Warming up the engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SirGrove, Dec 9, 2016.
  1. Dec 9, 2016 at 6:30 PM
    eon_blue
    Azusa, CA
  2. Dec 9, 2016 at 8:28 PM
    avitaco
    avitaco Well-Known Member
    A
    2017 DCSB 4x4
    I let it warm till the rpm drops and its generally a min or two for that then I let it start to bring the needle up on the temp gauge. As long as its moving there is plenty of lubricant.
    I heard its not good to idle to operating temps. it puts unneeded stress on the block and can cause loss in life span... but thats just what Ive heard. Those sources could be full of crap.
    I have the V6 auto and my shifts are really rough when its cold... Like that rear dif/drive train is molasses. I wonder what can be done about that.
    PROseur likes this.
  3. Dec 9, 2016 at 8:53 PM
    sodaryl
    sodaryl Well-Known Member
    Daryl
    Vancouver, BC
    2016 Blazing Blue DCSB M/T Sport
    -Relentless Off-Road sliders -265/70r17 Wrangler Duratracs -Diamondback HD -CCG Mesh grill -Pop & Lock PL8535 -BPF Heavy-Duty Front Tow Hook
    10 months down, 4 years 2 months to go for me...
    I was a bit surprised that the auto-heat would keep the fan turned off until it was actually ready to blow warm air, neat feature!
    PROseur[QUOTED] likes this.
  4. Dec 9, 2016 at 10:37 PM
    highwhey
    highwhey Well-Known Member
    Alan
    Phoenix
    2016 Tacoma OR m/t
    lol, it feels like it. i have to be on my jobsites by 5am, and since most of them are quite the drive, every minute counts. i love my truck but it also hurts me to hear the tranny clunk.
  5. Dec 9, 2016 at 10:40 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    My 6MT, just reverse out of driveway, then its 1.2 miles downhill to highway. I neutral her all the to the highway. Then 1,2, skip shift to 4th and 6th, and steady eddy at 80mph. Bam bam. Loving the PRO and the third pedal.
    highwhey[QUOTED] likes this.
  6. Dec 9, 2016 at 10:47 PM
    SB Taco
    SB Taco Well-Known Member
    Santa Barbara, CA
    2007 Silver Tacoma DCLB 4x4
    The manual for my 2007 actually says "do not warm engine by idling". Always found that interesting but I do what it says, start it, then drive it.
    winterwolf likes this.
  7. Dec 9, 2016 at 10:49 PM
    winterwolf
    winterwolf Well-Known Member
    Arthur
    Surrey, BC Canada
    16 White TRD Sport SB 6spd
  8. Dec 10, 2016 at 6:45 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    I would definitely do more than my typical 60 seconds or so, but to me 10 to 15 seems like a lot, but I am not jumping on the highway for a few miles when I do go that way.
  9. Dec 10, 2016 at 6:55 AM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    This. I would bet that the third gen manual also says it.
  10. Dec 10, 2016 at 6:57 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Many will say it doesn't matter others will say it does.
    It really all depends
    Is it -25 out? Did it struggle just to start?
    Are you going to turn it on throw it in gear and floor it?
    Best way for it to warm up is to be running and moving as it will get more heat than at idle, but you don't want to over do it.
    Accelerate lightly until it starts to warm up and you should be fine.
    I opted to get the block heater from the dealer with mine for this.
    Even though its gas it really helps with having it start throughout january february where its -40 overnight and daytime highs are -25 to -30. Also helps the engine warm up faster once it is started and driving since its not going to be as cold.
    I'm used to driving diesel so to me I'm used to plugging in at night and giving it 2-3 minutes at idle just to warm up. I also have a digital gauge on my TDI (similar to scan gauge) and I get an accurate oil temp and coolant temp read out. I usually wait until both are 5-10 degrees C before taking off. Basically until the idle RPM drops to within normal. When its cold I'll idle at 1100RPM roughly I wait for it to drop to its 800-900rpm, for both the taco and jetta I have a timer set on the cord and an 1.5hours before I'm leaving in the morning it turns on.
    You'll get mixed answers here because everyone will have their own view and also live in different climates.
    I move around from southern ontario to central ontario all the time so obviously very different climate. from someone who's coastal and might just get -10 C the coldest and just get a lot of wet snow, where here we just get ice and really cold temps. Or a mix of light fluffy snow and ice in central ontario.
    You definitely do not need to be having it idle for 10+ minutes. But giving it 1-3minutes just to warm up and start getting stuff flowing won't hurt and it won't waste much fuel. Besides for peace of mind might just feel better wasting the bit of fuel.
  11. Dec 10, 2016 at 6:59 AM
    Joe23
    ya 10-15 seems a bit drastic for a modern day gas engine.
    2-3minutes should be fine.
    PROseur likes this.
  12. Dec 10, 2016 at 7:34 AM
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Your catalytic converter is not operating efficiently until it's warmed up so to speed up that process, most manufacturers today don't recommend letting the car idle cold. They want you to drive it quickly. 30 seconds is more than enough time to have oil flowing for adequate protection with light throttle application, however your oil's viscosity and sheer strength will not be attained until it's come up to full operating temp so don't go hot rodding for at least several minutes after your water temp is at operating. Oil takes longer to reach operating temps than water does.
  13. Dec 10, 2016 at 8:20 AM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I wait for idle to drop to its lowest RPM.
  14. Dec 10, 2016 at 6:04 PM
    Duff49
    Duff49 Well-Known Member
    Bucks County PA
    17 Sport TRD DCLB Barcelona Red
    I want my truck to warm me up !
  15. Dec 10, 2016 at 7:13 PM
    #35
    TRDOBSESSED
    TRDOBSESSED Well-Known Member
    Blair
    Puyallup, Wa.
    2017 TRD ORAC
    OvTuned
    on my 2017 the Rpm's do not drop lower then 1200-1300 after a few minutes until i put it in gear....all my other new cars always dropped pretty quick...dealer of course said...."it's normal operation "
    Gabtap likes this.
  16. Dec 11, 2016 at 2:22 AM
    #36
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Is your heater on when you turn the ignition on? Mine stays high if it is...
    IIRC, our trucks have an electric heater; maybe that's the difference between your other cars.
  17. Dec 11, 2016 at 3:22 AM
    #37
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    My winter and summer warm ups are pretty much the same.
    Start the Truck walk back inside put my boots on finish my coffee turn off the lights.
    10 minutes maybe 15
    The only difference in the winter wood gets put in the stove.
    Now if I get a phone call all bets are off.
    I do this because my commute is 5 miles the long way
    CusterFan likes this.
  18. Dec 11, 2016 at 3:24 AM
    #38
    TRDOBSESSED
    Blair
    Puyallup, Wa.
    2017 TRD ORAC
    OvTuned
    makes sense man...i'll see what's up with that
  19. Dec 11, 2016 at 11:27 AM
    #39
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    2016 SR5 Access Cab V6 Auto 4wd
    Limited wheels, extra rope hooks in bed.
    I've had 2 transmission updates and I'm still waiting for it to warm up...:annoyed:
  20. Dec 11, 2016 at 1:39 PM
    #40
    SilverTacomaGuy
    SilverTacomaGuy Well-Known Member
    Cody
    Central Oregon
    2016 TRD OFF-ROAD
    Little tree air fresheners. Clazzio black leather seat covers.
    When it's really cold (single digits) I let Lil Red warm up while I make my lunch for work and get ready. So generally 5-10 mins. That's just me! I like it to be warm when I drive to work.
