Warning - Extremeterrain.com
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wduncan1983, Nov 13, 2022.
  1. Nov 13, 2022 at 8:23 AM
    wduncan1983
    wduncan1983 [OP] Active Member
    2012 Black Tacoma Pre-Runner Double Cab 2.7l
    Do business with extrementerrain.com at your own risk. Purchased a pair of headlights leads than a year ago and they’re peeling and cracking. I’ve driven <5k miles and it’s garage kept. Customer service said they would not return and they have no warranty. I’m out $450 and have to buy a new pair.
    What was worse is they offered me a $15 voucher on my next order. About as tone deaf as it gets.
    I’m sure they have some good parts but I won’t be doing business with them again. Cant do business with someone who doesn’t who doesn’t stand behind their products.
  2. Nov 13, 2022 at 8:46 AM
    Velequez
    Velequez Well-Known Member
    Austin
    2020 TRD Sport DCLB - Quicksand
    Before you spend the money on replacements it may be worth trying to sand/polish with a headlight restoration kit then follow it with a baked on UV coating. May or may not be a long-term solution but if those are going in the trash it is worth a try.
    Torspd, whatstcp, Mark77 and 2 others like this.
  3. Nov 13, 2022 at 8:47 AM
    mchabot1987
    mchabot1987 Well-Known Member
    Elizabeth City, NC
    2017 Super White TRD Sport DCLB
    Yes
    I never have any issues with Extreme Terrain. I've been a customer for about 5 years now between extreme terrain and American muscle (Same company). I've had issue in the past but they've always helped me. My headlights were peeling on my 3rd gen. Got a whole new set for free.
    Tactical_Panda likes this.
  4. Nov 13, 2022 at 8:55 AM
    wduncan1983
    I had not had an issue before this either. I like a lot of their products but I’m not giving them another dollar.
  5. Nov 13, 2022 at 8:56 AM
    mchabot1987
    Elizabeth City, NC
    Yes
    Ive had issues with that company "Spyder" that sells stuff on extreme terrain......those people won't be getting another dollar from me that's for sure. Lol
  6. Nov 13, 2022 at 9:01 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    This is called "Race to the Bottom"
    Who can provide the most appealing product for the least cost wins.
    This is why OEM lights are far superior to anything aftermarket.
  7. Nov 13, 2022 at 10:08 PM
    Pnwadventure
    Pnwadventure Well-Known Member
    Kirkland wa
    2006 white access
    Have you read the ultimate headlight upgrade sticky at the top of the 2nd gen forum?
    wi_taco likes this.
  8. Nov 14, 2022 at 9:42 AM
    goforbroke123
    goforbroke123 Well-Known Member
    Montgomery County, PA
    2012 Tacoma TxPro DBcab 6speed
    Aftermarket headlights are JUNK.
    If you guys realized how many millions of dollars Toyota or xyz car manufacture spends on headlight research and development you wouldn't replace them with an inferior product.
    On that note, I'm not so sure I would put the 2nd gens in that category with the old school halogen bulbs. :anonymous:
    They get the job done though, even more so once you upgrade the bulbs.
    J Williams and 2015WhiteOR like this.
  9. Nov 14, 2022 at 11:19 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    You can try rockauto for a set. I haven't heard good things about DEPO but that TYC brand 'looks' to be OEM quality, take that with a grain of salt. There are dealerships that offer online stores where you can sometimes get things for at-cost which might save you a little bit of sticker-shock from the parts counter and I'm sure other users will have links to the stores that offer the best discount. I would try the ultimate headlight retrofit post that someone referenced here, you can get the polishing compounds and packs of wet use sandpaper to polish/buff the lenses back into near glasslike clarity. Top it with some 4K UV clear which should last you years of shelf-life if you keep it clean and waxed. Bottom-line, you'll never go wrong with direct OEM parts from a dealership but you'll be out dealership money.
    -J
  10. Nov 15, 2022 at 6:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    DEPO is junk. Something you use to get you by. TYC is nicer. They'll do for a while as an "cheaper slap-in OEM alternative." You do it because you don't mind that cheaper alternative to OEM. OEM, or modded OEM is where it is at.
    Maybe even some LaminX protective lense covers. https://lamin-x.com/
  11. Nov 21, 2022 at 4:08 PM
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    Might i suggest off the shelf headlight restoration kit followed by lamin-x headlight film? Comes in vehicle specific shape, no trimming. The only solution ive seen for long term headlight protection that doesnt require maintenance after installation. Its also pretty thick and protects against rock chips. Had it on several cars previously.
    jackn7 likes this.
  12. Nov 26, 2022 at 6:47 AM
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    I bought a front bumper, rear bumper and winch from Extreme Terrain. No ordering problems and fast free delivery. Two Thumbs Up! :thumbsup::thumbsup:
  13. Nov 26, 2022 at 6:53 AM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Does it affect the output at all? If not I may go this way.
    Just read the reviews. Seems like a pita to install.
  14. Nov 26, 2022 at 2:42 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Ya, the Lamin-X has some bad reviews on their page. 2 out of 5 stars. Only 6 reviews but:
    "I was very disappointed in this item. There was no relief cuts on the hard curves therefore it would not contour to the outside edges even with heat. I’m experienced with applying film and I could not get the corners to apply flat. I ended up growing the film away because it was wrinkled up on the top edges. To improve this design I would highly recommend laminate-x to create relief cuts so that way you don’t have to fight with application."
  15. Nov 26, 2022 at 3:25 PM
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Yeah, I saw that too. I'll keep looking around, gotta be something out there that protects your headlights that doesn't cost an arm and a leg.
  16. Dec 5, 2022 at 6:39 AM
    wduncan1983
    Extreme Terrain wouldn't allow my review to post. They deleted it. Just confirms that this company doesn't really care about customer service.
  17. Dec 5, 2022 at 6:40 AM
    wduncan1983
    I didn't have a problem ordering or receiving either. It's the cheap products that they don't stand behind. Hopefully your bumper and winch don't have issues
  18. Dec 5, 2022 at 6:42 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Your headlights are over a year old. Why would you try to get the seller to do anything? Why not reach out to the manufacturer instead?
    Am I missing something?
    If you bought something from Walmart, Target, Bestbuy, Amazon, literally any retailer, and it’s been over a year, what do you expect them to say to you?
  19. Dec 5, 2022 at 6:48 AM
    wduncan1983
    The manufacturer doesn't provide a warranty and this started well before they were a year old. A garage kept vehicle that doesn't see the sun shouldn't have that happen in 12 months anyway.
  20. Dec 5, 2022 at 7:09 AM
    TexasWhiteIce
    Texas
    So the manufacturer doesn’t provide a warranty, but you expect the retailer to? Dude….
    So when did it happen and you just waited to report it? Like within 90 days? Or 10 months?
