Warped rotors and drums every 15-20k miles ISSUE FINALLY DISCOVERED!!!!!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BuilderBill722, Jun 20, 2021.
  1. Jun 30, 2021 at 5:29 PM
    #101
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Jesus... how many times did you post the conclusion! I saw one, answered and then looked up to find a hundred!:rofl:
  2. Jun 30, 2021 at 5:34 PM
    #102
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    Was it this way from the factory? If so I’d be asking for them to pay for all of those brake jobs you had to pay for
    BuilderBill722[OP] likes this.
  3. Jun 30, 2021 at 5:48 PM
    #103
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    I’D be demanding a new truck at this point. Turn over all your prior invoices for brakes, your invoices at other dealerships for time and money spent for missed diagnosis, and our time for reading the results over and over again. That should be worth at least a 2021 4 banger. :amen::rofl:
  4. Jun 30, 2021 at 6:39 PM
    #104
    BuilderBill722
    BuilderBill722 [OP] Active Member
    2016 Black Toyota Tacoma SR5 Crew Cab Long Bed
    I didn't realize that everyone would see it if I just did the update to the original. I apologize. I wanted everyone to see it especially if someone else has the same problem.
    averagejp likes this.
  5. Jun 30, 2021 at 6:40 PM
    #105
    BuilderBill722
    OK, I'm deleting the responses... I apologize. Once again, I didn't realize I had to do it just once. :(
  6. Jun 30, 2021 at 6:42 PM
    #106
    BuilderBill722
    They are waiting for Toyota approval to redo the brakes and replace the axle at Toyota's cost. I am probably going to have to go to the other dealership when this is all fixed with the paperwork to prove it.
  7. Jun 30, 2021 at 6:46 PM
    #107
    BuilderBill722
    Yes, from the factory. I am going to go back to my servicing dealership with all the paperwork when this is finished.
    barf[QUOTED] likes this.
  8. Jun 30, 2021 at 6:50 PM
    #108
    BuilderBill722
    Yes, waiting for the call to come down and get the new axle put in.
    hiPSI[QUOTED] likes this.
  9. Jun 30, 2021 at 7:01 PM
    #109
    Itchyfeet
    Itchyfeet Well-Known Member
    So how does the rear axle being bent warp the front rotors? Did they figure that out?
  10. Jun 30, 2021 at 9:09 PM
    #110
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    and how do you know its fixed, they havent even replaced the rear axle yet.
  11. Jul 1, 2021 at 4:27 AM
    #111
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    just replaced my front pads for the first time at around 65k and still had some left but i work in another state and inspection was coming up and it just passed and now have 75k on my rear shoes and still good...didn't turn my rotors either, they were fine. probably replace them the next time along with pads at about 130k.
  12. Jul 1, 2021 at 5:07 AM
    #112
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    so did you find out what it was?
  13. Jul 1, 2021 at 5:21 AM
    #113
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Don't bother deleting, but for future reference your can use the multi quote tool to respond to multiple posts with one reply or at least do it in one post.
    This post is an example, since I quoted and replied to another post below vvvv
    If rears start causing pulsations because of uneven transfer layer, the pedal pressure will fluctuate with each rotation and affect the fronts.
  14. Jul 1, 2021 at 5:29 AM
    #114
    manncura
    manncura Well-Known Member
    2020 DCSB 6MT Sport
    Definitely good to have on my radar as i mentioned in previous post My brakes have shuttered on hardish breaking at highway speeds since about 2k miles. I asked them to look at both my 5k service and my 10k service,,,,now need to make sure its noted on the paperwork that I asked them to check it out. Both times they said nothing was wrong. I am going to try and bed my brakes in and see if that helps. Glad you have an answer and will be getting it repaired.
  15. Jul 1, 2021 at 6:56 AM
    #115
    BuilderBill722
    I don't know that it is fixed, yet, but both I and Toyota know what is causing the problem. It is documented on their end that several of their trucks have had this issue with them having been shipped with defective axles from the factory. I am waiting on them to approve the replacement.
  16. Jul 1, 2021 at 6:57 AM
    #116
    BuilderBill722
    Yes. Please read the update on my original post. It was a defective rear axle.
  17. Jul 1, 2021 at 7:09 AM
    #117
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    now the question is, did you keep all the receipts for the repairs and will toyota reimburse you for all those repairs since it was a defect?
