Warning..check your tire pressure after dealer inspec
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MJG, Aug 4, 2011.
  1. Aug 4, 2011 at 4:58 AM
    MJG
    MJG [OP] Well-Known Member
    Michael
    North Bay
    Kenwood Nav system, Sub, etc
    So I got my oil changed at the dealership. Had the scheduled expensive vehicle overall check done. This is where they go over the vehicle looking for any problems. Anyway they checked the psi in the tires and "adjusted". So when I got it back for fun I double checked tire pressure. It was at 44psi!!!! When I corrected it ..the Low tire inflation light would come on..after reading the manual some more I realized you can manually reset the monitor..I think it's really bad and potentially dangerous for a dealership to set a extremely high psi as normal operating range..especially having the sensor backing up there error..
  2. Aug 4, 2011 at 5:16 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Damn... I usually have the opposite problem with my dealer, they always drop me to 28 PSI (probably so it rides nicer). I just tell them not to screw with my tires when I go in.
  3. Aug 4, 2011 at 7:11 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    My steering wheel shake went away after the dealer dropped my pressures to 29 as door jamb sticker recommends. I had been running 35 psi. This was with my stuck Duncrap tires I no longer have. Once I put them back at 35, shake came back.
  4. Aug 4, 2011 at 7:40 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    That's true pretty much anyplace you take it... they all air it up to some crazy high pressure.
    The TPMS alarm setting shouldn't change unless they intentionally recalibrated it to the higher pressure. That's just wrong.
  5. Aug 4, 2011 at 7:51 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    tire pressures increase with temperature
  6. Aug 4, 2011 at 7:56 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    yeah,i run Nitro in my tires...cause i get it free at work;)..
  7. Aug 4, 2011 at 7:57 AM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    I run 78% nitro in my tires, cuz it's free everywhere.
  8. Aug 4, 2011 at 8:00 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Lucky you! I'm pretty much forced to use 21% oxygen.
  9. Aug 4, 2011 at 8:00 AM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    I think they do this as a general rule for the cars on the lot so they don't have to air them up as often. When I got mine from the dealer it was 42psi all around and had all kinds of crappy steering problems.
  10. Aug 4, 2011 at 8:11 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    That's not unusual-I have Toyota do my oil changes. I have always had tires that require 35lbs max on my truck. TWICE I caught Toyota increasing my pressures to 40psi! Since then, I specifically request them to NOT bother checking the tires..I will do them myself. Why do they do this?
  11. Aug 4, 2011 at 8:24 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The error the sensors read was due to when you lowered the psi in one of the tires from where the dealership had them set to. You can set the tmps to any psi, but when one tire pressure is lowered by around 6psi from the others it will set off the light.
  12. Aug 4, 2011 at 8:30 AM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    The place where I bought my Duratracs does free rotations, and last time I brought it in for a rotation then pumped those things up to 50 psi! Not that they can't handle it, but if I had left em like that there's no way they would have passed a chalk test. I'm guessing they were hoping I wouldn't notice so that my tires would wear faster and thus be able to sell me another set of tires sooner.
  13. Aug 4, 2011 at 9:18 AM
    textoy
    textoy Well-Known Member
    Fred
    Texas
    2011 4x4 TRD DC
    i no longer let them do rotations. they torqued my tundra wheels so tight i had to use a 4 foot cheater to break the lug nuts. that's death on rotors.
  14. Aug 4, 2011 at 9:25 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i think they all over inflate to give people the best mpgs
    they pumped my scion up to 40psi and i got 1 better mpgs
    makes the tires wear faster but tires for that are cheap as hell
    they put my duratracs down to 30 though, talk about squishy, probably because load e rides like shit with 40 but i dont mind
  15. Aug 4, 2011 at 9:34 AM
    Yoytoda
    Roland
    completely stock
    i caught it at the dealer and made them go back up to 40... they looked really low. i have one of the little pressure checkers in my truck at all times
  16. Aug 4, 2011 at 9:48 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    last time i had a set of tires balanced, the place put mine to the max psi on the sidewall...jackasses.
  17. Aug 4, 2011 at 12:24 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    I run my BFG AT's at 45-50 psi on the street. I get really good gas milage like that but once I hit the trail I air down to 15-20 psi. Discount tire tried putting 85psi in them one time because that is what it says on the sidewall at max psi. I just started laughing, I can imaging how hard that would ride!
  18. Aug 4, 2011 at 12:31 PM
    Rashnu
    Rashnu Well-Known Member
    '16 T4R TEP
    Stock
    Wait...so that's a bad thing.....:D
  19. Aug 4, 2011 at 12:35 PM
    The_Hodge
    SC
    haha...on the drive home i was wondering WTF was up since the ride was shit. popped out the gauge and walked around and it was crap.
  20. Aug 4, 2011 at 12:37 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I used to run my Hankook MT's at 36 PSI , recently went up to 40 PSI with no noticeable ride difference , but gain 1 MPG , on my last 2 fills
