achieve.
    youre not trying to just get it warmed up, your supposed to be letting the engine run and warm up a under low stress situation, ie at an idle, so that the belts and engine "inards" (if i may use that term:) ) are warmed up and ready for action when put in higher stress situation ie actually driving it.
    your gear boxes will take care of them selves when you start driving there is nothing you can do except spend some money and get one of those highspeed warmers. jsut dont take off and do agressive driving right off. in about a couple minutes or so your gear boxes are going to be warmed up.
    hopping in and taking off will allow for the cold components to more easily break one day. Its not going to hurt you "right now" but one day when your components are getting older and more frail, hopping in and taking off before the belts can properly warm up and expand is gonna leave you with a broken one.
    with that said down here in there is really no scenario for me to need to warm it up more than a minute or so but if i am back home in northern Idaho then i wait until the temp actually rises close to normal operating temps and by then everything should be nice and warmed up and ready to operate.
  20. Feb 6, 2010 at 3:37 PM
    NMG
    Ottawa
    I've seen vehicles up here that simply can't get up to normal operating temps WITHOUT driving them, it's just too cold. In those cases, the temp gauge won't budge more than marginally, you have to put a greater load on the engine to get it into the range of its normal operating temp.
    I can totally see not hopping in and driving off like a demon, but I don't buy that gentle driving when the engine is cold will cause any more damge than letting it idle away for minutes. I just don't see there being that much difference between a 1,000 RPM idle and a 1,500 RPM cruise.
