Warn Semi Hidden winch bumper (New for 3rd gen Tacoma)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cal13, Jan 21, 2018.
  1. Jan 25, 2018 at 6:36 PM
    #101
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    The part number at summit matches the warn part number. It's just the bumper.
  2. Jan 27, 2018 at 10:35 AM
    #102
    oranjish
    oranjish Well-Known Member
    Josh
    Harris County, GA
    2017 TRD Pro Cement
    VTX Rogue Satin wheels, BFG KM3 tires, Diamondback SE tonneau, KBVoodoo Crossbars
    Just curious why on the PDF it says "Hacksaw Blade with Handle (fine tooth)" under tool's required - which is probably for the black plastic air deflector piece below **guessing** so would an off-road or pro not have any cutting whatsoever?
  3. Jan 27, 2018 at 11:26 AM
    #103
    oranjish
    Josh
    Harris County, GA
    2017 TRD Pro Cement
    Please post a few pics I'm eager to see your build come together
  4. Jan 27, 2018 at 5:29 PM
    #104
    Intrepid
    Intrepid Well-Known Member
    Jeff
    Toronto, Ontario CANADA
    2018 Tacoma TRD Sport double cab short box manual transmission cement grey
    ARE canopy with sliding screened windoors and rhino roof track, Warn semi-hidden winch mount with VR 10 winch, nightrider 28" single row LED lightbar, Hood scoop light bar, Anytime front and rear cameras. anytime Navigation switch, plug-in oil pan heater, plug-in block heater, plug-in battery blanket. WINTER: Snow Sport plow with back-drag modification, Bridgestone Blizzak DM V2 on steelies 265-70-17.
    Check back here next weekend.
  5. Jan 28, 2018 at 1:30 PM
    #105
    Charlie2017
    Charlie2017 Well-Known Member
    Hans
    Central Washington
    2017 Tacoma TRD Offroad Quicksand MT
    All chrome removed, TRD Pro grill, All-Pro Apex sliders, ARB twin compressor with Slee mount. SSO slimline bumper with Smittybilt X20, Softopper
    I think all three, SSO, SOS & Warn, are quality products. I have a SSO bumper installed on my truck. I went with SSO because you can customize your order. Mine is powder coated, no hoop, no light cut out and has cut outs for winch access. I was 758.20 including shipping to WA state using the TW group buy, not bad. Then I was lucky enough to get another 100 off through the drawing SSO does for a certain number of buyers. Again I don't think we can go wrong whose we install, we will have something that we like and will help us or somebody else out of a bind. If a winch is install, like I did.
    Friedtacolover and Harvo like this.
  6. Jan 28, 2018 at 4:57 PM
    #106
    sixlxvi
    sixlxvi "break stuff"
    I’m very interested in the Warn bumper.
    For anyone that has it/ordered it: Does it seem possible to mount 2 circle or square fog lights on it (not a light bar)? Are there holes already up there?
  7. Jan 28, 2018 at 5:01 PM
    #107
    Harvo
    From what I can see there are no holes, but you can use tube bar mounts for lights and I plan to get round of road lights.
  8. Jan 29, 2018 at 8:29 AM
    #108
    Suehog60
    Suehog60 Active Member
    Sioux Falls, SD
    2016 Tacoma TRD 4X4 Off Road
    TRD wheels, Michelin Defender LTX tires, Extang solid fold bed cover, OE roof rack added, 32" Caliraised LED light bar behind lower grill, Husky Liner floor mats, OE sliding bed divider, LED strip lights under bed rail, Fumota oil drain valve, TRD Pro skid plate, Warn front bumper, Weathertech in-channel vent visors, Updated TSB front door seals, Glove box and center console organizers,
  9. Jan 29, 2018 at 9:45 AM
    #109
    Taco Traction
    Taco Traction New Member
    TT
    2018 silver Tacoma TRD
    Leveling/lift kit 255/80/17 tires
    Any word if these work with the adaptive cruise control on the 2018s? The tube may interfere with the radar behind the front grille emblem. I called warn and the were not sure yet...
  10. Feb 2, 2018 at 2:16 PM
    #110
    Intrepid
    Jeff
    My Warn semi hidden winch mount and VR10 winch arrived in Whitehorse, Yukon yesterday. Cutting it close! I'm flying up there tomorrow to get it. I asked the Toyota dealer in Whitehorse if it looked like it would interfere with the sensor in the grill and he said, "What sensor?" When I described the adaptive cruise control he said, "Oh, I dunno but using cruise control up here is not recommended." This is gonna be great!
  11. Feb 2, 2018 at 2:44 PM
    #111
    LoMa
    LoMa Well-Known Member
    2016 Tacoma TRD Sport AT MGM
    For those wondering if cutting is required....according to the Warn's post on ExpeditionPortal
    Post 5
    Post 21
  12. Feb 3, 2018 at 12:26 PM
    #112
    Intrepid
    Jeff
    Warn semi hidden mounted but I don't know about the cruise control yet
  13. Feb 3, 2018 at 1:03 PM
    #113
    TACO_83
    TACO_83 Active Member
    North of the wall
    Any cutting? As in can you go back to stock?
  14. Feb 3, 2018 at 1:06 PM
    #114
    LoMa
    That looks great! Do you mind me asking how many Canadian pesos it cost you?
    stealthmode likes this.
  15. Feb 3, 2018 at 1:09 PM
    #115
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    That looks great!
    Intrepid[QUOTED] likes this.
  16. Feb 3, 2018 at 1:11 PM
    #116
    TACO_83
    North of the wall
    I was quoted right at 1000$ and change.
    Intrepid likes this.
  17. Feb 3, 2018 at 1:12 PM
    #117
    LoMa
    :thumbsup:
  18. Feb 3, 2018 at 4:13 PM
    #118
    Harvo
    Looks great. Did you mount the winch to the bumper then the bumper on the truck, or follow the instructions and slip the winch in after the bumper was on?
  19. Feb 3, 2018 at 5:50 PM
    #119
    Intrepid
    Jeff
    It looks better in person. No cutting and they say cruise control works but there is way too much ice to try it.
    LoMa likes this.
  20. Feb 3, 2018 at 6:00 PM
    #120
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    That looks awesome
