Warning symbol on speedometer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nanau_beznez, Jan 10, 2025.
  1. Jan 10, 2025 at 9:22 AM
    Nanau_beznez
    Nanau_beznez [OP] Member
    Northern New Jersey
    2017 Tacoma SR5
    Anyone know what this symbol might be indicating?
  2. Jan 10, 2025 at 9:29 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
  3. Jan 10, 2025 at 9:31 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Just another Friday post...
    RIX TUX, clg and K9tacoma like this.
  4. Jan 10, 2025 at 9:32 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Step 1 - Pop hood.
    Step 2 - Verify engine didn't fall out.
    Step 3 - Close hood.
    Happy Friday!
  5. Jan 10, 2025 at 9:55 AM
    Nanau_beznez
    Northern New Jersey
    2017 Tacoma SR5
    I am legit and newish to the forum. Thanks for the response, and it’s Friday post tip. I had never noticed that symbol before today. It comes on when I turn the key in the ignition, along with a message in the center display to check charging system, but neither stays on once I start the engine. I’m wondering if the speedometer symbol and check charging system message are telling me the same thing or unrelated.
  6. Jan 10, 2025 at 9:57 AM
    Charlie Marlow
    Charlie Marlow Well-Known Member
    Georgia
    19 TRD OR
    That's normal. As long as they go off once you start the truck, everything is fine.
    Just to add a quick edit, I even saw a post on Reddit where somebody used that "trick" to pretend something was wrong with his truck right before he was supposed to meet a buyer as an excuse to not sell it.
  7. Jan 10, 2025 at 10:00 AM
    pdxTacoSR5
    PDX area
    Normal - it is just letting you know the light is working in case there is a reason for it to be on.
    the center display charging annoyance is similar, letting you know battery is being drained without the alternator working.
  8. Jan 10, 2025 at 10:06 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Surprised you didn’t get this light.
  9. Jan 10, 2025 at 10:13 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    It looks to me like you have 3/4 of a tank. I might be wrong.
  10. Jan 10, 2025 at 10:15 AM
    pdxTacoSR5
    PDX area
    to my knowledge, toyota does not own any oil refineries. if they did, that would be a reasonable assumption.
    Nanau_beznez[OP] likes this.
  11. Jan 10, 2025 at 10:16 AM
    pdxTacoSR5
    PDX area
    that is a classic. never saw it before. will be using that again. :thumbsup:
    Lawfarin[QUOTED] likes this.
  12. Jan 10, 2025 at 10:22 AM
    bjohn041
    bjohn041 Well-Known Member
    Brian
    NW WA
    2019 Quicksand TRD Off-Road SBDC
    It means that aliens will soon be arriving to transfer you to their base on the sun.
  13. Jan 10, 2025 at 10:39 AM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
  14. Jan 10, 2025 at 10:53 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    That's telling you that the ignition is on, but the engine isn't running.
  15. Jan 10, 2025 at 10:58 AM
    Tacosauro
    Tacosauro Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
    Thats normal if engine is not running. The light must turn off while truck is up and running. If it stays on while engine is on, then there is an issue.
    It would mean something is wrong with the car, there is a code that needs to be read by OBD scanner, it will say what is wrong. Then you take picture or type out code and what it says there and we can help you out
    OBD scanner plugs to the left lower side of he steering wheel.
  16. Jan 10, 2025 at 2:43 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    did you ck the manual ?
  17. Jan 10, 2025 at 2:44 PM
    RIX TUX
    girls will be girls
  18. Jan 10, 2025 at 2:52 PM
    RIX TUX
    OMG
    Phlogiston likes this.
  19. Jan 10, 2025 at 2:54 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Friday!
  20. Jan 10, 2025 at 2:58 PM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
    It ain't got no gas in it
    RIX TUX likes this.
