Warped Rotors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dimonback, Jun 24, 2011.
  1. Jun 24, 2011 at 3:44 PM
    Dimonback
    Dimonback [OP] Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    The vibration from my rotors is getting so bad the steering wheel is beating my hands up at highway speed. Has anyone tried the Ebay drilled rotor/pad combos, and can give a review?
  2. Jun 24, 2011 at 3:48 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    This ^^ I wouldn't skimp when it comes to brakes.
  3. Jun 24, 2011 at 3:53 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    is it common to have to replace them after just 6 years on these trucks? mine (to the best of my knowledge) have never even been turned and they seem fine.
  4. Jun 24, 2011 at 3:57 PM
    jgwheeler17
    NC
    neglect, mostly.
    yeah i know braking is hugely the main factor, but i just wouldn't have expected for someone to have to replace them after just 6 years (OP's truck). . . . speaking of, what miles do you have on it OP?
  5. Jun 24, 2011 at 7:36 PM
    Dimonback
    Patrick
    Just turned over 60k- it had 48, with some warpage when I got it. I do a lot of freeway driving now through Austin, which means a lot of braking. But none of my three 4Runners ever had ANY brake work, of any kind, in 100k miles. I expect this pup was abused bad by someone in her previous life.
  6. Jun 25, 2011 at 1:20 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    My steering wheel was beating me up to. I had the rotors turned and installed EBC pads. Brake pad float went away :), but the wheel still shakes. I'm thinking the tires are finally going out of balance from all the wheeling but who knows.
  7. Jun 25, 2011 at 5:14 AM
    Dimonback
    Patrick
    My shaking is only during braking, and the hotter they get, the worse the shake.
  8. Jun 25, 2011 at 5:18 AM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
  9. Jun 25, 2011 at 6:37 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Brembo makes good rotors.
  10. Jun 25, 2011 at 6:46 AM
    racerxtaco
    racerxtaco Well-Known Member
    Joey
    virginia
    01 xtra-cab 4X4 w/cap
    make sure when purchasing your new brake package that you don't get pads that are too soft for the rotors or to hard for the rotors. Incorrect matching of brake components is a huge factor in premature brake wear. Stick with a set that are compliment each other well. Also, if you were wanting to spend more on one component over the other ( pads Vs. rotors), I would choose the premium pad over the premium rotor.
  11. Jun 25, 2011 at 7:31 AM
    Dimonback
    Patrick
  12. Jun 25, 2011 at 7:34 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    OK, I got a question on this. Stock rotors seem 2 B shite. My steering wheel shakes a little and has for a long time. I'm pretty sure it is from warped rotors. I am not a race driver or an off road driver - 99% used to go to work - 99% highway driving. So stock rotors take just about no heat at all B 4 they warp. Question is if I just want a good rotor and pads that won't warp under conservative driving conditions - what should I go with ? I don't think I need slotted or drilled rotors just a good solid rotor that won't warp the first time I put on the brakes. Thanks for any suggestions.
  13. Jun 25, 2011 at 8:28 AM
    berry79
    berry79 Well-Known Member
    Homestead, FL
    08 DBL Cab LB
    EBC, rotors and pads.
  14. Jun 25, 2011 at 9:11 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Did you mic your rotors to measure run-out? if not how can you be so sure they're warped.
    If you haven't mic'd em they probably aren't warped but have uneven pad deposits.
    Read this:
    http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml
  15. Jun 25, 2011 at 9:20 AM
    george3
    New Jersey
    Thanks.
  16. Jun 25, 2011 at 9:21 AM
    george3
    New Jersey
  17. Jun 25, 2011 at 9:38 AM
    Dimonback
    Patrick
    Never even considered this- thanks for the idea. However, I figure I can't go wrong trying to upgrade the brakes, which is my biggest complaint about the Taco. Last car was a Mazda CX7, with pretty astounding brakes- then jump into the truck and I'm completely underwhelmed.
  18. Jun 26, 2011 at 5:08 AM
    Dimonback
    Patrick
    While I had my wife's car in for tires, I asked about the price of turning the rotors. The salesman started off down the warped rotor path, and I told him what I'd read in the article.
    Of course I started thinking- $150 per rotor, with labor, vs $50 machining- of course he's going to discredit the idea of material deposits. Hmmm.
  19. Jun 26, 2011 at 5:44 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    I think the brakes on the six-lug trucks are pretty good actually. The front disk, at least... rear disks vs. drums would be better but they work well enough.
    The front are 4-piston with a thick meaty rotor and can take a lot of heat. But they need a little warming before they bite so first times to brake pedal effort is high until the pads heat up. They also have a nice long life, especially the rear drums.
    This is a good set up for a truck,IMO. Put a 3000 lb trailer w/out surge brakes behind 'em and another thousand pounds in the bed and you'll appreciate 'em better when descending a twisty mountain road.
  20. Jun 26, 2011 at 11:53 AM
    michaelg589
    michaelg589 Well-Known Member
    Ebay brakes. I've never heard a worse idea.
    Drilled rotors are a terrible idea in the first place. Let alone buying no-name brand ones off Ebay. Slotted rotors are also a bad idea and completely unnecessary.
    REPLACING YOUR FACTORY ROTORS WITH EQUAL DIAMETER SLOTTED AND/OR DRILLED ROTORS WILL NOT INCREASE BRAKE PERFORMANCE.
    Slots and holes are for looks only. By using them, your decreasing surface area and thus decreasing pad to rotor contact. A good brake pad will perform very well with a blank rotor.
    Save your self the aggrevation of buying cheap parts. Buy replacement OEM rotors or equal quality blanks and a good set of pads. Hawk isnt bad. EBC also seems good from what I've read. Also, if you havnt bled your brakes since you bought it, I would HIGHLY recommend doing so.
