Warning Lights! No idea what I did..
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FalconTX89, Mar 1, 2020.
  1. Mar 1, 2020 at 12:16 PM
    FalconTX89
    FalconTX89 [OP] Member
    Joe
    2017 Tacoma Off Road 4x4
    So this weekend I was out on the property doing some hunting when I backed up into a hole that centered my truck in the rear. Wenched myself out and parked it. When I went to leave this morning it was giving me an ABS/Brake/ and Stability red light code on the dash. It gave me an error and wouldnt active cruise control either on the highway. It even gave me an error for 2WD-4WD failure. I was able to clear this later.
    I also feel like maybe it was stuck in 4H or something. I was getting 13 MPG on the highway, when I normally get like 20-21.
    Not sure if anyone else has had this issue?
  2. Mar 1, 2020 at 12:18 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Have you peaked under the truck and taken a look? I’d guess a torn abs wire on the rear axle.
  3. Mar 1, 2020 at 1:17 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Yup, Gotta take a look see. As Stated, ABS wires and sensors to/at wheels + brake lines, and wires/connectors, etc. As for the Cruise ... the computer normally will not let you use cruise if it detects a problem with the vehicle. I'd worry about that last as it may sort itself out when you fix the other error cause(s). Sorry and good luck! Keep usn posted !
    Gunshot-6A likes this.
  4. Mar 1, 2020 at 2:07 PM
    FalconTX89
    Joe
    I've checked all the axles and no cables seem to be lose or damaged.
  5. Mar 1, 2020 at 2:12 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Same! My guess is ABS wire. If u have a scanner u can look at wheel speed sensors and see if they all coincide with each other.
  6. Mar 1, 2020 at 2:17 PM
    Canufixit
    New England
    Bottom is clean ?? Not mudded up ?
  7. Mar 1, 2020 at 2:20 PM
    FalconTX89
    Joe
    There's some mud. Not a whole lot. Could something just be caked over? I just really dont want to take this to the dealer. Lol
  8. Mar 1, 2020 at 2:25 PM
    Canufixit
    New England
    Easy to clean - run it through the car wash .... Also check your disk calipers , Ebrake (Ebrake OK ?), and drum lip for foreign stuff ... Sticks, rocks etc.
  9. Mar 1, 2020 at 3:21 PM
    FalconTX89
    Joe
    Got it clean. Used the pressure washer on all the wheels and undercarriage. Still showing the errors.
    I did notice however something interesting. I get the 2WD-4WD error immediately if I swap from 2WD to 4WD and into 4LO. However, I can hear the 4LO and 4H engage. When I shut the vehicle off in 4LO for example or 4H, it actually shows that its in that mode. Its only when I swap from 2WD..
    As mentioned earlier, the comp wont let me swap to Cruise or when in 4LO use Crawl.
    So I'm thinking maybe its electrical? Something with the fuses perhaps?
  10. Mar 1, 2020 at 3:45 PM
    Georgia Native
    Georgia Native Well-Known Member
    4x4 DCLB 2017 SR5, 2019 4runner Offroad, 2021 SR Access Cab
    Disconnect the battery for 30 minutes. Reconnect and see if it throws the codes again.
    BSFord and Canufixit like this.
  11. Mar 1, 2020 at 3:45 PM
    Canufixit
    New England
    Check your fuses by your lower left leg and underhood drivers side behind wheel and in front of firewall. Others can chime in here if I'm wrong or missed a location ... Again I'd not worry about the cruise until the other issues fixed first
  12. Mar 1, 2020 at 3:47 PM
    Canufixit
    New England
    Yes this .... and code readers are cheap. pick one up as your truck is getting older as well.
  13. Mar 1, 2020 at 5:08 PM
    FalconTX89
    Joe
    Still the same check lights.
    Gonna try the code reader.
    Canufixit likes this.
  14. Mar 1, 2020 at 5:24 PM
    Canufixit
    New England
  15. Mar 1, 2020 at 5:26 PM
    Canufixit
    New England
  16. Mar 1, 2020 at 5:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    Did you happen to fill up with gas before your adventure?
    A loose / cocked gas cap will cause a similar response of lights / loss of functions
    Gunshot-6A and Skydvrr like this.
  17. Mar 1, 2020 at 5:50 PM
    Canufixit
    New England
    Clearwater brings up a point .... When you extracted the truck from the hole - was still ok then? You said next am ... so you drove it (home /some distance?) from the hole and all was fine until the morning ... ??? Did you go any where else between the hole and the next morning ??
  18. Mar 1, 2020 at 5:58 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    So there is a 98% likelihood that this is the front ADD actuator, or the transfer case actuator.. (or the wiring connecting to them).
    If you want to diagnose yourself, really need techstream and a cable. Alternative is an ohmmeter, but much quicker with techstream before going to ohmmeter next.
    Free copies of techstream are available on the site. A USB to OBDII cable is available on Amazon or ebay (about $20-$50).
    This thread has the basic diagnostic data...
    https://www.tacomaworld.com/threads/4wd-actuator-troubleshooting-transfer-case-and-add.578262/
    Canufixit and hiPSI like this.
  19. Mar 1, 2020 at 6:16 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    If it's a fuse, there's a bigger issue, fuses aren't consumables. IMO this is a wiring issue. Cruise turning off is most likely because the ECU is not getting input from the wheel speed sensor.
    Gunshot-6A and Georgia Native like this.
  20. Mar 1, 2020 at 7:07 PM
    SD Quicksand
    SD Quicksand Well-Known Member
    Alex
    San Diego, CA.
    2017 Tacoma TRD Off Road 4x4 Access Cab Quicksand
    Several people have suggested that you get an OBDII reader and check for error codes.
    Most of the inexpensive OBDII readers will read and erase engine trouble codes but will not examine your ABS system. You want an OBDII reader that also has the ABS scan function. They are usually listed as Engine / ABS. Some can scan multiple systems such as Engine / ABS / Trans / SRS (Air Bags). So if you are going to purchase a scan tool, make sure it will scan the systems you are diagnosing.
    Gunshot-6A and Canufixit like this.
