Warped rotor(s); unbalanced tires???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChukarBob, Aug 25, 2020.
  1. Aug 25, 2020 at 6:45 PM
    ChukarBob
    ChukarBob [OP] Well-Known Member
    Bob
    Seattle
    2017 TRD Sport DC LB 4WD AT; preceded by '15 Subaru Outback & 2007 Tacoma SR5 DC LB 4WD AT
    Driving home today on I5 after an abysmal round of golf (maybe I should stick to something I'm reasonably competent at?), I noted that semi-heavy braking from 65 +/- mph had a shuddering feel. I've always connected this to warped rotors in other vehicles I've owned / driven. Also, it seems like my Michelin Defender tires, with about 10K miles, seem like they're not as smooth as my previous experience with Michelin tires on other vehicles, with a nearly indistinct shuddering. My truck has about 50K miles on it, with no brake work to date.
    How should I address / triage these issues? I have some thoughts on this based on past experience, but want to make sure I'm not overlooking anything.
    Thanks.
  2. Aug 25, 2020 at 6:48 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    You have warped rotors, mine too at 46k. Your pads are probably worn too.
    zoo truck likes this.
  3. Aug 25, 2020 at 6:51 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Next time u feel it doing it, try using the emergency brake. Only do it at speed though because the drum brakes have a tendency to "lock up". Lightly apply the parking brake and see if it's coming from the rear. There's a tsb for the rear axel and brakes.
    Hooper89 likes this.
  4. Aug 25, 2020 at 6:53 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
  5. Aug 25, 2020 at 8:25 PM
    hockeynut258
    hockeynut258 Well-Known Member
    2019 OR MT
    Had my rear drums turned at 15k as they were warped. The vibration was worst around 60-70mph. Guessing it was from using the ‘auto LSD’ and/or A-TRAC function off road heating them up. I don’t tow but we take the truck off road often.
    Story time, or just read past :)
    I took it to the dealer and they said it was the front rotors and wanted $300 to turn them + diagnostic. I complained as they first said it was under warranty then came back after the ‘diagnostic’ test and wanted money. Called Toyota corporate and complained, 5 min later the dealer called and said they would replace front rotors for free. Too bad they don’t know how to pull the parking brake to test the rears independently.. Won’t bring the truck back to that dealer. anyways, $20 turn at the local tire shop and the truck is back to normal.
  6. Aug 25, 2020 at 8:32 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I gave up golf. Not relaxing except for the beers in the bag.
    Try jacking, loosening, and evenly torquing yours lugs as a first step. Ham-fisted ugga duggas can cause an induced warp.
    Doobfucious and BlkTaco47 like this.
  7. Aug 26, 2020 at 5:56 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    With my tundra it was both after 150k miles...installed new slotted and drilled EBC rotors and new rear brake drums plus pads and shoes....actually the rear shoes were still good. Also was able to get a newer brake star adjuster with more graduation from toyota for the rear drums.
    Skydvrr[QUOTED] likes this.
  8. Aug 26, 2020 at 6:55 AM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Beer can on the floor, spin the rotor and it's a self check run out gauge, and life enhancer.......(the beer) and then get some foot powder for your golf club and practice....lol
    Zim
  9. Aug 26, 2020 at 6:55 AM
    Fredk
    Fredk Well-Known Member
    Fred
    Dark grey 2020
    If you got 50k out of your brakes you are doing great. Apparently as I was told you can"t machine the new rotors and the pulsing on the brakes is usually rust.
  10. Aug 26, 2020 at 7:07 AM
    alegerlotz
    alegerlotz Well-Known Member
    Los Angeles
    2017 Tacoma Limited 4x4
    Before you buy rotors, check the torque on your wheel lugs.
    My truck was doing this and I brought it into the dealer for my last service within the warranty period and they told me I needed a brake job (which is ridiculous at 15K miles where I don't tow, ride my brakes, etc...). I said no. They still changed my oil and rotated my tires. Surprise, no more vibration/thump during braking. Feels like brand new.
    So the issue was likely improper wheel torque, a tire out of balance (unlikely since they hadn't been an issue before either), or something with the rear brakes. I'd check these things first before spending a dime.
    zoo truck and tonered like this.
  11. Aug 26, 2020 at 8:22 AM
    zoo truck
    None
    Rotors are cheap enough today for newer vehicles....don't know of anyone that machines them here anymore, except maybe older stuff. Just my experience with toyota vehicles best not to machine anyways...seen, and heard to much about them warping sooner again.
    tonered likes this.
  12. Aug 26, 2020 at 8:43 AM
    alegerlotz
    Los Angeles
    Funny, when the dealer told me my rotors were warped, they wanted to machine them rather than replacing them. As stated in my other post, none of this was actually necessary for my truck at that time.
