Warranty About To Expire....Please Help.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmed99, Nov 8, 2011.
  1. Nov 8, 2011 at 10:44 AM
    jmed99
    jmed99 [OP] Well-Known Member
    SC
    09 DC PreRunner TRD OR
    I only have about 2000 miles before my bumper to bumper warranty expires. I'm going to do an inspection this weekend to see if I need to get anything repaired or replaced. :confused:
    Is there anything to pay special attention to that routinely goes bad on this trucks? Anything y'all recommend I check when I do my inspection?
    Thanks a million guys!!!
    :D
  2. Nov 8, 2011 at 10:47 AM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Consider getting a quote for extended warranty before your 36k runs out.
    There are a few threads on here about discounted pricing from dealers across the country.
    Also, I might be paranoid, but I would have my truck inspected by a qualified mechanic other than one working for a Toyota dealership. They have no incentive to be honest with you. If they see something that will fail in the next 5,000 miles and they don't tell you now it will be more $$$ later for the same job.
    Get your own mechanic or trusted shop to look at it. They get paid for their time and are in a better position to be honest with you about what is about to fail.
  3. Nov 8, 2011 at 10:49 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    If your not experiencing any issues and there's no visible oil leaks I'd say your good to go.
  4. Nov 8, 2011 at 11:08 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    If it ain't broke...
  5. Nov 8, 2011 at 11:30 AM
    poynter
    poynter Well-Known Member
    Tony
    Somerset, KY
    05 Taco 4x4 SR5 TRD AC
    ...drive the piss out of it?
  6. Nov 8, 2011 at 11:33 AM
    Pugga
    Massachusetts
    F-150 Mod
    errr... yeah, sorry, drew a blank there for a second :D
  7. Nov 8, 2011 at 11:49 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    My truck had a 60,000 mile extended warranty on it that the previous owner bought when he bought the truck new. He said he never used it and I never did either.
    101k miles now and the only problem I've had was the factory battery went kaput at 45k miles. (knock on wood haha)
    I think extended warranties are a waste of money, especially on a toyota...that's just my opinion.
  8. Nov 9, 2011 at 7:59 AM
    jmed99
    SC
    I'm not getting an extended warranty and that wasn't the question. Anyone else know anything in particular I should check before my warranty runs out?
  9. Nov 9, 2011 at 8:41 AM
    macgyver
    Brad
    Canton, GA
    Maybe the rear leaf spring TSB.
    Other than that, if nothing is broken..I wouldn't worry about it. The warranty is only there to cover "broken" stuff.
  10. Nov 9, 2011 at 8:51 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Bull bar, nerf bars, bed extender, tonneu cover, bug deflector, wish list,....
    They will not replace anything that is not broken, so even if you find something that others had problems with, it will not help much. Your idea is good though. Check the waterpump to make sure it is not leaking, check under the truck for oil leaks, even if it is just sweating. Note any weird noises that you don't like that were not there when the truck was new. If you can give the dealer a legitemate list of items (limit to only a few, otherwise they will know you are just bullshitting) that you are really concerned about, they will have it on record, so if something breaks soon after the warranty expired you can tell them "I told you so". Other than that there is not much you can do to let them do preventative maintenance under warranty.
    It is a Toyota though, so you should be fine (too bad it is not a 1st gen; you would have had no concerns then :D)
  11. Nov 9, 2011 at 12:24 PM
    jmed99
    SC
    I'm not trying to get them to fix things that aren't broken. I just want to make sure I check everything to make sure nothing is broke. Thanks for the help so far!
    Anyone else???
  12. Nov 9, 2011 at 12:25 PM
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    use duct tape, it makes it better
  13. Nov 9, 2011 at 3:52 PM
    blackpearl11
    blackpearl11 Well-Known Member
    2010 tacoma
    You have to remember, just because you think something may be about ready to break, that does not mean toyota will replace it. They will more than likely only replace it if its broken
  14. Nov 22, 2011 at 7:42 PM
    05blutaco
    05blutaco Member
    SW Indiana
    11 DC...Just gettin started
    3" Toytec lift. Full tank of gas
    My 05 Taco Double Cab 4x4 has really started bottoming out bad when I hit a bump. I've had air bags installed and some really good shocks but neither has helped. I called my local dealer in Evansville IN but was told the leaf spring upgrade is no longer covered on my 05 and if I wanted it to be prepared to spend $2600. Is this true? I just noticed TSB -0359-10 from December 21 2010 and wondered if I talk to the Manager or to Toyota direct if I might be successful. From what I see from other members the leaf spring upgrade is about the only other option to me. Thanks for you help and Happy Thanksgiving!
  15. Nov 22, 2011 at 7:57 PM
    joes06tacoma
    Joe
    Central Coast, CA
    OP, if you're still reading this thread I would suggest taking the truck to an independent shop and have them check it out and see if there is anything about to go. Toyota isn't going to volunteer to tear into your truck without a specific complaint.
    Off the top of my head: check for oil seepage at the passenger side of the timing cover, consider the leaf spring TSB if you haul, and I think that's about it. The 09s were pretty refined compared to the earlier ones.
  16. Nov 22, 2011 at 8:10 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2015 DCSB OR Auto Silver Sky 4x4
    I bought a Toyota so that I didn't have to worry about a warranty.......:D
  17. Nov 22, 2011 at 8:42 PM
    Rupp1
    NC
    I'm still looking for a good sig.
  18. Nov 22, 2011 at 8:47 PM
    Qjake
    Qjake Just another Masshole
    Billy
    Massachusetts
    2016 Limited
    SCS Ray10's • 265/70/17 KO2's • Tonneau • Pop-n-lock • AVS Ventvisors • Weathertech • RedLine Hood struts • NoxLux Blackout Kit & Tailgate letters • 20% Tint • Cast OEM RunningBoards • Dechromed •
    ^This^
    Also my 09 developed a rattle/clunk in the steering, do a search for Intermediate shaft TSB
  19. Nov 23, 2011 at 12:32 AM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    2600 ???? No fukin way you can buy a very nice set of aftermarket springs for a lot less than half of that!
  20. Nov 23, 2011 at 6:09 AM
    Large
    Large Red
    I had an 06 lifted w / 33s bought the extended warranty and it ran out, basically wasted my money b/c nothing went wrong. Bought my 2011 new, paid $250 for the 125k mile B2B warranty (had no intentions of buying it at all) still think I overpaid. They give the option of extended warranty b/c they don't lose money on it lol. If you haven't had problems it's fine, if you think you did something you still have a 60k mile power train.
