Warming up your 3rd gen for winter driving
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaIan, Nov 15, 2017.
  1. Nov 16, 2017 at 5:01 PM
    #61
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    Yeah I try to keep from flooring it until I'm at least out of my neighborhood.
    Taco Fan and HutchJ like this.
  2. Nov 16, 2017 at 6:29 PM
    #62
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nah. My Sport does that also. The high idle is a little high! It makes it less than fun to crawl backward out of the garage.
    The Wife's Forester is the same though.
    Once it gets to normal idle (usually after the first stop sign), life is good.
    Deathray likes this.
  3. Nov 17, 2017 at 6:17 AM
    #63
    a400ryan
    a400ryan Well-Known Member
    Garson Manitoba Canada
    2015 SR5 DCLB
    Yep....
    I’ll seitch to other than floor and auto light goes off and to fan/heat setting
    It is a Cdn model
    I figured was common
    Though I believe once gets up to temp allows change but have to confirm
    I’ve tried not to let it bother me but I’m confused why
    Maybe because of temp sensor would be mislead?
  4. Nov 17, 2017 at 12:07 PM
    #64
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    After reading this thread yesterday, I actively paid attention to my Tacoma warm up. My truck sat outside all day and it was 47 degrees when I left work. Set the temperature temporarily to 85 and always leave it on fresh air and started driving. Takes me a little ways to get out of my work parking lot so I use that slow stretch for warm up. Within 4 minutes and 1.1 miles (pretty much all side street driving) my vents were blowing what I would call fairly warn air. Seems about the same as my other Toyota vehicles.
    tonered likes this.
  5. Nov 17, 2017 at 2:13 PM
    #65
    jsey21
    jsey21 Well-Known Member
    2016 Black Tacoma Sport DCSB V6 4x2
    OVTuned https://www.tacomaworld.com/threads/rear-diff-vent-behind-the-tail-light-mod.286097/ https://www.tacomaworld.com/threads/rust-on-frame-with-a-c-drain-mod-fix.444138/ https://www.tacomaworld.com/threads/ultimate-led-turn-signals.486423/ https://www.tacomaworld.com/threads/premium-audio-upgrade-for-less-than-250.510424/
    TRD Sport FTW!!!!
    over60 likes this.
  6. Nov 17, 2017 at 7:58 PM
    #66
    a400ryan
    2015 SR5 DCLB
    Goes to floor when auto is pressed
    Is this not the case w others ?
  7. Feb 11, 2018 at 6:53 AM
    #67
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    Does anyone actually get the auto climate control? I thought it will stay on till you reach the temperature your set at. Doesn't seem to be that way tho.
    Also even if I put it on floor, I always get heat through the top left vent. Not the other good but ya a consistent amount through the left one. Anyone else?
  8. Feb 11, 2018 at 7:22 AM
    #68
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    Total BS, this may have been true when cars used carburetors...But with modern electronic fuel injection the ECU and wide band O2 sensors actually lean out the mixture to prevent this. So no you are not running the engine in a overly rich condition.
    The biggest reason that is suggested to not let a vehicle warm up is auto theft.
  9. Feb 11, 2018 at 7:33 AM
    #69
    Team Dirt
    Team Dirt Active Member
    East Of The Rockies, West Of The Rest!
    2017 Inferno TRD Sport
    That vent helps keep the side windows from frosting. The passenger sides the same. Also put cardboard in front of your rad and it will help with warm up and increase your mileage when it’s cold. Bring the engine temps up a bit and it doesn’t work as hard to stay warm. We’ve been consistently -20 to -40c in southern Alberta this winter and mine heats up decent. Only issue I’ve had is my cab filter plugging with snow but that’s a whole other issue. 39EB5FE7-CE01-4052-BEF3-5A2D94258239.jpg
    Taco Fan likes this.
  10. Feb 11, 2018 at 7:51 AM
    #70
    Canadianguy91
    Sean
    2016 Limited
    Holy crap. Maybe I should check mine!
    Any idea about the auto climate?
  11. Feb 11, 2018 at 7:59 AM
    #71
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Only read the first page, but being from Maine, many mornings below freezing and even a sreatch of below zero. I use the same method in the winter as the rest of the year. I get in, push clutch, turn key, put it in N, let off the clutch, count to about 20, push in the clutch and drive slower for about 2 miles, turn up the heat as it just starts getting warm, and then drive it. The only thing I do different in the winter is sometimes I pump the clutch as on the real cold mornings it's hangs some.
    JiminMaine and Taco Fan like this.
  12. Feb 11, 2018 at 8:08 AM
    #72
    Spare Parts
    Southern Maine
    I added the seat heaters to the group buy on wet oakie (think that's what they are called) seat covers, there has been a group buy every spring and fall since I've been here paying attention.
  13. Feb 11, 2018 at 8:39 AM
    #73
    Team Dirt
    I Never use auto climate. I just crank the heat then dial it back to between 20 and 24c and dial the fan back a few clicks. I usually just run foot and defrost on fresh air. If you use recirculate it doesn’t get rid of the condensation and windows frost more.
    over60 likes this.
  14. Feb 11, 2018 at 3:49 PM
    #74
    Canadianguy91
    Sean
    2016 Limited
    Ya that's what I do
    over60 likes this.
  15. Feb 11, 2018 at 7:21 PM
    #75
    Taco Fan
    Taco Fan Well-Known Member
    Fort Worth, TX
    2017 White TRD PRO AT 5 ft bed
    Console Organizer, black tailgate letters, chrome glove box letters.
    I’m in Texas...so “cold” mornings are never colder than a few degrees below freezing. No big deal. But I still drive slow until I see the temp needle begin to register...about 5 mins after start at the most.
  16. Feb 11, 2018 at 7:39 PM
    #76
    facefirst
    facefirst Well-Known Member
    Geoff
    Cleveland, OH
    2017 MGM TRD Off Road DCSB
    Zero issues. Heats up very fast.
  17. Feb 11, 2018 at 7:56 PM
    #77
    Wedge
    Wedge Well-Known Member
    Yves
    Kebekistan
    17 OR DCSB MGM
    Bestop supertop Bronze Method roost 255/80/17 toyo open country RT Interior LED XenonPro HID low beam
    Mine does fine even in -30 celsius weather just start it take the snow off and drive it. Its going to warm up faster if you you just drive it. Put seat heater to the max and voila. Having it plugged on a timer 1hrs before i leave helps a shit ton of course
  18. Feb 11, 2018 at 8:47 PM
    #78
    Team Dirt
    Just so happens that was the temp when I got home tonight. Clutch was sure stiff. My biggest beef is the frosting windows at this cold. I have to take it off foot heat every once and a while just to get windows cleared up.
  19. Feb 12, 2018 at 9:28 AM
    #79
    Wedge
    Yves
    Kebekistan
    17 OR DCSB MGM
    Little trick if you run foot heat crack a window down just a little bit and run the AC to which you should do anyway in the winter. Empty the water out of your mats to.
    over60 likes this.
  20. Feb 13, 2018 at 9:29 AM
    #80
    Monday_Rex
    Monday_Rex Well-Known Member
    Also live in frigid climate with Auto CC. I leave it on auto at 22 degrees (room temperature, Celsius). When cold it doesn't blow (fan off) until midway between the first 2 markers on the engine temp guage, presumably in an effort to get engine to running temperature ASAP before robbing heat. Even in my old vehicles without Auto CC, I would leave the fan off until that needle started lifting.
    Set at 22 degrees, it will blow hot air, and back off heat and fan speed as the cab warms up. There isn't any difference in the heat coming out set at 22 vs Max while warming up the cab in my test this morning.
    TL;DR - I leave it at room temp on Auto, does it's job. Only playing I do with the controls is if it's that -30 weather and the windows keep fogging up.
    Flash1034 and Wedge like this.
