warranty at the dealership
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mike686, Oct 4, 2011.
  1. Oct 4, 2011 at 4:01 PM
    mike686
    mike686 [OP] Well-Known Member
    Michael
    Waldorf
    10 Tacoma TRD Off Road
    See Build Thread
    Alright so I retrofitted my headlights a week ago and its hunting season so I got in my truck today and a cel is lit ... take it to the dealership thinking it was something with the headlights ... no the lady who was pretty damn cute came over and told me my throttle body needs to be replaced and its under warranty ... my question is has anybody else had this happen and what code is this or what happens to throw a code for the throttle body
  2. Oct 4, 2011 at 4:07 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I haven't heard of that. And there's no way in hell that your headlights could trigger a CEL.
  3. Oct 4, 2011 at 4:20 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    P2103 Throttle Actuator Control Motor Circuit High
    - Short in throttle actuator circuit
    - Throttle actuator
    - Throttle valve
    - Throttle body
    - ECM
    P2111 Throttle Actuator Control System - Stuck Open
    - Throttle actuator
    - Throttle body
    - Throttle valve
    - ECM
    P2112 Throttle Actuator Control System - Stuck Closed
    - Same as DTC P2111
    P2118 Throttle Actuator Control Motor Current Range / Performance
    - Open in ETCS power source circuit
    - Battery
    - Battery terminals
    - ETCS fuse
    - ECM
    P2119 Throttle Actuator Control Throttle Body Range / Performance
    - ETCS
    - ECM
    P2120 Throttle / Pedal Position Sensor / Switch "D" Circuit
    - Accelerator Pedal Position (APP) sensor
    - ECM
    P2121 Throttle / Pedal Position Sensor / Switch "D" Circuit Range / Performance
    - Accelerator position sensor
    - ECM
    P2122 Throttle / Pedal Position Sensor / Switch "D" Circuit Low Input
    - APP sensor
    - Open in VCP1 circuit
    - Open or ground short in VPA circuit
    - ECM
    P2123 Throttle / Pedal Position Sensor / Switch "D" Circuit High Input
    - APP sensor
    - Open in EPA circuit
    - ECM
    P2125 Throttle / Pedal Position Sensor / Switch "E" Circuit
    - APP sensor
    - ECM
    P2127 Throttle / Pedal Position Sensor / Switch "E" Circuit Low Input
    - APP sensor
    - Open in VCP2 circuit
    - Open or ground short in VPA2 circuit
    - ECM
    P2128 Throttle / Pedal Position Sensor / Switch "E" Circuit High Input
    - APP sensor
    - Open in EPA2 circuit
    - ECM
    P2135 Throttle / Pedal Position Sensor / Switch "A" / "B" Voltage Correlation
    - Short between VTA1 and VTA2 circuits
    - TP sensor (built into throttle body)
    - ECM
    P2138 Throttle / Pedal Position Sensor / Switch "D" / "E" Voltage Correlation
    - Short between VPA and VPA2 circuits
    - APP sensor
    - ECM
  4. Oct 4, 2011 at 5:43 PM
    mike686
    Michael
    Waldorf
    See Build Thread
    Im thinking it was p2118 ... I mean I noticed it this afternoon before that I hadn't drove it for a week ... and they said I could drive it home so its not stuck in any way
