Warped rotors...Any ideas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trdchic, Jun 19, 2011.
  1. Jun 19, 2011 at 7:12 PM
    trdchic
    trdchic [OP] Well-Known Member
    Erie CO
    07, TRD Sport, 4x4, SR5, V6, Access Cab
    Had rotors replaced in December-ish last year. They were warped. They are warped again. I wasn't the owner for the first warping so I don't think it is driving related. Any ideas? :confused:
  2. Jun 19, 2011 at 7:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    are both warped?
  3. Jun 20, 2011 at 12:40 PM
    Eurosport
    Eurosport Well-Known Member
    around the world
    well did you change the pads when you put in the new rotors?
    you should have, otherwise old pads are just eating up the new rotors...
  4. Jun 20, 2011 at 12:44 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Usually Pad fade due to improper break in. Read the following article on "warped" rotors.
    http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml
    Replace the pads and have the rotors turned. Once you have the new stuff installed. Head out to an empty country road (if you can) or somewhere else that is safe. Get up to about 50Mph and then brake hard to about 20. Not hard enough to lock the brakes or kick in the ABS. Then drive for a couple minutes and repeat. do this 5-6 times. You shouldn't have any more issues after that.
  5. Jun 20, 2011 at 12:52 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    x2...
    I doubt the rotors are warped... most likely they have uneven pad deposits from bad pads or improper bedding-in the pads.
  6. Jun 20, 2011 at 12:52 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    Make sure you use a torque wrench on your lugs.
    All life is about balance.............
    Alan
  7. Jun 20, 2011 at 12:56 PM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    HAHH.. beat me! :rolleyes:
    that's a damn good article!
  8. Jun 20, 2011 at 1:31 PM
    ChompsterTacoma
    ChompsterTacoma Well-Known Member
    Chompster
    Fresno,Ca
    TRD offroad 4x4
    Bone Stock
    Mine was making the warpie feelings coming to a stop. So the other day went out to quiet stretch of road and got it up to 60 mph a couple of times and hit my brakes hard. That cured it.
  9. Jun 20, 2011 at 4:26 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Don't stand on the brakes at stop lights and you won't warp em. All I can say, you are in control of the braking action, also, don't ride the brakes into a stop. I've owned multiple vehicles and NEVER had warped rotors.
    Now if I could just teach this to my wife, we'd be golden!
  10. Jul 7, 2011 at 10:18 AM
    trdchic
    Erie CO
  11. Jul 7, 2011 at 10:42 AM
    PreRunnerSeth
    Apex, NC
    Most people dont know that brake pads need to be bedded in, and I have never heard of a brake place/shop that does it for you. most people just jump right in and drive off and never look back until their rotors are "warped" again in a few months.
  12. Jul 7, 2011 at 10:47 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    If your truck has drum brakes in the rear, it is important to make sure they are adjusted up correctly. The auto adjusters never really work that well. If they are not properly adjusted, then the fronts are left doing all of the stopping, which can lead to warped rotors.
