Warranty Enhancement - Propeller Shaft Universal Joints
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ozzy73, Dec 1, 2017.
  1. Dec 7, 2017 at 8:21 PM
    pinchetaco
    pinchetaco Well-Known Member
    Winston Salem, NC
    06 Taco 6 inch ProComp Lift 35's
    6 inch ProComp Lift, 35s, ProComp Wheels, 4.88 gears, Debadged, BHLM, Dome Light Mod, Trailer Plug Relocated
    I need to look into this as well. Haven’t gotten any letters but I’ve definitely got some vibes. Been greasing the joints but still vibes under throttle
  2. Dec 9, 2017 at 8:14 AM
    altidude
    altidude Member
    Colorado
    2011 TRD XCab Pyrite Mica
    Does anyone know if they will do this if your truck is lifted?
  3. Dec 9, 2017 at 8:49 AM
    2011Streaker
    2011Streaker Well-Known Member
    Maine
    2012 DCSB TRD Sport
    I wonder why this isn't all of the model years? I have a 12 and I have the same 15-25 mph vibes that my 11 had, that they issued the TSB for.
    Or is this entirely different?
  4. Dec 9, 2017 at 8:59 AM
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    Got the letter for my X-Runner. I have had a vibration under anything over half throttle since I bought the truck.
    Will be taking it in when I get a chance.
  5. Dec 11, 2017 at 12:59 PM
    ozzy73
    ozzy73 [OP] Active Member
    Milton, Ontario
    2005 Toyota Tacoma TRD 370 KM
    If anyone is interested replacement part # is 37100-04363 .
    I could not find any info online on ujoint details ( grease-able/sealed ).
  6. Dec 11, 2017 at 1:07 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    My '15 PreRunner has no Zerks from the factory. 38k miles. No vibrations
  7. Dec 15, 2017 at 3:02 AM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    Just took my'05 in and I'm getting 3 new universal joints. Hope this helps with the vibes, also wonder if it's why I needed to replace pinion bearing earlier this year
    wheeliest likes this.
  8. Dec 15, 2017 at 3:12 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  9. Dec 15, 2017 at 3:51 AM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    My driveshaft on my tacoma doesn't, but my '08 4runner has them on both the driveshaft and u joints. I've changed my u joints on the tacoma a couple times along with carrier bearing. The new u joints have grease fittings, and they get greased every oil change.
    ozzy73[QUOTED][OP] likes this.
  10. Dec 30, 2017 at 4:57 PM
    rjbt770
    rjbt770 Member
    ronnie
    bay area, Ca
    2006 DCSB 4x4 off road
    just got my letter in tghe mail today!
  11. Jan 17, 2018 at 11:38 AM
    larolco
    larolco Member
    Vancouver, BC
    2006 SR5 sold 2023 SR5
    Follow up:
    Took the truck in for inspection and they found no problem with the U-joints. No charge.
    Looks like I'm doing a wheel bearing instead...
  12. Jan 17, 2018 at 4:39 PM
    Richie Rich
    760 (San Diego)
    "No problem found" with my X-runner either.
    Was told that the vibrations I am feeling were associated with the aftermarket (not cheap, properly hub centric) wheels.
    I called bullshit, that it did the same thing since I got the truck (came with OEM wheels/tires), they still said no dice.
    Not super happy about it.
  13. Jan 17, 2018 at 7:04 PM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
  14. Jan 18, 2018 at 1:36 PM
    dhzbmx
    dhzbmx New Member
    I had the same issue, had to take it to a gear place to replace pinion.
    07 trd tacoma 87k miles
  15. Jan 18, 2018 at 5:03 PM
    #35
    anangrytaco
    anangrytaco New Member
    Jose
    Red 08 Tacoma
    Self Installed backup camera
    I got my letter this week (2nd week Jan 2018).
    Truck started rattling at around 90k miles usually around 25mph-30mph.
    Truck is at 97k miles currently.
    Made an appointment at my local dealership and showed them the letter.
    They did and inspection and said the would not charge me for the analysis ($180) as long as the source of the rattling was the propeller driveshaft. They immediately asked me that if I agreed to have the $180 inspection ahead of time it wouldn't be added to the repair bill of w.e. else would be causing the rattling. I figured no matter what they found they were going to try to have a lunge at my wallet.
    After waiting for a couple of hours they said that there are possible multiple sources of vibrations.
    1. Break-pads, rotors, and calipers may be "loose" because they're not OEM. So they maybe causing some of the rattling. Recommended that I get them change even though they're new and only had about 10k miles of use. Cost: $596.95
    2. Tires are not balanced. (A reasonable possibility) Cost: $89.95
    Total: $686.90 + Tax
    So because there are two other possible sources of vibration they cannot identify that the propeller shaft is the source of the rattling (its more of an all throughout shake actually). A little disappointed that a Master Technician backed with the tools of a proper dealership's service center can't identify whether or not the properller shaft is in a position/condition where it would cause a rattle/shake distinct to the "brakes being lose" or unbalanced tires.
    I made an appointment with another dealership.
    I hope they can identify whether or not the propeller shaft needs replacing or not.
    Hope you guys are having better luck so far!
  16. Jan 19, 2018 at 2:53 AM
    #36
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    Whoa! That sucks. Hate when they do that, try to blame non Oem parts, but charge 4-5x more for them.
    On the other hand, you seem to agree somewhat that it might not be the propeller shaft. Just seems to me that a good mechanic with a truck on a hoist could wiggle/find the problem.
    $180 analysis? Wow! I get dinged at $107 or something like that, here in Ontario.
  17. Jan 25, 2018 at 12:41 PM
    #37
    ozzy73
    Milton, Ontario
    Some dealerships are better than others.
    I don't understand the charge for the analysis. It's a warranty replacement by Toyota. They are paying the dealerships to do the work.
  18. Feb 16, 2018 at 1:20 PM
    #38
    BigE taco
    BigE taco Well-Known Member
    Eric
    Sarasota, FL
    19 TRDOR DCSB
    19 TRD OR DCSB Cement Falken Wildpeak AT3W 275/70/17 TRD Sema Pro TRD Pro Fox Shocks with Wescott lift Icon AAL progressive leaf pack Freedom Off Road UCA ECGS Bushing SSO slimline hybrid bumper in Zeak 12000lb winch Rigidhorse 20" led combo light bar Taco Garage "TRD Pro" Grill RC TuningFL OTT mild/medium tune Rav4 blindspot mirrors Seat Jackers driver seat Tri fold hard bed cover...came with truck Magnus side steps...came with truck, don't like them Tufskinz Inferno various interior items Auxbeam led low beam headlights "TRD PRO" style fog lights "TRD PRO" style skid plate Meso Custom Total Tail Stg 1 OEMAudio speakers Multi Ch amp, Sub amp and Toyota Gain Knob 09 TRD OR DCSB....sold Falken wildpeak at3w 265/75/16 TRD Pro Kit with Headstrong Prog. AAL TRD Seat Covers TRD Drop filter TRD Exhaust Led headlights and fogs Hidden light bar Led interior lights Pioneer Avic-F900BT Kicker speakers swap Kicker Solo 10" Kicker kx400.1 misc..$$$ spend on unnecessary things AVS in channel visors Trifecta tri fold Toyota Bed Extender Toyota Skid plate
    Just got my letter today and I have been noticing the u joint squeaking last week and have been trying to pinpoint which one. Does anyone know if I have just a small spacer leveling kit it the front if it would void any recall? Should I take my spacers off and go to the dealer?
  19. Feb 18, 2018 at 7:24 PM
    #39
    atxboyof08
    atxboyof08 New Member
    2006 PreRunner 2WD, 4 door, V6 4.0L
    I just got my letter in the mail today, after replacing all 3 u-joints couple months ago (2 were bad, so figured I mightiest well replace all 3 at the same time).
    I wonder if this covers the carrier bearing as well. Kind of nervous of getting stuck with a diagnosis fee if they try say its the replaced u joints.
  20. Feb 22, 2018 at 6:57 AM
    #40
    CajunCubsFan
    CajunCubsFan Well-Known Member
    Scott
    NE Texas
    White 2015 Tacoma TRD 4x4
    3" lift OME Nitrocharger 16" SCS Ray 10's Utility cap AL Offroad Roof rack Prototype SSO Tacoma Rock Sliders
    No, it doesn't!!! :frusty: They wanted to charge me $350 to replace that when they did my
    "Warranty Enhancement"
