Warped Rotors and Lug Nuts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CVCV, May 12, 2023.
  1. May 13, 2023 at 8:10 PM
    eurowner
    eurowner Duke Sky
    Scoty
    No.
    TireFire likes this.
  2. May 20, 2023 at 12:34 AM
    Kapnd
    Kapnd Active Member
    Thank you for that information. I just ruined a new set of rotors because I ignored the torque specs!
    How would I shop for more robust rotors?
  3. May 20, 2023 at 5:30 PM
    CVCV
    CVCV [OP] 3rd Toyota Truck
    Tacoma 2022 3.5L DCSB TRD OR 4x4
    Does anyone into mods know of improved front brake rotors. I have heard of upgrading to Tundra front brakes, but don’t know of any standard front brake upgrades.
  4. May 20, 2023 at 5:38 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    power stop. but don't purchase for an e-commerce seller as they ship from the distributor and do not inspect before shipping and have zero concern about heavy items being shipped in shitty weak packaging. You might be lucky to get half of the order, and then spend a month fighting to get their crap returned and your money back. I know from a bad experience. Look at Summit or a real parts supply seller - they package and check before sending.
    eurowner and CVCV[QUOTED][OP] like this.
  5. Feb 23, 2024 at 4:00 PM
    manfred twd
    manfred twd Active Member
    mike
    2021 trd takoma
    My 21 trd has always had the lug nuts torqued to 83 ft lbs
    I replaced pads with factory pads at 60'000
    I forget just when but maybe at 70,000 is when I first noticed the warp. It is getting very annoying.
    It's not driven hard or ever towed anything. I just assume poor quality rotors from Toyota
  6. Feb 23, 2024 at 4:20 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    How much torque was caused to warp rotors …. That’s crazy …. Toyota is notorious for warped rotors from the factory …no idea how the tech determined it was caused by over torqued rims ..unless they checked it prior to removing the lug nuts.
