Warning (Mequiars Endurance tire spray)
Discussion in 'Detailing' started by Guerrilla, Oct 26, 2013.
  1. Oct 26, 2013 at 4:53 PM
    Guerrilla
    Guerrilla [OP] L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    Thought I would warn everyone about Mequiars Endurance tire spray. If you do get and use it, first allow it set up for a long time and if you get any on your wheels or paint, get it off quickly. After you drive down the road a bit, pull over and make sure it hasn't slung on your paint, if so get it off THEN..
    Months ago I didn't realize it wasn't dry enough and went on a long ride and noticed too late that it had slung all over the sides of my truck.. It is still on after numerous washes and attempts at removing with automotive base paint reducer and lacquer thinner.
    I actually called Mequiars and they recommended Isopropyl Alcohol. So today I tried some 91% Isopropyl and it helped a "little" on some of the smaller spots, It may work better before it really dries, but DAM this stuff is on, it's ridiculous.
  2. Oct 26, 2013 at 5:05 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    [​IMG] This should do the trick.
  3. Oct 26, 2013 at 5:11 PM
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    I've used that in the past, I'll give it a try too.
  4. Oct 28, 2013 at 8:04 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    I only use gels and let them cure overnight. Endurance, slinging or not has proven to be a greasy dirt magnet for me. I'm always looking for that low gloss natural sheen.
  5. Nov 12, 2013 at 7:26 PM
    JKU3000
    JKU3000 Well-Known Member
    Birmingham, Alabama
    2014 Tacoma
    Ehhhhhh
  6. Nov 12, 2013 at 8:54 PM
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    Yeah so I tried some the other day, didn't work.
    Yeah you're right about it being a dirt magnet. I only tried it the one time, didn't care for the look either.
    Not sure what you're gettin at, but O kehhh
  7. Nov 26, 2013 at 3:27 PM
    Mrallank
    Mrallank Active Member
    Thanx, ill steer clear of this stuff
