Warning on DIY cruise control
Discussion in 'Technical Chat' started by trailertrashman, Dec 4, 2010.
  1. Dec 4, 2010 at 6:37 AM
    trailertrashman
    trailertrashman [OP] Active Member
    10 Reg Cab 4x4
    Folks,
    Sad news on DIY cruise control installation, some Tacomas do not have the necessary wiring, (2010 4x4 2.7 Reg Cab base). Purchased all the parts from the sticky threads, delay wipers went in okay, cruise stalk on steering wheel and clutch switch for it went in fine. Problem is no plug to for clutch switch on cruise control. Friend is long time experienced mechanic could not find it and neither I (most of dash out) could using wiring diagrams from both FSM and Rostra's after market web site. The only ray of hope may be different wiring for 2010's
    Bobby
    Will take to dealer after first of year to see if the can do it
  2. Dec 5, 2010 at 9:35 AM
    otter
    otter Well-Known Member
    Rob
    MI
    09 4 cyl Reg Cab
    The wiring isn't there. They stopped pre-wiring Tacomas for it sometime during the 2009 model year. Some 2009s were lucky enough to get it, mine doesn't have it. I still have all the parts sitting on the shelf. Only way to get them to work is to run wiring yourself from the ECU.
  3. Dec 7, 2010 at 1:20 PM
    TIM GAINOUS
    TIM GAINOUS Well-Known Member
    tallahassee fl
    o7 base desert sand
    tints,venvisors,low pro toolbox, readylift sst ,afe pro dry,dynomax muffler,sec air filter removed. jvc aresenal, with rear jvc 6x9's front blaupunkts.
    hey there either one of you guyss wanna sell the cruise control parts? i was looking on here and saw your posts thanx tg
  4. Jan 21, 2011 at 8:19 PM
    slotdoc
    slotdoc New Member
    Brian
    Henderson, NV
    2008 4x4 2.7
    I would be interested in buying your parts for the cruise control mod.
