Warped rotors and drums every 15-20k miles ISSUE FINALLY DISCOVERED!!!!!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BuilderBill722, Jun 20, 2021.
  1. Jun 20, 2021 at 9:41 AM
    BuilderBill722
    BuilderBill722 [OP] Active Member
    2016 Black Toyota Tacoma SR5 Crew Cab Long Bed
    I agree. That's what I'm going to do. Thank you.
    hiPSI[QUOTED] likes this.
  2. Jun 20, 2021 at 9:42 AM
    BuilderBill722
    Thank you. I will.
  3. Jun 20, 2021 at 9:46 AM
    BuilderBill722
    Nope, not a 2 footer. I do a lot of stop and go driving as I run a cleaning business and have to keep appointments frequently. As I said though, I had a 2nd Gen 2005 for 13 years, 215k miles and never problems like this. I am at a loss because, like I said, Toyota is supposed to mean Quality Build.
  4. Jun 20, 2021 at 9:46 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    If you have gone to the same dealer. I’m guessing the mechanics that have done the job. Didn’t take the time to bed in the pad and rotors. Then you pick up and go driving and literally the first time you stop and keep your foot on the brake you will imprint material on the rotor face do this a couple times on the way home and it’s just a matter of time the shudder shows back up. Now as you continue to drive you lay down pad material on the rotor face unevenly and the shudder returns.
    BuilderBill722[OP] likes this.
  5. Jun 20, 2021 at 9:47 AM
    OrangeRa1n
    OrangeRa1n Well-Known Member
    Houston Area
    TRD-Offroad 2021
    IMO I would try the caliper upgrade by itself and see how you like it. Drilled/slotted rotors are expensive and are a bit of a controversial subject. Most SCCA members here use larger calipers on solid cheap centric rotors. Most of those guys run their cars pretty hard and have no issues. But if the price is not an issue, I'd say go for the full kit.
    You definitely want to diagnose the car before upgrading, as these kits are not cheap. I still don't think this is user error, as I used to go through pads on my F-150 every 20k and had no problems. I also go through race pads on my Miata every season and reuse the same rotors with no problems, and I use cheap $20-30 rotors on that car.
  6. Jun 20, 2021 at 9:51 AM
    BuilderBill722
    Thank you. I am going to get it inspected by an outside mechanic and probably upgrade.
  7. Jun 20, 2021 at 9:53 AM
    gotoman1969
    Just have them turn the rotors, replace the pads and bed them in correctly.
    wrightme43 likes this.
  8. Jun 20, 2021 at 10:13 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Drilled/slotted rotors are of no use on a street driven vehicle. Drilled/slotted rotors are designed for providing a path for gasses to escape from the pad/rotor interface when operating at high temps like a track vehicle would experience after several laps. Auto-X stuff just doesn't generate the temps/conditions that would benefit from this, so certainly street driven vehicles would also not benefit from this.
  9. Jun 20, 2021 at 10:20 AM
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    Truthfully the gasses issue is even less of a factor now days than it was years ago. Many of us run solid rotors, less likely to develop cracks in them. Slotted do provide some cleaning of the pad or in wet conditions can proved some help. In some cases it’s just about getting some weight out of the rotors which are the heaviest component and can screw with the unsprung weight as you go to larger and larger rotors.
  10. Jun 20, 2021 at 10:27 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    It most likely isn't an issue of poor build quality by Toyota, rather poor service and ineptness of the dealership/service dept.
    No matter how many times this comes up, people refuse to believe that brake rotor "warping" doesn't happen (except when physically bent from extremely over tightening the wheel lugs - usually by using an impact wrench to install a wheel)
    Inept/lazy/stupid/uncaring mechanics see brake jobs as low profit grunt work. Often they just replace parts and send it on its way.
    They don't make anymore if the clean everything, inspect for wear and/or build up on the caliper pistons so many don't. If you didn't get charged for two cans of brake cleaner...there's a good chance that's the problem. A little build up on a caliper piston is enough to make it just a bit sticky, the brakes will still work they'll just slightly drag all the time. The brakes then overheat.
    Most can follow up to this point then they get side tracked because the tech tells them the rotors warped, insinuating that it's the drivers fault.
    No they didn't warp from being overheated. The discs get hot and then when you come to a stop at a long light and hold the brake pedal down, the hot disc cooks the uncured resin binder in the new brake pads. When the brake is released a little of the resin/liner is bonded to the disc. Now with that thin deposit the next full stop that lines up with the same spot bonds a little more. This area is just a couple thousands of an inch thicker, but it feels like it's much thicker when it pushes back each time it rotates.
    As Ripley said....Believe it or not
    OrangeRa1n likes this.
  11. Jun 20, 2021 at 10:36 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Actually i was told the gen1 tundra, and tacoma at the time shared the same brake components. The tundra was too big/heavy a vehicle for those tacoma brake components. Trick was to use the heavier land cruiser rotors, and calipers while modifying the backing plates so they'd fit. The cheaper fix was the EBC rotors which worked fine for me.
  12. Jun 20, 2021 at 10:40 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    You keep saying bent rear axles and that causes everything . Check them or have them checked and then replace if need to before putting all new brakes on again .
  13. Jun 20, 2021 at 10:43 AM
    GrundleJuice
    Michigan
    2016 TRD Bro
    1st gen 6lug Tacoma came with the S12 caliper and the tundra came with the S13/13WL caliper in my experience. The 13WL was a direct bolt on to the Tacoma when paired with the correct rotor.
  14. Jun 20, 2021 at 10:43 AM
    Paulndot
    Paulndot Well-Known Member
    2020 TRD Off Road
  15. Jun 20, 2021 at 10:45 AM
    #35
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    I wouldn't get the drilled rotors. Unless you have ducted vents to the rotors (like on sports sedans/sports cars), they do not offer better braking. Slotted does work better in wet conditions. Unless you live in a place that rains non stop, get a premium rotor.
    I had the Z36 kit on my Tundra....lost braking performance due to lost surface area. I have ducted vents to my Lexus IS350 and I run the EBC rotors and pads. If you stab the brakes on that car....better be ready. My corvette had cross drilled rotors, but wouldn't put them back on when needing replaced.
    Do you have a link to this bent axle suit or an article?
    If you weren't so far away, I would have you come by and run the alignment bar through the axle to see if it's bent. Pretty easy (very time consuming) thing to check.
  16. Jun 20, 2021 at 12:13 PM
    #36
    6MT
    6MT Well-Known Member
    Greg
    2020 TRD OR DCSB 6MT
    Would investigate if your current shop is overtorquing the lug nuts. For multiple sets in a row, this could also potentially be the common variable.
  17. Jun 20, 2021 at 4:02 PM
    #37
    BuilderBill722
    I thought it would help with keeping them cool and lessen the likelihood of warping.
  18. Jun 20, 2021 at 4:05 PM
    #38
    BuilderBill722
    Makes sense. I understand.
  19. Jun 20, 2021 at 4:05 PM
    #39
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Yes rotors most certainly do warp. Especially cheap ones. Rapid heating and cooling will do it.
  20. Jun 20, 2021 at 4:14 PM
    #40
    Clearwater Bill
    Billy
    Largo Florida
    You're not. Since the rotors and drums are chunks of iron, the amount of heat needed to 'warp' them would have given you brake fade from boiling the brake fluid long before you felt pulsation.
    BTW, as others have posted, those don't really warp. Drums can become out of round for a variety of reasons, including improper reassembly, casting flaws, etc. Rotors can become unevenly worn by something as simple as improper torquing sequence on the lug nuts.
    And your move to an independent is a smart play, because the dealership is feeding you a line of misinformation AND overcharging you for the work performed.
    There are good dealers, good service advisors and good techs at dealers. Just not enough of them. So with a situation like yours it's well past time to move on.
